POV-Ray : Newsgroups : povray.off-topic : Largest POV image? Server Time
16 Mar 2026 17:44:14 EDT (-0400)
  Largest POV image? (Message 51 to 56 of 56)
Subject: Re: Largest POV image?
Date: 24 Oct 2009 21:55:00
Message: <web.4ae3afac3743c5293d6448520@news.povray.org>
"TC" <do-not-reply@i-do get-enough-spam-already-2498.com> wrote:
> Hi, there!
> I wonder how large a povray rendered image can be?
> While 1280x1024 fits on an A4-page nicely at 150 dpi, what about renders at
> higher resolutions? What are the limits?
> What is the largest image you have rendered and how long did it take?
I think it was 24000x16000 , can't remember how long it took, though. But
possibly no longer than 30 hours. I have rendered 20000x15000 images quite a few
times (rendertime between 8 and about 25 hours, I think). I do not need them
exactly in that size, but sometimes I only need a part of the image (because
there is much free space around the objects which renders fast of course) and I
sometimes don't know how to put the camera so that it's zoomed in while
maintaining the exactly same perspective. So I cut a part off the image of
later. Another reason for the big images is, that sometimes the antialiazing is
not good enough, so I resize it to a smaller size with a graphics program after
rendering which is much quicker and IMHO even looks better than using a better
antialiasing and time consuming AA setting in POV.
When I use some focal blur I always render the image 2-3 times bigger than I
need with low quality settings, and then downsize it later, because the focal
blur gets more smudged and realistic, I think.
I wouldn't render images in such size with any media or such, because that takes
so long even for small images.
I always have to switch display=off when the image size is more than about
12000x9000 because of the lack of RAM.
I have not much experience with radiosity. If I recollect it correctly the
calculated values are somehow attached to the object and can be stored in a
file? So it possibly doesn't matter much when the image size is increased with
radiosity? Maybe the experts can say more about this :).
When estimating the total render time it also helps me a lot to render some
sample regions (with this "render region" option) both with many objects and
less, and then dividing the final (planned) resolution by the average pps and
again by 3600 which then gives the supposed total render time in hours.
Simone
Date: 25 Oct 2009 08:29:29
Message: <4ae444a9@news.povray.org>
In a perfect world, all radiosity samples you ever need would be
gathered during radiosity pretrace, which is basically independent of
screen resolution.
In practice, most people don't set the radiosity parameters high enough
to have pretrace do a good enough job; in that case, a high-res image
may add more samples during final trace than a low-res image.
OTOH, even the number of additional samples during final trace just
grows linearly with the number of pixels.
Another effect that needs to be considered is radiosity sample lookup
during the final render; in an ideal world the time spent on this would
increase roughly linearly with number of pixels; however, due to a
high-res image usually generating more radiosity samples in total, the
per-pixel time spent on looking up radiosity samples will increase, so
the total time spent on sample lookup will increase nonlinearly.
All in all, however, I guess time required for radiosity will increase
sub-linearly with number of pixels in practice, due to pretrace time
remaining basically unchanged (unless you change radiosity parameters).
Date: 25 Oct 2009 14:25:01
Message: <web.4ae496f63743c529f6380b330@news.povray.org>
> screen resolution.
I see. So as a rule of thumb it would be good to use the save_file/load_file
options together with high quality parameters for a low-res image, so the
sampled data can be used again for the high-res image?
Simone
Date: 25 Oct 2009 15:10:24
Message: <4ae4a2a0$1@news.povray.org>
That depends.
Just rendering the scene at low resolution with save_file, and then
rendering it at high resolution with load_file, will give you not much
of an advantage; to the contrary: You'll just force POV-Ray to run the
main render twice (though at low resolution the first time).
It only pays off in case you can somehow manage to simplify the scene in
a manner that does not affect radiosity calculation much; good
candidates for this would be minor media  effects, micronormals for
slightly blurred reflections, or low-res versions of textures. (Make
sure not to change any actual geometry though.) In that case it's worth
running the radiosity pretrace with this simplified scene, with low
resolution to not waste much time on the not-really-main render; for the
final render, you can then get away with a single, very coarse pretrace
(IIRC POV-Ray always does at least one pretrace pass, even if you load
previously generated data).
(Note that with POV-Ray 3.7, the syntax for saving and loading radiosity
data has changed.)
Date: 25 Oct 2009 17:05:00
Message: <web.4ae4bd5e3743c529f6380b330@news.povray.org>
Ok, Thanks. I hopefully have understood most of it :). I'll keep this in mind
next time when I want to render a high-res radiosity scene.
Simone
Date: 26 Oct 2009 03:34:34
Message: <4ae5510a@news.povray.org>
It seems to me like once you try to render at 27000x27000 or above with the
preview, the POV core crashes and then the preview window shows
"StretchDIBits() failed!" instead of any image.  POV is then crashed and you
have use task manager to kill it.
