POV-Ray : Newsgroups : povray.off-topic : Swell. Server Time
17 May 2026 10:57:48 EDT (-0400)
  Swell. (Message 123 to 132 of 312)
Subject: Re: Swell.
Date: 10 Nov 2009 10:13:31
Message: <4af9831b$1@news.povray.org>
On Tue, 10 Nov 2009 07:38:30 +0000, Orchid XP v8 wrote:
> Wanna take a guess what the customary place to install programs is?
> Yeah, it's C:\Program Files.
Then there's also the button that lets you choose a different location to
install to - part of pretty much every modern installation program on
Windows.
Jim
Subject: Re: Swell.
Date: 10 Nov 2009 10:16:57
Message: <4af983e9$1@news.povray.org>
On Tue, 10 Nov 2009 10:21:30 +0000, Invisible wrote:
>>> ...yeah, shopping online tends to be cheaper. Quality is another
>>> matter, of course.
>> Buy from reputable dealers, and quality isn't an issue.
> I don't mean to imply that quality is *necessarily* an issue, just that
> it *can* be more of an issue. As you say, it depends who you buy from.
Exactly.  I started using newegg because system builders I know who build
for small businesses used them.  I rarely go to a place I've never heard
of and bought something.  Oddly, the svideo cable I mentioned before I
did go to a relatively unknown company - but I didn't drop more than
about 10 bucks on the cable, either, and when I do something like this, I
usually start with something cheap.  I did this with a place that sold
through Amazon - bought a $3 iPod battery replacement kit - that worked,
so ordered a laptop battery from them for my stepson's laptop.  Both have
worked well. :-)
> I often buy from Maplin because 1) I don't have to wait for it to be
> delivered, 2) their staff actually have a frickin clue, and 3) they
> don't argue about returns.
Sometimes expediency is worth the extra cost - as is the ability to get
something replaced without a hassle.
Jim
Subject: Re: Swell.
Date: 10 Nov 2009 10:18:51
Message: <4af9845b$1@news.povray.org>
> In theory, until the disks are spinning at full speed, you don't get that
> "cushion of air" for the heads to "fly" on, which should result in wear.
> Of course, no doubt manufacturers know all about this and have come up
> with ways to at least reduce the problem...
There's probably just a reserved portion of the platter that is used for
spin-up/down operations.  The only tricky bit is to get the head over to
that portion when the power is suddenly cut.
Subject: Re: Swell.
Date: 10 Nov 2009 10:25:20
Message: <4af985e0$1@news.povray.org>
>> Tape operates at much lower speeds. And since the only people who use
>> tape are people who want seriously reliable backup storage, it tends to
>> be very well engineered. (And stupidly expensive...)
> Never used DAT drives for backup, have you? ;-)
No, only for the last 6 years.
> Horrible quality of storage media, and terrible shelf life IME.
Really?
Subject: Re: Swell.
Date: 10 Nov 2009 10:27:59
Message: <4af9867f$1@news.povray.org>
Maplin are pretty much the best electronics shop around.
I mean, apart from being the *only* place in all of Christendom which
can sell you (say) a 50kohm resistor, their staff have a clue about what
they're supposed to be selling, and if you take something back they will
exchange it or give you your money back (provided it isn't obviously
busted).
Their website utterly sucks, by the way...
Subject: Re: Swell.
Date: 10 Nov 2009 10:32:46
Message: <4af9879e@news.povray.org>
>> that "cushion of air" for the heads to "fly" on, which should result
>> in wear. Of course, no doubt manufacturers know all about this and
>> have come up with ways to at least reduce the problem...
I'm 98% certain this is the case. However, that still means that this
part of the disk wears down, and also that the heads themselves wear down.
> The only tricky bit is to get the head over to that portion when the
This is probably fairly trivial. In the old days you used to have to run
the "park" command. But today... well, have you ever noticed that
"click" noise when you unplug the power? I imagine that's the magnet in
the voice coils parking the heads. ;-)
In fact, I've disassembled a HD and observed that the arm strongly
resists any attempt to remove it from the home position. It keeps
wanting to click back into place, with the heads on the outer edge of
the platters.
Subject: Re: Swell.
Date: 10 Nov 2009 10:33:52
Message: <4af987e0$1@news.povray.org>
> Windows.
There is *usually* such a button, yes. Not always though.
And it's not unheard-of for a program to malfunction if you change this
setting during installation. (You'd think if they offered you the
option, they'd implement it so it works. But not always...)
Subject: Re: Swell.
Date: 10 Nov 2009 10:35:01
Message: <web.4af98757a6cd6561ccf29180@news.povray.org>
I think they don't park the heads on the platter any more, they're moved out of
the platter radius before spindown.
Moving the head out of the way in case of power failure is not so problematic
I'd think. The positioning coils of the heads are constantly under current and
cutting this current will create a force. You "just" have to make it so that a
power failure exerts a force in the head mechanism that whips the head into
park. ;o)
Subject: Re: Swell.
Message: <web.4af98774a6cd6561ccf29180@news.povray.org>
Jim Henderson <nos### [at] nospamcom> wrote:
> On Mon, 09 Nov 2009 16:53:14 +0100, clipka wrote:
> > I wouldn't be too much surprised if HDD manufacturers would know ways
> > how to optimize drives for one usage pattern or the other, so that maybe
> > indeed powering up and down might kill a server HDD quickly, while 24x7
> > usage might shorten the life of an office computer / consumer HDD.
> That seems to be reaching to me.
> Jim
Not that reaching. WD sells HDs which are specifically for 24/7 usage.
I think the difference is the lifetime of the bearings which is dependent not so
much on actual age but on revolutions and temperature.
Subject: Re: Swell.
Date: 10 Nov 2009 10:35:27
Message: <4af9883f$1@news.povray.org>
Stefan Viljoen wrote:
> This is what always bursts my bubble about space travel - whenever I hear of
> the incredible distances involved.
The distances are *astronomical*!
Literally. As in, that's where the term comes from. ;-)
> it is still 4 YEARS in space to the nearest start.
I'm glad it's not just me who constantly mis-spells "star". :-D
> To even get to more "close" stuff, 6 YEARS, 10
> YEARS - or -thousands- of years (at LIGHTSPEED!) to another galaxy.
Indeed. Without warp drive and the ability to vastly exceed the speed of
light, it will just take such an absurdly long time to go anywhere that
it doesn't bare thinking about. Think about it: how long ago did we land
on the moon? And how long after that did we land on Mars? Oh, wait...
In fact, half the stars in the night sky probably DON'T EVEN EXIST ANY
MORE. It's just that it's taken that long for the light to reach us.
> Of course, time dilation at high relativistic velocities might mean you can,
> from your relative viewpoint, complete the journey within a human lifespan
> of 70, or 80 years, depending on just how close you can get to the
> magical "c". Nothing would be left back home though, since thousands of
> years might have passed there...
> It just somehow... sad.
Yeah.
