POV-Ray : Newsgroups : povray.off-topic : The magic of CSV Server Time
13 Sep 2025 02:20:14 EDT (-0400)
  The magic of CSV (Message 1 to 10 of 19)
Subject: The magic of CSV
Date: 2 Dec 2009 11:09:51
Message: <4b16914f$1@news.povray.org>
OK, so today I confirmed that you can in fact export data from the
Windows event log into a plain CSV file. Which is great.
(Unfortunately, sometimes event descriptions contain line breaks, which
is not so great.)
Anyway, I wrote a small Haskell program that deletes any multi-line
events, and then another which grabs only the events I care about and
does some trixy parsing of the event description to pull out the data I
actually want. The result is a big CSV file containing a list of printer
events - date, time, user, printer and page count.
(There is *one* event in the log that says something like "document %4
was printed on %6, byte count: %7, page count: %8". Which is really not
especially helpful...)
So now I have a CSV file that contains the date, time, user, printer and
page count. Just import that into Access and produce some stats, right?
Wrong! Access apparently can't parse any of the dates. Despite them all
being perfectly valid dates (and it even *detects* that this column
should be a date column), it fails to parse every single last one. >_<
So I used Haskell (which is really the wrong tool) to produce some
statistics the hard way - by manually scanning the CSV file, reparsing
the data and writing the results into yet *another* CSV file.
And now, finally, I have a chart showing me how many pages each printer
printed on a given day. Which is all I wanted in the first place!
Mmm, apparently that printer in the corner hasn't printed a single
damned page since July... Yep, it's definitely spare. :-)
Subject: Re: The magic of CSV
Date: 2 Dec 2009 11:23:56
Message: <4b16949c$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4b16914f$1@news.povray.org...
> OK, so today I confirmed that you can in fact export data from the Windows
> (Unfortunately, sometimes event descriptions contain line breaks, which is
> not so great.)
> events, and then another which grabs only the events I care about and does
> (There is *one* event in the log that says something like "document %4 was
> being perfectly valid dates (and it even *detects* that this column should
> statistics the hard way - by manually scanning the CSV file, reparsing the
> Mmm, apparently that printer in the corner hasn't printed a single damned
Have you tried importing your CSV file into Excel first, then moving it to
Access? I've found that it sometimes does better with external data. It's an
extra step, but it may give you cleaner data, and may make the process
easier to do the next time, if there is one.
Jack
Date: 2 Dec 2009 11:33:06
Message: <4b1696c2$1@news.povray.org>
I did notice that Excel apparently had no difficulty with the date
column - or indeed any other column for that matter. So maybe that would
work...
Date: 2 Dec 2009 11:41:25
Message: <4b1698b5$1@news.povray.org>
>> to Access? I've found that it sometimes does better with external data.
>> It's an extra step, but it may give you cleaner data, and may make the
>> process easier to do the next time, if there is one.
> work...
If all you have is Haskell, every problem starts looking like an erm... that
self-functor (or whatever) thingy.
Stefan Viljoen
Date: 2 Dec 2009 11:47:15
Message: <4b169a13$1@news.povray.org>
>> work...
Well, it *did* solve the problem, didn't it? :-P
I could have spent more time fiddling with Access to coax it into
working, or I should do what I did: produce a solution that works right now.
Now, if I knew a lot about Access and very little about Haskell, the
most efficient solution might have been different... ;-)
Date: 2 Dec 2009 11:51:36
Message: <4b169b18@news.povray.org>
>>> work...
>> that self-functor (or whatever) thingy.
Haha yes, granted, a solution that works is what you want. :)
> now.
Exactly!
Probably, though as another poster said, the first thing I'd have tried is
"piping" the file through Excel.
Stefan Viljoen
Date: 2 Dec 2009 11:54:39
Message: <4b169bcf@news.povray.org>
And that would have been because I don't know squat about Haskell.
After that, (if Excel didn't solve it) I'd have tried a commandline PHP
script. Again the "hammer-nail" paradigm. I guess most people will use the
tool or language they know best to solve a problem in the quickest, most
direct way.
Stefan Viljoen
Date: 2 Dec 2009 12:00:14
Message: <4b169d1e@news.povray.org>
> work...
It would seem to me that the appropriate solution is to add up the columns
appropriately using excel.  Adding up columns is kind of what it does best,
after all.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 2 Dec 2009 16:07:10
Message: <4b16d6fe$1@news.povray.org>
>> would work...
> columns appropriately using excel.  Adding up columns is kind of what it
> does best, after all.
Well, I'd like to be able to sort and filter the data and so forth -
Access is specifically designed to be able to do that kind of thing,
whereas Excel makes it a bit tedous.
By the way... I just realised. While you *can* move data between Excel
and Access easily enough, there isn't actually a way to run a query in
Access and get a chart as the result. I never thought about it before.
But you'd have to run the query, copy the data, paste it into Excel and
then fiddle about with chart options. There isn't a button in Access
that says "please plot this as a pie chart" or something...
http://blog.orphi.me.uk/
Date: 2 Dec 2009 16:08:01
Message: <4b16d731$1@news.povray.org>
> direct way.
And, no doubt, you actually have the PHP interpretter installed, whereas
I only have a Haskell interpretter. ;-)
