![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am Fri, 30 Oct 2009 06:59:05 -0400 schrieb Warp:
> I don't understand why linux would modify the frequency/timings of cpu
> and
> memory, and even if it did, why it would have to modify BIOS to do that.
I don't know why it would change the BIOS either, but AFAIK for some
CPU's one could reduce the power consumption by using a lower CPU
frequency (power savings on mobile computers).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jim Henderson wrote:
> This is true - the *nix way (in general) is that the HW clock is set to
> GMT and the OS calculates the offset. That may be what TC is seeing.
Speaking of which... how do you change the timezone on Linux these days? The
TZ variable isn't set. I think it's a Debian install. (It's a VM at work, so
I barely know anything about it, but if screws up the timestamps because the
head office is in a different timezone.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 30 Oct 2009 23:42:19 +0100, Darren New <dne### [at] san rr com> wrote:
> The TZ variable isn't set. I think it's a Debian install.
http://lmgtfy.com/?q=debian+change+timezone
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> The TZ variable isn't set. I think it's a Debian install. (It's a VM at
> work, so I barely know anything about it, but if screws up the
> timestamps because the head office is in a different timezone.)
I would change it on my SUSE systems using YaST, most likely, in the time/
date configuration.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> date configuration.
That's why I asked. The VM I'm using is all command-line driven, let alone
something as nice as YaST.
Fortunately, Fredrik googled it for me. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> time/ date configuration.
> alone something as nice as YaST.
I was tempted to, but since he already did.... ;-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
>> and
> Actually, during boot-up, something along the lines of "installing new
> microcode" or "installing new firmware" or something like that scrolls by.
> That always worried me, but I figured it either got reversed at the next
> reboot or it was too late to do anything about it, and it never caused any
> trouble.
CPUs have volatile memory to store microcode updates. If an OS, during
bootup, loads microcode into your CPU and screws things up, reboot and it's
gone.
Many pieces of hardware have a similar thing for firmware, except that it's
not for "updating". If the device driver doesn't load the firmware into the
device, then it won't work at all, or it will lack features.
In any case, it's volatile memory (that's why it's being done on boot).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
