A little math help here? Wolfram Alpha is being bloody awkward at me...
side is 1 mile long, and the other side is 24 cm long. What are the
other two angles??
> other two angles??
That depends on whether one of those sides is the hypotenuse.
"Graphic Artist seeks Boss with vision impairment."
> side is 1 mile long, and the other side is 24 cm long. What are the other
> two angles??
Google "(24 cm / 1 mile) in degrees".
If you want more accuracy then it's going to depend on whether the 1 mile
side is the one opposite the 90 degrees or not.
Google:
"asin(24 cm / 1 mile) in degrees"
or
"atan(24 cm / 1 mile) in degrees"
Ah, good old Google calculator. It may not know how to compute the
Riemann zeta function, but it at least manages to do common math
operations. :-D
Apparently it's 0.00854446724 degrees, which is about 30 seconds. That's
some pretty fricken tiny angle!
> other two angles??
http://en.wikipedia.org/wiki/Right_triangle#Trigonometric_ratios_in_right_triangles
FE
According to Wikipedia:
"20/20 is the visual acuity needed to discriminate two points separated
So I guess 30 seconds (0.5 minutes) could plausibly be within the range
of normal human vision then.
I just noticed the other night that as I passed under a sign telling me
the motorway exit was in 1 mile, I could already see the green traffic
lights beyond the exit. And those lights can't be much more than 24cm
across...
> > other two angles??
This is basic trigonometry which is taught in high schools in most places.
> "20/20 is the visual acuity needed to discriminate two points separated by
> So I guess 30 seconds (0.5 minutes) could plausibly be within the range of
> across...
Hmm, I can see an object perfectly fine with an angle of 10^-9 degrees.
Being able to see something and discriminate between two points is
different.
I did say "trivial", didn't I? ;-)
My education didn't include this information. Also, I have no idea how
many centimeters there are in one mile.
> across...
Lights can be seen much easier than other details.
