POV-Ray : Newsgroups : povray.off-topic : 4D Server Time
14 Oct 2026 22:07:44 EDT (-0400)
  4D (Message 35 to 64 of 64)
<<< Previous 34 Messages Goto Initial 50 Messages
Subject: Re: 4D
Date: 21 Oct 2009 09:44:57
Message: <4adf1059$1@news.povray.org>
ANd nobody knows if we were or not 2D beings.
Subject: Re: 4D
Date: 21 Oct 2009 11:06:04
Message: <4adf235c$1@news.povray.org>
Invisible wrote:
> These are two seperate, unrelated geometries.
> 4D Euclidian space is interesting because it's a straight extension of
> 3D Euclidian geometry.
I should read more about this, sounds interesting.
> Somewhat weirder is hyperbolic geometry, where multiple "straight lines"
> through a single point do not intersect each other [except at that
> point]. You really need to play with this:
> http://cs.unm.edu/~joel/NonEuclid/NonEuclid.html
I'll check it out.
I've been trying to figure out how to calculate hyperbolic geometry, so
I may create new "circle limit" Poincare disk tesselations. I figure it
must be possible to create such a thing with POV-Ray functions, but so
far all my attempts have been total failures :(
Subject: Re: 4D
Date: 21 Oct 2009 11:15:28
Message: <4adf2590$1@news.povray.org>
3D Euclidian space = the place where we (apparently) live.
4D Euclidian space = the place where objects such as the hypercube live.
4D non-Euclidian space = any space with 4 dimensions that *isn't* 4D
Euclidian space. This includes a system where time is the 4th dimension,
but also many other kinds of space as well.
>> lines" through a single point do not intersect each other [except at
>> that point]. You really need to play with this:
> I'll check it out.
I believe you can use ordinary 2D coordinates for hyperbolic space, you
just need to remap them when plotting them in normal 2D space.
(Unfortunately, I can't find any formulas for doing this.)
Note that there is more than one way to project hyperbolic space into
Euclidian space; you probably want the Poincaré disk model if you're
trying to copy Escher's Circle Limit.
Subject: Re: 4D
Date: 21 Oct 2009 11:40:26
Message: <4adf2b6a$1@news.povray.org>
clipka wrote:
> Well, AFAIK there's actually no fundamental reason to apply different
> "measuring tapes" to time and space:
It's not measured *quite* the same way... The distance between two events is
sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Subject: Re: 4D
Date: 21 Oct 2009 11:41:13
Message: <4adf2b99$1@news.povray.org>
> events is sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Hence "non-Euclidian space".
Subject: Re: 4D
Date: 21 Oct 2009 12:03:25
Message: <4adf30cd$1@news.povray.org>
clipka wrote:
> Kevin Wampler schrieb:
>> It is worth nothing, however, that the time dimension is *not*
>> identical to the space dimensions (one would hope not!) and distances
>> are measured differently in time than in space.
> "measuring tapes" to time and space: The constant vacuum speed of light
> can serve as a ruler for both, with the distance of a light second
> equating a second.
> It just happens that it's still more practical to use meters for
> space-like dimensions and seconds for time-like dimensions.
I think that this becomes problematic for measuring between points which
aren't connectible by a lightlike geodesic, but maybe there's some
clever way around that (although I don't see how).
In any case, I was referring to the fact that under special relativity
spacetime has a metric that differs from that of a 4D Euclidian space
along the dimension corresponding to time.  For instance, the length of
a vector can be negative, which is impossible under a Euclidean metric.
Subject: Re: 4D
Date: 21 Oct 2009 12:03:50
Message: <4adf30e6$1@news.povray.org>
Yes. I wasn't sure if that counted as a euclidian space or not. :-)
Subject: Re: 4D
Date: 21 Oct 2009 12:08:21
Message: <4adf31f5@news.povray.org>
It doesn't, but it does share the property that the metric tensor is
constant over the entire space.
Subject: Re: 4D
Date: 21 Oct 2009 12:57:41
Message: <4adf3d85$1@news.povray.org>
It /is/ measured in the same way - it's just that the Pythagorean
theorem doesn't hold in our peculiar (3+1)D universe...
Subject: Re: 4D
Date: 21 Oct 2009 13:01:06
Message: <4adf3e52$1@news.povray.org>
Well, if two points cannot be reached from one another - is there /any/
way to assign a distance to these points at all?
So I think this is a non-issue.
