POV-Ray : Newsgroups : povray.off-topic : Swell. Server Time
17 May 2026 22:04:06 EDT (-0400)
  Swell. (Message 43 to 52 of 312)
Subject: Re: Swell.
Date: 9 Nov 2009 11:44:00
Message: <4af846d0$1@news.povray.org>
On Mon, 09 Nov 2009 16:53:14 +0100, clipka wrote:
> Jim Henderson schrieb:
>> See my anecdotal evidence in reply to Stefan.  Two identical units, one
>> powered on and off regularly, one that was left on 24x7.  Guess which
>> one failed?  Not the one that has been turned on and off regularly for
>> 5 years now.  The one that was plugged in and running for 3 years
>> solid.
> I wouldn't be too much surprised if HDD manufacturers would know ways
> how to optimize drives for one usage pattern or the other, so that maybe
> indeed powering up and down might kill a server HDD quickly, while 24x7
> usage might shorten the life of an office computer / consumer HDD.
That seems to be reaching to me.
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:44:11
Message: <4af846db$1@news.povray.org>
On Mon, 09 Nov 2009 12:42:03 +0000, Stephen wrote:
> Jim Henderson wrote:
>> On Mon, 09 Nov 2009 11:42:48 +0200, Stefan Viljoen wrote:
>> Of course the first showed no signs of slowing down either - right up
>> to the minute that it croaked.
>> Jim
> The way of the world*
> * By William Congreve - premiered 1700
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:45:59
Message: <4af84747$1@news.povray.org>
Stefan Viljoen schrieb:
> Read a while ago that the RAF had to pay compensation to almost a hundred
> car owners - one of their air-defense "steerable-array" radars went haywire
> and scanned over a road - they burned out almost every vehicle's ignition
> and fuel injection microprocessors with the radar beam!
Ouch!
That reminds me of the tale told by an old acquaintance of mine, who had
served on some air-defense radar installation, of how they'd keep an
older fellow soldier at bay when he got all enraged and charging for the
hilltop bunker they were sitting in.
You know, the old guy had a pacemaker... so pace he did make when he saw
those radar antennae slowly closing in on his direction...
Subject: Re: Swell.
Date: 9 Nov 2009 11:46:46
Message: <4af84776$1@news.povray.org>
On Mon, 09 Nov 2009 15:14:40 +0200, Stefan Viljoen wrote:
> See my other reply too... granted, but you refer to an "enclosure" - is
> that a mobile drive? E. g. one which you pull out of its enclosure at
> work, then you put it in an enclosure at home if you need something off
> it?
No, it's an external USB storage device with 2 (I presume) IDE hard
drives in it.
> *brrr* - I shiver at the thought of a mobile HDD as a backup device...
> How do you feel about the statement that the fact that if a drive is
> mobile, inherently it will never last as long as a "traditional"
> statically mounted drive that just sites in a cradle internally in a
> climate controlled server rack / box?
Given that this mobile drive lasted longer than a stationary drive that
was the same make/model, my anecdotal evidence wouldn't support that
assertion.
That said, I do not abuse the drive that I move from one place to another
- and the drive isn't intended as a "backup" per se - it's intended more
to be a local copy of data I may need when working from home (which is
90% of the time).  The data itself is backed up by our IT staff.
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:48:47
Message: <4af847ef$1@news.povray.org>
>> Personally, I'd probably use SSD for my system partition (for the
>> faster booting) and use cheap spinning disk for my POV-Ray renders. ;-)
> How much storage capacity do you need for a Linux system partition?
> They fit /entire/ Linux installations on a single CD, so...
Ah yes, but under Windoze all programs insist on being installed on C: ;-)
Subject: Re: Swell.
Date: 9 Nov 2009 11:49:12
Message: <4af84808@news.povray.org>
On 11/08/09 20:09, Tim Cook wrote:
> My half-full terabyte external hard drive seems to have died.  I opened
> the case and there doesn't seem to be anything visibly wrong with the
> drive, and it was working just fine earlier today (even ran a checkdisk
> to be sure)...it just doesn't spin up when powered on. Hopefully it's
> just the enclosure. Have ordered a new one, which will arrive in two or
> so days.
	I had an enclosure die on me. As have many of my friends.** No more
enclosures for me.
** Lose enclosures. My friends didn't die...
Engineers: often wrong, seldom in doubt.
Subject: Re: Swell.
Date: 9 Nov 2009 11:50:44
Message: <4af84864@news.povray.org>
On 11/09/09 03:24, Jim Henderson wrote:
>>> guess there isn't a convenient modality for backing up 500GB of data?
>> There is - but not for sane prices, no.
> A 1.5 GB SATA Seagate Barracuda drive costs a mere $95 from newegg.
> I guess that arguably is an insane price - insanely cheap.
	Sounds insanely expensive to me. Even for a USB flash drive...
Subject: Re: Swell.
Date: 9 Nov 2009 11:55:19
Message: <4af84977$1@news.povray.org>
Yeah, now if I had written TB instead of GB (which is what I meant to
write), that changes the dynamic a little bit. ;-)
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:55:27
Message: <4af8497f$1@news.povray.org>
> Well said - guess there isn't a convenient modality for backing up 500GB of
> data?
Yes, there is.  Buy two.  :-)  I don't know about elsewhere in the world,
but 2 1-TB drives would run you <$400 here.
Then use robocopy (or rsync on Linux and probably Mac).  I'll give you my
robocopy scripts if you want - you can even take a volume shadow so you can
keep using the disk while it's backing up.
Subject: Re: Swell.
Date: 9 Nov 2009 11:57:53
Message: <4af84a11$1@news.povray.org>
Hopefully that's TB. :-)
> I don't know, man... Backing up spinning disk to... spinning disk? Is
> that such a sensible idea?
Why not? It's a backup. It's not like you can read a tape without spinning
it. What are you going to back it up to, FLASH RAM?
> (Then again, I don't have any hard data on the reliability of HD verses
> tape verses CD. I've heard that spinning HD up and down wears it out
> faster than keeping it spinning, but I don't know if that's true...)
And by the time you actually have to worry about that, those drives will be
your temp drives and you'll be buying 15TB SSDs for the next computer.
