POV-Ray : Newsgroups : povray.off-topic : Inspect DLL Server Time
18 Jul 2026 12:13:08 EDT (-0400)
  Inspect DLL (Message 32 to 41 of 61)
Subject: Re: Inspect DLL
Date: 12 Oct 2009 15:46:57
Message: <4ad387b1$1@news.povray.org>
> That looks like a COM Dll... See if there's a .tlb file somewhere, or if
> there's a type library embedded. Use oleview.exe:
http://www.microsoft.com/DownLoads/details.aspx?FamilyID=5233b70d-d9b2-4cb5-aeb6-45664be858b6&displaylang=en
Ooo... shiny.
http://blog.orphi.me.uk/
Date: 12 Oct 2009 15:54:34
Message: <4ad3897a@news.povray.org>
On 10/12/2009 6:13 AM, Le_Forgeron wrote:
> Worse, How do you find which DLL are needed by a DLL ?
> There is a "dependancy walker" (from  steve P. Miller) but that might
> not provide the argument list.
It won't. If you're lucky, the DLL will have C++ mangled names. That
will give you the types of parameters, provided you can decode the name
mangling. Good luck with that.
You'll notice some C functions often have an @ followed by a number.
IIRC, that's the number of bytes that should be on the stack when the
function is called. But, that's about as informative as it gets. No
names for the parameters, especially no description of what they do.
You're playing blind. Better be good at reading assembly to find out how
the parameters are being used. ;)
~Mike
Date: 12 Oct 2009 16:00:13
Message: <4ad38acd$1@news.povray.org>
Orchid XP v8 wrote:
> Nice of them to include the link to part 2. :-P
I have noticed that virtually nobody actually goes back and fixes earlier
blog links to link to subsequent parts.
Date: 12 Oct 2009 16:13:59
Message: <4ad38e07$1@news.povray.org>
Invisible wrote:
> OK, so here's a question: I think I understand how to load a DLL and
> call the functions it exports, but... how do you find out what functions
> a DLL exports?
> I mean, one way would be to find some documentation. But if you don't
> have any... is there some way to inspect the symbol list somehow? Can
> you get an argument list? How about type information?
Depends. Are we talking a COM supporting one? There are three flavors of
dll, one has internal entry points that you need a linking table to get
at. I.e., there is no stored internal data on what is there. Full COM
supporting ones (one ones using any such variation on the concept)
include an internal table and some standard method of "asking" what all
the calls, variables, types, etc. are. The third is a kind of hybred,
where "some" of the internals are exposed via the interface, but others
have been intentionally designed to only allow linking using the
header/table used to inform a compiler what they are.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 12 Oct 2009 16:19:53
Message: <4ad38f69$1@news.povray.org>
Orchid XP v8 wrote:
>>> ...see a pattern yet?
>> Yes. It means Sun is too stupid to even know what a "GUID" is.
> This was my conclusion also.
> Surely the correct behaviour would be to register a single interface and
> give it a "do you support this API version?" method...
>>> Next time you install some program and it says "registering
>>> components" or "writing registry keys", this is what it's doing. It's
>>> registering millions of COM ClassIDs!
>> Yes.
> Heh. I lost count of how many Office-related DLLs are in there. There's,
> like, A LOT!
You sure you don't have "older" versions still installed too? When you
update the JRE it tends to leave prior versions, as a "just in case your
program requires some bug that was only in 1.3.0_03, but got fixed
later. I had to go back and manual uninstall like 4-5 of these, to free
up space on my HD. I stupidly installed them in C:, and didn't realize
at the time that the small size of that was going to produce bad
results, or that Sun didn't "replace" the install, instead of just
installing a new one.
Still, you get a bit of some of that with MS too, just not as much. In
principle, the version isn't relevant, only if the function is there,
and yes, if you do need a version, the sane solution is to ask if there
is an interface that is backward compatible to it in there some place.
void main () {
   If Schrödingers_cat is alive or version > 98 {
   else
Date: 12 Oct 2009 16:26:27
Message: <4ad390f3@news.povray.org>
Yes. I disabled autoupdates. Where I work, I have to document exactly
which version of the JRE I'm running. ;-)
Date: 12 Oct 2009 16:28:35
Message: <4ad39173$1@news.povray.org>
> earlier blog links to link to subsequent parts.
Indeed, part 2 links to part 1, but not the other way around...
Date: 12 Oct 2009 16:29:55
Message: <4ad391c3$1@news.povray.org>
The situation is far more complex than I imagined.
Apparently it is notionally possible to construct a DLL which actually
contains no executable code at all, only data. (Although I highly doubt
anybody *does* this...)
Man, the more you look, the more complex it gets! :-}
Date: 12 Oct 2009 16:50:34
Message: <4ad3969a$1@news.povray.org>
My head hurts from reading about the wild zoo of possibilities here.
Damn, I wonder if I'll ever actually figure this stuff out? :-/
Date: 12 Oct 2009 18:18:37
Message: <4ad3ab3d$1@news.povray.org>
Darren New schrieb:
> Not necessarily. But I'm pretty sure you're not going to get good
> "globally unique identifiers" by manually including english words in them.
Well, if you /know/ you're the /only/ one stupid enough to do that... :-P
