POV-Ray : Newsgroups : povray.off-topic : An explanation of what next_permutation does Server Time
31 Mar 2026 15:00:36 EDT (-0400)
  An explanation of what next_permutation does (Message 11 to 20 of 32)
Subject: Re: An explanation of what next_permutation does
Date: 4 Dec 2009 11:56:22
Message: <4b193f36$1@news.povray.org>
Darren New wrote:
> It's about as complex as a case statement.
In particular, it *is* [part of] a case expression. ;-)
Date: 4 Dec 2009 12:12:32
Message: <4b194300$1@news.povray.org>
Yes, *I* know that. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 4 Dec 2009 12:40:25
Message: <4b194989@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> >>>>     ([] , _  ) -> Nothing
> >>> Yeh, it's really clear what this line does to a non-Haskeller :-)
> >> I'll tell you what it does: It makes the function crash. o_O
> >   After this you should really stop picking on C variants (or at the very
> > least, not immediately compare them to Haskell). ;)
> Why? Because I wrote some code with a small typo?
  Because it's exactly as (or even more) obfuscated as your hated C, and
it seems to be equally easy to make something "crash" by mistake.
  Also you should understand that the Haskell line might not be obfuscated
to *you* because you know how to read it, but it's quite obfuscated to
others who don't understand it. The same works for C as well. Thus you
really don't prove anything by saying "that piece of C(++) is really
obfuscated, I don't understand it, here's how I would write it in Haskell"
and proceed to present a program which is at least as obfuscated.
Date: 5 Dec 2009 08:57:23
Message: <4b1a66c3@news.povray.org>
If you make a typo in a Haskell program, the program stops and says
"error: you tried to access the first element of an empty list". If you
make a typo in a C program, the program stops and says "error:
segmantation fault".
The former is easier to debug [although, admittedly, it gives you
absolutely no indication of *where* the program crashed], while the
latter is no fun at all. Also, the former is an *exception*. You can
catch exceptions and handle them if you want. As far as I'm aware, you
cannot catch segfaults.
Performing multiple steps all at once in a small blob of symbols? Sounds
fairly non-trivial to me. By contrast, the Haskell version doesn't use
any remotely advanced features of Haskell, just a few case expressions
with some basic pattern matching. No monads, no typeclasses, no
existential types, nothing. Just plain ordinary pattern matching.
For me, the question is not how obscure it looks, but how difficult it
is to explain it.
FWIW, I think this particular algorithm itself is pretty tricky, no
matter which language you use for it.
http://blog.orphi.me.uk/
Date: 5 Dec 2009 12:12:16
Message: <4b1a9470@news.povray.org>
  And?
  Actually you can catch exceptions in most systems, and you can resolve
the exact location of the crash using a debugger.
  Haskell is fairly (in)famous for its one-liners which do tons of things.
  Because you wrote it so. The C++ version could also have been written to
be as verbose and straightforward as possible. It's not like you *have* to
write dense code.
> is to explain it.
  Many Haskell one-liners would probably take entire books to explain.
Date: 5 Dec 2009 12:34:53
Message: <4b1a99bd$1@news.povray.org>
*If* you're lucky.  What's worse is when it *doesn't*. :-)
> As far as I'm aware, you cannot catch segfaults.
You can, but not in a portable way, a language-defined way, or in a way
that's useful for debugging or continuing on.  You cannot, for example,
catch a segfault and use it to extend the size of the array you just ran off
the end of.
Date: 5 Dec 2009 12:36:35
Message: <4b1a9a23$1@news.povray.org>
I think APL (and now J) is the canonical example for that.
Well, the particular bit you complained about is no more complex than
    case 23: return 0;
in C. It's just that Haskell has literals that aren't in C, so "case 23"
looks funky.
Date: 5 Dec 2009 13:45:01
Message: <4b1aaa2d@news.povray.org>
Worse Than Failure.
> You can, but not in a portable way.
I had a feeling the OS might provide a way to do this. (Presumably
that's how the shell tells you your program segfaulted.) And that would
make it OS-dependent...
Date: 5 Dec 2009 13:57:33
Message: <4b1aad1d$1@news.povray.org>
>   And?
And if your program stops with an exception, you can catch and handle
it. If it segaults, AFAIK you can't do anything about it.
C and C++ have debuggers which are actually useable. I'll give you that one.
> write dense code.
No, BUT EVERYBODY DOES.
Nobody told this C++ programmer "hey, please write this in the most
complicated way possible". He just did, out of habit.
Personally, I don't have a problem with being able to incriment or
decriment a variable just by saying "x++" or whatever. It's a nice
shortcut. But when you reach the point of performing an assignment and
incriment at the same time... well, *I* certainly wouldn't write code
like that. I'd be forever having to double-check whether the incriment
happens before or after the assignment, and so on.
>> is to explain it.
Haskell allows you to do clever and rather opaque things such as compute
a list of all the prime numbers in the universe in a one-liner, or
Pascal's triangle, or the Fibonacci numbers, or whatever. And, yes, it
takes some explaining to unravel.
*This* program, however, involves no such cleverness. Merely a few case
expressions. Aside from the unfamiliar syntax, there's really little
about it that's complex. No fancy tricks, no clever math, just a few
conditional tests and a couple of function calls.
Date: 5 Dec 2009 13:58:09
Message: <4b1aad41@news.povray.org>
  You seriously claiming that if you make a typo in Haskell, it always
magically knows that and gives you an error message?