Subject: Re: 4D
Date: 21 Oct 2009 13:16:35
Message: <4adf41f3$1@news.povray.org>
>> which aren't connectible by a lightlike geodesic, but maybe there's
>> some clever way around that (although I don't see how).
In this context a lightlike geodesic refers to a path in spacetime which
  light would follow, and I meant to imply that defining the distance
between points which could only be connected by going *slower* than
light would also be hard to define uniformly.
Subject: Re: 4D
Date: 21 Oct 2009 13:27:00
Message: <4adf4464$1@news.povray.org>
I fail to see how stating that the Pythagorean theorem doesn't hold
isn't just another way of saying that distances are measured differently
in our spacetime?
Is you point that in space time there *is* a well-defined notion of
distance which unifies both the spatial and temporal aspects, and thus
we don't really need to use one set of units for space and another set
for time?  Your comment about light-seconds would make more sense in
this context.  If this is the case perhaps I've been misunderstanding
your point form the beginning, since I'd surely agree with this.
Subject: Re: 4D
Date: 21 Oct 2009 13:36:51
Message: <4adf46b3$1@news.povray.org>
>> /any/ way to assign a distance to these points at all?
In light of one of your other comments I think I now understand what
point you're making: we can treat space-time distances in a common set
of units by treating distances as times via the speed of light.  In
which case I'd agree, and it fact the necessity for this clearly falls
out of being able to have a single number represent the distance at all.
I still don't see how it's relevant for my initial comment that the
space and time coordinates are treated differently though, since they
are most definitely factor into the distance function in different ways.
  Stated another way, swapping the time axis with a space axis is *not*
in the symmetries of Minkowski spacetime, but swapping any of the space
axes *is*, and this there's something "different" about the time axis.
Otherwise why bother saying (3+1)D instead of just 4D?
Subject: Re: 4D
Date: 21 Oct 2009 14:00:42
Message: <4adf4c4a@news.povray.org>
http://blog.orphi.me.uk/
Download 'brain.jpg' (47 KB)
Preview of image 'brain.jpg'
Subject: Re: 4D
Date: 21 Oct 2009 15:24:15
Message: <4adf5fdf$1@news.povray.org>
>  my head asplode
It was just a fancy way of saying that there's a sense in which the
spacetime isn't "curved"; which I probably should have just said in the
first place since the way I phrased it should really be made more
precise to be accurate anyway.
Subject: Re: 4D
Date: 21 Oct 2009 16:23:25
Message: <4ADF6DBC.8060007@hotmail.com>
On 20-10-2009 12:41, Invisible wrote:
> Saul Luizaga wrote:
>> I don't know if some day would be possible but would be great to visit
>> a 4D world and meet 4D people :-D
> I should point out that a rotation in 4D can leave your body in mirror
> image. If you go to 4D-land, turn around the "wrong" way, and then come
> back, your body will be inverted.
> Why would you care? Well... certain biological molecules are chiral,
> so... good luck assimilating your food. :-P
Book reference: 'Doorways in the sand' Roger Zelazny
Subject: Re: 4D
Date: 21 Oct 2009 16:32:52
Message: <4ADF6FF3.3080606@hotmail.com>
Yes there is, but you have to keep in mind that the points here are 4
dimensional points. i.e we are talking about two events that take place
in two places that happen closer in time than the light needs to go from
one place to the other.
Subject: Re: 4D
Date: 21 Oct 2009 21:48:24
Message: <4adfb9e8@news.povray.org>
"Saul Luizaga" <sau### [at] netscapenet> wrote in message
news:4adf1059$1@news.povray.org...
How do you know that?
Subject: Re: 4D
Date: 21 Oct 2009 23:22:38
Message: <4adfcffe@news.povray.org>
nobody has ever proved it.
Subject: Re: 4D
Date: 22 Oct 2009 02:28:43
Message: <4adffb9b@news.povray.org>
news:4adfcffe@news.povray.org...
Subject: Re: 4D
Date: 22 Oct 2009 03:45:56
Message: <4ae00db4@news.povray.org>
>>>> different "measuring tapes" to time and space:
Well, yes, I guess that's one way to express what I said: We don't need
different "measuring tapes" for time and space. How distance is measured
"diagonally" in spacetime is another story.
Subject: Re: 4D
Date: 22 Oct 2009 04:05:28
Message: <4ae01248$1@news.povray.org>
Maybe you'd first need to define "point": Are you talking about a point
in 3D space which extends along time - i.e. a line in 4D space - or an
actual 4D point that only exists at a certain time T?
