POV-Ray : Newsgroups : povray.off-topic : Modern Linux desktops suck Server Time
2 Jul 2026 12:00:10 EDT (-0400)
  Modern Linux desktops suck (Message 108 to 117 of 127)
Subject: Re: Modern Linux desktops suck
Date: 23 Nov 2009 04:30:45
Message: <4b0a5645$1@news.povray.org>
>> Unix software, on the other hand, seems to regard giant text files (all
>> with a completely different format) as the *primary* means of
>> configuration, and a GUI as secondary to that.
> Let me introduce you to YaST....Before I started using it, I didn't like
> the idea of it, but now that I'm used to it, guess what - I don't have to
> tweak all these different configuration files, because it handles it for
> me most of the time.
The problem is, Unix has _always_ been designed around the idea that
everything is a text file and that's how you configure the entire
system. Sure, these days we have pretty front ends that atempt to hide
all the complexity. But as soon as you need to edit something there
isn't a front-end for, or the text file contains some setting that the
fancy front-end doesn't comprehend... suddenly you need to know how all
this stuff works again.
Windows, on the other hand, has always been designed around the idea
that the user doesn't know anything about computers and needs to be
shielded from anything more complicated than a lightswitch. Which is
sometimes quite frustrating, in a different way...
I think XKCD sums it up nicely:
http://www.xkcd.com/619/
Date: 23 Nov 2009 13:15:00
Message: <4b0ad124@news.povray.org>
>>> (all with a completely different format) as the *primary* means of
>> like the idea of it, but now that I'm used to it, guess what - I don't
>> have to tweak all these different configuration files, because it
>> handles it for me most of the time.
Allow me (again) to introduce you to YaST, or Webmin.  I've found very
little that these two frontends won't configure properly.
And again, allow me to introduce you to YaST and Webmin.... ;-)
Full-screen flash video support has been around for a while.
Jim
Date: 23 Nov 2009 13:23:22
Message: <4b0ad31a@news.povray.org>
Invisible escreveu:
What that really means is that there are GUIs for all the n00b-level
options and if there isn't, the Windows n00b will have to mess around
with the arcane registry or RTFM for the first time in his life.
I like configuration files better than GUIs for no other reason that I
can simply grep it for whatever I'm looking for or remotely related --
direct to the point.  In GUIs I have to go through a multitude of
recursive menus or tabs hidden well underneath other options etc...
a game sig: http://tinyurl.com/d3rxz9
Date: 23 Nov 2009 19:45:31
Message: <4b0b2cab$1@news.povray.org>
	Not really on Linux. It eats up the CPU, and doesn't seem to utilize
many capabilities of the graphics card - which the Windows plugins do.
"Graphic Artist seeks Boss with vision impairment."
Date: 23 Nov 2009 22:38:08
Message: <4b0b5520$1@news.povray.org>
utilize
I use it quite frequently, and while it does suck CPU, it does run full
screen, which is what the claim there was....
"Works for me"....
Jim
Date: 24 Nov 2009 04:23:41
Message: <4b0ba61d$1@news.povray.org>
The things that require you to touch the registry are so arcane that
your average n00b wouldn't even comprehend what you're talking about.
Stuff like changing the network MTU, or the order in which IRQs are
assigned to PnP devices, or other such obscure stuff like that.
Usually the challenge is just figuring out which sub-sub-menu M$ has
hidden the setting you want under. (Or just which combination of options
makes the program behave correctly.)
I'd be surprised if that actually works.
The option you want to change might be at default, and thus there's no
entry for it in the config file. It might have a highly non-obvious
name. Or it might be configured from a totally different file. (E.g.,
there is [presumably] a file somewhere which configures your network
interfaces. But the DNS configuration is in an entirely unrelated file.)
M$ does have an annoying habit of hiding absolutely every configuration
setting under an "advanced" tab...
Date: 24 Nov 2009 10:25:29
Message: <4b0bfae9$1@news.povray.org>
> utilize
> "Works for me"....
	Ah. You have a fast CPU.
	It's like saying "X works", when you don't have 3-D working. A major
"feature" of the plugin fails to work. From my perspective, that means
it *doesn't* work.
	Anyway, on many computers, including mine, playing HD videos full
screen on Flash gets jerky. CPU can't handle it, and the CPU isn't
supposed to handle it - the video card is.
Date: 24 Nov 2009 11:27:08
Message: <4b0c095c$1@news.povray.org>
> it *doesn't* work.
I have this persistent problem with my co-workers. Everyone was telling me
"yes, that works" and I'm saying "I'm getting no output" and they mean "it
compiled without errors."  Sheesh.
   You know the kamikaze monsters in Serious Sam
     with the bombs for hands, that go AAAAAHHHHHHHH!
   I want that for a ring tone.
Date: 24 Nov 2009 11:29:12
Message: <4b0c09d8$1@news.povray.org>
In particular, in a file that says nothing about DNS in the name or
contents. And even if you knew it was called the "resolver", they spell the
name of the configuration file *wrong*, so you can't even find it with 'find'.
Only the advanced ones you shouldn't screw with without knowing what you're
doing. :-)
Date: 24 Nov 2009 13:41:31
Message: <4b0c28db$1@news.povray.org>
The Linux Flash is still a crappy piece of shit. It's a resource hog and
still it's amazingly stupid (eg. won't handle second soundcard, even
though it supports ALSA).
-Aero
