POV-Ray : Newsgroups : povray.off-topic : Quick C++ question... Server Time
15 May 2026 08:03:56 EDT (-0400)
  Quick C++ question... (Message 16 to 25 of 25)
Subject: Re: Quick C++ question...
Date: 11 Nov 2009 22:21:07
Message: <4afb7f23$1@news.povray.org>
Darren New schrieb:
> clipka wrote:
>> Fun fact about structs in C++: They /are/ classes. Only major
>> difference (IIRC) being that their members default to "public:".
> That much I knew already. But I don't know if C structs are C++ structs
> for sure. :-)
Well, C structs are fully compatible to C++ structs, aren't they? You
can link a C++ program against any C library; and you can compile a C
library with a C++ compiler, and still link it to a C program. So...?
Date: 11 Nov 2009 23:05:51
Message: <4afb899f@news.povray.org>
Aren't they?  That's what I understood the intent to be, but I'm not sure I
ever looked it up definitively. :-) Good to know.
Date: 12 Nov 2009 12:49:16
Message: <4afc4a9c@news.povray.org>
> Classes only start to really diverge from classic C structs when you go
> for stuff like virtual methods or multiple inheritance. In the former
> case there'll be a few hidden data members that C++ will automatically
> add, while in the latter case... heck, I have not the slightest clue :-)
  Firstly, C++ structs are enormously different from C structs in that C++
structs are, in fact, C++ classes. The *only* difference between a struct
and a class is default accessibility of members (iow. if access rights are
not specified, members will be by default private in a class but public in
a struct). This means that you can add a whole lot of things to a C++ struct
which you cannot to a C struct, such as constructors, a destructor, assignment
and other operators, member functions, and public/protected/private access
right specifiers.
  But secondly, if you *inherit* from a C-style struct (POD), this base
part will still be a basic struct even if you use things like virtual
methods or multiple inheritance in the derived class. In other words,
if something expects a pointer to an object of the struct type, you can
pass it a pointer to an object of the derived type and it will work just
fine. The inherited class using things like virtual functions and multiple
inheritance does not affect the base struct part.
Date: 12 Nov 2009 12:51:54
Message: <4afc4b39@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> I'll have to look at this again (and
> look up some syntax to see what "x::y : z" means :-)
  That might surprise many beginner and mid-level C++ programmers, but
there's nothing special going on there. You can pre-declare an inner
class and declare it later. The "x::y" part simply means "class y inside
class x". And the ": z" part means, of course, inheritance from z.
  In other words, this is perfectly valid (and quite handy):
class A
    class B;
class A::B
Date: 12 Nov 2009 14:14:43
Message: <4afc5ea3$1@news.povray.org>
Oh! OK. Heh. I don't think I've ever had the pleasure of needing or using
inner classes before, in any language, so it didn't leap out at me.
Oh! And A::B means class B inside class A, not class A inside class B. Wow,
that confused me for a bit.
I see that. Yes, that could work cleanly, if I wanted to redeclare every
function exported by DirectFB. Easier to kludge it in *this* case, but I'll
remember the trick for another time where I'm writing actual production
code. :-)
(Indeed, I'm doing the same thing with the "Player" vs "Player_private"
except I'm not making it an inner class. I'll have to think if that would
help anything.)
Date: 12 Nov 2009 14:16:15
Message: <4afc5eff$1@news.povray.org>
Cool. Not even C# manages that. (You can't put virtual methods on a value
class.) Another win for C++ MI.
Date: 12 Nov 2009 14:56:51
Message: <4afc6882@news.povray.org>
  Why not? It aids in limiting the visibility of types, and thus increases
modularity. If a class uses a helper class which is completely exclusive
to that class (and might even be a friend), then it makes sense that the
helper class is defined as a private inner class.
Date: 12 Nov 2009 14:58:57
Message: <4afc6901@news.povray.org>
  Forgot to mention practical examples.
  Ever wondered what, for example, std::list<int>::iterator is? Well,
surprisise surprise, it's an inner class inside std::list<int>. It's so
related to std::list that it makes a lot of sense to make it an inner class.
Date: 12 Nov 2009 16:53:39
Message: <4afc83e3$1@news.povray.org>
>   Why not?
I just haven't needed it. In languages where there's specific header files
(i.e., C and C++), I don't include the header file for the child class. In
languages where there's specific support for the concept (C#) I use the
internal visibility. I haven't done much in Java since they invented inner
classes, but those aren't really "invisible" so much as obsfucated anyway,
so there didn't seem to be a benefit there either.
I.e., everyone already has modular visibility controls, so putting it inside
a class rather than a namespace didn't seem worthwhile.
Yes it does. I didn't say it was bad. I just said I never found the need to
use one. The existent mechanisms were already sufficient.
Date: 12 Nov 2009 17:55:13
Message: <4afc9251$1@news.povray.org>
> to use one. The existent mechanisms were already sufficient.
Altho your point of a public class with an embedded iterator is a good one.
I even expect C# uses embedded classes to implement that in the libraries,
now that you mention it. Of course, the name isn't exposed outside the class
in any way, so it's hard to tell without reading actual source code.
Instead, there's a call called "getEnumerator" or something on the
collection that returns something that inherits the Enumerator interface or
some such. You don't directly instantiate an iterator, but rather ask the
class for one.
