POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
4 Jul 2026 12:08:09 EDT (-0400)
  Trivial trigonometry (Message 31 to 40 of 178)
Subject: Re: Trivial trigonometry
Date: 30 Nov 2009 06:35:01
Message: <web.4b13acc76ad665b96dd25f0b0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> OK, so according to the best data I could get my hands on, Alpha Centuri
> A is about 430 light years away
Um, I'm pretty sure that should be 4.3 lightyears.
http://en.wikipedia.org/wiki/Alpha_centauri
That will make your numbers a little more sensible. There are very few naked-eye
stars that are as far as 400 lightyears - only highly luminous giants like
betelgeuse.
Date: 30 Nov 2009 06:38:51
Message: <4b13aecb$1@news.povray.org>
> betelgeuse.
EPIC FAIL. >_<
Maybe I should just go away and live in a box somewhere. :-S
Date: 30 Nov 2009 06:40:01
Message: <web.4b13ad866ad665b96dd25f0b0@news.povray.org>
> The part that really puzzles me as that even on the clearest, most
> cloudless night, there are, like, maybe 3 stars visible in the entire
> sky. And yet mankind has names for hundreds and hundreds of stars, many
> of which are claimed to be "visible to the naked eye".
> I can only presume this must be due to light pollution.
Entirely. There are over a thousand stars visible to the naked eye.
http://en.wikipedia.org/wiki/Naked-eye_stars#Naked_eye_in_astronomy
There is nothing like spending a couple of hours on your back in a field with a
truly dark sky - it feels like there are far more than mere thousands visible!
:o
Date: 30 Nov 2009 06:45:53
Message: <4b13b071$1@news.povray.org>
> :o
But where do you have to go? Outer Mongolia?
(Also... where the hell *is* that anyway?!)
Date: 30 Nov 2009 07:15:01
Message: <web.4b13b6596ad665b96dd25f0b0@news.povray.org>
Well, I bet the skies are great there(!), but at least 50 miles from a large
town or city would do in the UK. Simply making sure you can't see an artificial
light source directly by eye will make a big difference. Coastline works well
because you've only got to worry about distance from towns in half as many
directions. Wilderness such as moorland or mountains works best of course
(although steep hills will obstruct part of the sky), but I'm sure you could
find somewhere suitable within a short drive of MK. Also, winter is best because
the cold air holds less moisture and is therefore clearer. Try to make sure the
moon isn't up either, it can produce a surprising quantity of light pollution,
especially when full!
Oh, and pick a cloudless night ;-)
Date: 30 Nov 2009 07:47:26
Message: <4b13bede$1@news.povray.org>
> Still, even on school caving trips in the middle of nowhere, I don't
> recall seeing many stars in the night sky. I presume they're still there,
> we just can't see them any more.
http://www.astro-travels.com/pictures/Europe-Light-Pollution.jpg
On the above map my house is on the border of a green/yellow region and I
can make out a huge number of stars on a clear night, the Milky Way is also
just barely visible on a really good night.  I don't know exactly where MK
is on that map, but it looks a bit red/orange around there :-(
Don't forget you need to go outside for at least 20 minutes or so for your
eyes to get fully adjusted to the dark, initially it might look like only a
dozen or so stars are visible, but after a few minutes you will see hundreds
more.
BTW if you're interested, one of the brightest "stars" in the sky at the
moment is actually Jupiter.
Date: 30 Nov 2009 07:54:37
Message: <4b13c08d$1@news.povray.org>
>> there, we just can't see them any more.
> I can make out a huge number of stars on a clear night, the Milky Way is
> also just barely visible on a really good night.
Aren't we *in* the Milky Way?
> where MK is on that map, but it looks a bit red/orange around there :-(
I would suggest that MK is the small red dot just NW of London. (Or if
it isn't, it's in that general direction.)
> your eyes to get fully adjusted to the dark, initially it might look
> like only a dozen or so stars are visible, but after a few minutes you
> will see hundreds more.
We drove to and from work through lots of wilderness, and at this time
of night it's quite dark even at 5PM. Many of the roads aren't lit.
I don't recall where we get dragged to on our school caving trips, but
we seemingly had to drive for many hours along winding rounds lined with
dry stone walls before reaching the nearest building with electricity.
Any ideas what the visual angle for that is? ;-)
Date: 30 Nov 2009 08:06:19
Message: <4b13c34b$1@news.povray.org>
Yes, and it's quite a flat disc, so looking out from Earth along the plane
of the disc you see a lot more stars than looking out perpendicular to it,
this looks like a brighter band going across the sky.
Wikipedia tells me the radius is 71500 km, Stellarium tells me it's 5.224 AU
away from us, so googling "2*71500 km / 5.224 AU in degrees" gives 0.01
degrees.
Date: 30 Nov 2009 08:15:39
Message: <4b13c57b$1@news.povray.org>
> plane of the disc you see a lot more stars than looking out
> perpendicular to it, this looks like a brighter band going across the sky.
I will admit I don't know much about the geometry of our galaxy, but I
was under the impression that the disk is hundreds of billions of light
years "thick", it's just that it's quadrillions of light years across as
well. The point being, the disk is many million stars thick, and so we
should see them in just about every direction we look.
>>> the moment is actually Jupiter.
> 5.224 AU away from us, so googling "2*71500 km / 5.224 AU in degrees"
> gives 0.01 degrees.
So... about 36 seconds of arc. Man, that's pretty small.
Date: 30 Nov 2009 08:20:01
Message: <web.4b13c6376ad665b96dd25f0b0@news.povray.org>
This is a pretty awesome photo of the whole thing:
http://en.wikipedia.org/wiki/File:Deathvalleysky_nps_big.jpg
Not exactly what you'd see with the naked eye but it gives you the idea.
> degrees.
Jupiter and Saturn are particularly easy to pick out, because they're big enough
to be actual discs rather than points like regular stars. And if you can hold
binoculars steady enough you'll just about see Saturn's rings.
