POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
4 Jul 2026 09:01:28 EDT (-0400)
  Trivial trigonometry (Message 169 to 178 of 178)
Subject: Re: Trivial trigonometry
Date: 8 Dec 2009 02:05:20
Message: <4b1dfab0$1@news.povray.org>
Darren New wrote:
> Kevin Wampler wrote:
>> All are in agreement with he Schrödinger wave equation, so it's not
>> the equation that's the issue here.
> OK. I'm now more educated, I think.
It's a point which is often neglected.  Just to be clear though, the
issue is more subtle than I'm making it sound and AFAIK most
interpretations which give a deterministic state to the cat have run
into problems (for instance when incorporating them into special
relativity).  Also such interpretations are necessarily non-local.
>> Perhaps I'm missing what  point you're making?
> Only that the quantum equations don't *seem* to apply to the macroscopic
> world, for reasons unknown?
Yeah, IANAP (I am not a physicist) but as far as I'm aware this is
correct.  Although I think there's some interpretations which describe
why this is the case perfectly well, they just might come with other
philosophical implications that are undesirable (for instance I'd put
the many-worlds interpretation into this class).
Date: 8 Dec 2009 02:19:32
Message: <4b1dfe04$1@news.povray.org>
I read recently that someone did a Bell's Inequality type of experiment with
  more than 20 angles measured in 3D and from that somehow deduced locality.
Interesting.
Yah. I suspect it's much more mundane, like the "decoherence" section of the
paper Neeum posted.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 8 Dec 2009 12:35:44
Message: <4b1e8e70@news.povray.org>
> with  more than 20 angles measured in 3D and from that somehow deduced
> locality. Interesting.
Do you have a reference to this?  I'd be interested to see the details
of what exactly they mean by that.
Date: 8 Dec 2009 12:46:14
Message: <4b1e90e6$1@news.povray.org>
I'm afraid that was before I started bookmarking everything that caught my
interest. :-)  It was in something like Discover magazine, so there wasn't
much detail beyond what I already said in the article itself, but there
might have been links to the actual publication on the page.
Date: 8 Dec 2009 19:09:59
Message: <4b1eead7$1@news.povray.org>
Invisible wrote:
> http://en.wikipedia.org/wiki/File:Perseid_Meteor.jpg
> Here in the name of God does the night sky actually look like this?!
Anywhere far away from any major population center.  In addition to
being able to see many more stars, I've found that you can also spot
about 10-30 shooting stars per hour in areas like that.  It's quite
beautiful, and unfortunate that many people have always lived where you
simply can't see that sort of thing.
Date: 9 Dec 2009 00:22:09
Message: <4b1f3401$1@news.povray.org>
Darren New wrote:
> Patrick Elliott wrote:
>> Of course, the only flaw in the argument is that a cat isn't a
>> particle, so what effects *one* particle, doesn't effect something
>> made of a *lot* of them.
> Why not?  Indeed, that *is* the flaw in the argument, but the question
> is "why not?"
>> This is the absurdity involved. Its like asking why relativity doesn't
>> work in black holes. Because its a bloody black hole, which has
>> different rules.
> Relativity works just fine in black holes. That's why we know about them.
>> In effect, QM is what goes on in single instances,
> Single instances of what?
>> normal reality is an emergent property of what happens when QM can't
>> (or, if you prefer, the constraints put on the system reduce the
>> probability of a different result to near zero).
> Like what, in the case of the cat, specifically?  A different result
> from being alive or dead?
>> Same with particle interactions. Right?
> You tell me. You seem to have it all figured out so trivially.
No, what I am getting at is the math works in some specific cases, but
most of the time your particles are "not" in a state where that case
applies. That is what I mean about constraints. The cat, as a
collection, has constraints that an individual particle, in the test
cases, doesn't. After all, we don't throw cats are targets to measure
their QM, we generate single particles. And, no, that isn't bloody
trivial, any more than saying, "adding a strange attractor", tell you
what the result will actually look like. It just tells you it won't be
what you would have had *without it*. If I said A + B = QM, that would
be a "trivial" solution. lol
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 9 Dec 2009 01:09:30
Message: <4b1f3f1a$1@news.povray.org>
> applies.
Why not? If the particle gets in that state, how does it get out of that
state? You can't just say "interaction" without giving specifics, since
"interaction with other particles" is exactly what QM defines. If it was
obvious that mere interactions with other particles resolved the problem,
the guy who invented the Schrödinger equations wouldn't have come up
 with
the thought experiment in the first place.
What situations do particles get into where the QM equations don't apply?
Because every test seems to indicate we know the right *equations* to a
tremendous number of decimal places.  You can't just say "it doesn't appl
y
sometimes" without saying the circumstances under which it doesn't.
> cases, doesn't.
That's the "decoherence" argument, if I understand you right. It's one of
many possible answers, but it's not obviously accepted by everyone involv
ed.
What constraint applies to many particles that doesn't apply to one,
according the the Schrödinger equations?
Sure. But we look at distant stars to see the QM manifest in outer space.
 We
generate Bose-einstein condensates bigger than a cat.
Sorry. Pronoun overflow. What tells me what what wont be without what?
Date: 9 Dec 2009 23:41:48
Message: <4b207c0c$1@news.povray.org>
Darren New wrote:
>> It just tells you it won't be what you would have had *without it*.
What the result will be, without an attractor. As I said, I don't have a
math equation to explain it, but there obviously needs to be one, since,
under normal circumstances, as you say, you don't get non-decoherent
effects.
void main () {
   else
Date: 10 Dec 2009 13:44:58
Message: <4b2141aa$1@news.povray.org>
OK, I'm afraid you're not making any sense to me, so ... nevermind.
You're either completely missing my point, or you're talking about something
entirely different than what I am.
Date: 10 Dec 2009 16:10:00
Message: <4b2163a8$1@news.povray.org>
> something entirely different than what I am.
I am saying that, in general principle, large masses of particles act
"similar" to what a strange attractor does for the images some people
have been making in povray.images. It changes the behavior of the
system. Until you plot the result, you don't necessarily have a
prediction of what that will be, but it "not" what you end up with if
you had one single particle. Mind, in reality, we have fairly clear
ideas what happens if you place x number of protons/neutrons and
electrons together, in a stable configuration, you end up with an
element or isotope.
None of which describes why, or how, trivially or otherwise, which is
the crux of your accusation.
void main () {
   else