In the former case, this is actually a non-issue: Either you can find
(true) points on that line that /can/ be reached at /exactly/ light
speed, or you cannot reach that other line at all.
In the latter case, you can define the spacelike distance between the
points as the minimum difference between the spacelike component of two
intersecting lightlike geodesics running through each of the points
respectively.
Or, to eliminate the problem of "far-away" spacetime being curved, you
can have a look at all possible sequences of points that can be
connected with lightlike geodesics, compute the vector sum of the
spacelike components, and define the spacelike distance as the minimum
length of any such vector sum.
In the end it will boil down to defining the spacelike distance as the
length of the spacelike component of the shortest "direct" geodesic
between the points.
(Note that of course this leaves the definition of distance subject to
your frame of reference, as it defines the orientation of the spacelike
components of spacetime, but that's a known effect in relativistic physics.)
Subject: Re: 4D
Date: 22 Oct 2009 04:12:40
Message: <4ae013f8@news.povray.org>
Yes...
Well, your original statememt was that "distances are measured
differently in time than in space", not "distances are computed
differently in spacetime than in space", so I took this as talking about
"measuring tapes", not the math to combine space and time components of
distance into spacetime distance.
Subject: Re: 4D
Date: 22 Oct 2009 04:14:00
Message: <4ae01448$1@news.povray.org>
"Can you hear me, bomb?" :-)
Subject: Re: 4D
Date: 22 Oct 2009 04:53:31
Message: <4ae01d8b$1@news.povray.org>
Oh you really think that 2D only beings discovery might have gone
unnoticed? I don't think so, I think is perfectly safe to say that if
that kind of world exist it has not been discovered, or do you know
otherwise?
I think your question is pointless, anyone would had pointed out that
the 2D beings actually do exist, such a news would be common knowledge
by now. Otherwise people wouldn't be wondering:
http://www.unexplained-mysteries.com/forum/index.php?showtopic=163191
http://www.physicsforums.com/archive/index.php/t-185785.html
http://teamikaria.com/4dforum/viewtopic.php?f=5&t=1103
How do I know that? looks like you are the only one that it doesn't.
Subject: Re: 4D
Date: 22 Oct 2009 06:03:58
Message: <4ae02e0e$1@news.povray.org>
news:4ae01d8b$1@news.povray.org...
> unnoticed?
No, but that's not what you said. You said "ANd nobody knows if we were or
not 2D beings." Well, if lack of disclosure of discovery is proof (faulty
reasoning), well, everybody knows that we were not 2D beings (probably a
correct statement, at least more sensible than its negative).
Subject: Re: 4D
Date: 22 Oct 2009 16:45:08
Message: <4ae0c454$1@news.povray.org>
In all cases I'm referring to a point as a 4D point in spacetime since
there's no intrinsically unique way to extend a 3D point along time.
> physics.)
If you fix a reference frame there's certainly plenty you can do to
define spacetime distances in a consistent way.  If you want to
consistently measure distances independent of the reference frame, then
you're pretty much stuck with what the Minkowski metric tells you.  Of
course this metric gives you a single value for the distance (not
independent time and space distances) and thus can't really be used to
measure pure-spatial distances.
Not that this is necessarily inconsistent with what you said, I just
thought I'd point out (in case you weren't already fully aware) that if
you're going to measure spacetime distances independent of the reference
frame then the way to do it is to use the Minkowski distance and forget
about trying to determine what the "spatial" distance is at all.
Subject: Re: 4D
Date: 22 Oct 2009 18:40:42
Message: <4ae0df6a$1@news.povray.org>
>> unnoticed?
> reasoning),
I deed, because in all fairness we don't know this for sure, I stand
correct.
sensible? I don't think so since it has the same exact meaning.
Subject: Re: 4D
Date: 22 Oct 2009 21:50:11
Message: <4ae10bd3@news.povray.org>
news:4ae0df6a$1@news.povray.org...
If a statement and its negative have the exact same meaning, they are both
nonsense :P. But, I'll compromise: I'm pretty sure many, many more people
know that we were not 2D beings than those who know that we were (whatever
either statement means).
Subject: Re: 4D
Date: 23 Oct 2009 01:52:28
Message: <4ae1449c$1@news.povray.org>
Yeah this is more proper, thanks for understanding, but anyway not
necessarily true.
