POV-Ray : Newsgroups : povray.off-topic : Why I don't do design Server Time
22 Jul 2026 09:16:51 EDT (-0400)
  Why I don't do design (Message 11 to 20 of 37)
Subject: Re: Why I don't do design
Date: 12 Oct 2009 04:25:23
Message: <4ad2e7f3@news.povray.org>
> Isn't that just nausiating to look at?
> (Yes, it's Saturday Night, and I'm playing with SketchUp while listening
> to Jesus on Es.)
Hehe, this is on level with someone using Paint to draw a reflective sphere
over a checkered plane, and ending up with a red circle over a green
rectangle :-)
Date: 12 Oct 2009 04:28:07
Message: <4ad2e897$1@news.povray.org>
> sphere over a checkered plane, and ending up with a red circle over a
> green rectangle :-)
Why thank you. I feel much better now. :-P
Meh, the tutorial videos feature all kinds of intricate models, and
YouTube has a few people drawing highly complex stuff, but I don't see
how it's possible...
Date: 12 Oct 2009 04:48:00
Message: <4ad2ed40@news.povray.org>
Don't feel bad, you're using totally the wrong tool to try and do something
like you attempted.  There's a reason why Nokia don't use SketchUp to design
their phones :-)
> YouTube has a few people drawing highly complex stuff, but I don't see how
> it's possible...
Apart from showing off, I never understood people using a tool for something
it really isn't designed for.  If you really want to design stuff like that
phone with nice smooth surfaces then put the effort in to learning something
like Blender rather than SketchUp.
Date: 12 Oct 2009 04:54:29
Message: <4ad2eec5$1@news.povray.org>
> something like you attempted.  There's a reason why Nokia don't use
> SketchUp to design their phones :-)
> something it really isn't designed for.  If you really want to design
> stuff like that phone with nice smooth surfaces then put the effort in
> to learning something like Blender rather than SketchUp.
I wonder - is there anything that SketchUp *is* the right tool for?
Every single time I mention it, everybody says I should use Blender
instead...
Date: 12 Oct 2009 05:13:57
Message: <4ad2f355$1@news.povray.org>
> I wonder - is there anything that SketchUp *is* the right tool for? Every
> single time I mention it, everybody says I should use Blender instead...
AIUI (I only tried it once ages ago when it first came out) it is meant for
quickly designing simple, straight-lined 3D objects.  Like simplified
versions of buildings that mostly consist of cuboids or angled parts.
Wasn't it originally released to allow people to add 3D versions of
buildings to Google Earth?
Date: 12 Oct 2009 05:16:20
Message: <4ad2f3e4$1@news.povray.org>
>> instead...
> for quickly designing simple, straight-lined 3D objects.  Like
> simplified versions of buildings that mostly consist of cuboids or
> angled parts. Wasn't it originally released to allow people to add 3D
> versions of buildings to Google Earth?
Indeed, there's a big 3-part tutorial showing somebody importing a plan
from a CAD program, tracing the walls, and cutting all the doors and
windows. The result is pretty impressive, actually...
My own attempts to do something similar are far less convincing.
Date: 12 Oct 2009 07:56:01
Message: <4ad31951@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:4ad228ec$1@news.povray.org...
> All it seems to say is that there should be a "min" in there. What do you
> actually want to change in the formula?
Exactly ...
> I notice the brackets around the fraction aren't tall enough to enclose it
> properly. You can fix it like so:
>   ( \frac{...}{...} )
> becomes
>   \left( \frac{...}{...} \right)
OK ... this was helpful ... thanks
> I should perhaps also point out that, technically, when TeX sees
> <math>cat</math>, it interprets it as "c * a * t", which probably isn't
> what you want. Use <math>\text{\it cat}</math> instead. (There's a subtle
> difference in the letter spacing - and also the typeface is slightly
> different.)
The \it tag (italics?) was causing me grief. It gave a lexing error ...
failed to parse. With the \text tag alone I get normal typeface, without it
I get the italics typeface. it doesn't seem to be behaving as you suggest.
Here's what it looks like now:
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_4
I think it looks like what Mike was getting at ... correct?
Jim
Date: 12 Oct 2009 08:09:28
Message: <4ad31c78$1@news.povray.org>
>>   ( \frac{...}{...} )
>> becomes
> OK ... this was helpful ... thanks.
Works with any delimiter, by the way:
   \left[ ... \right]
   \left| ... \right|
etc.
If you wanted to be flashy, you could replace min(...) with those funny
bent-angle brackets - but I don't suppose anybody except a mathematician
would understand what the hell that means, so leave it.
>> different.)
It's quite possible the Wiki doesn't support arbitrary TeX markup, but
only supports a specific subset of commands. You could try
\text{\emph{distance}} or something. That should typeset it in text
italics, which is subtly different from math italics (especially
spacing). The AMS-LaTeX \text{} command also adjusts the spacing subtly.
I will admit that all of this makes a fairly subtle difference to the
final output though.
Change "min" to "\min" to have it typeset correctly. (I.e., in Roman
type, like all function names. It might even fix the spacing on the
brackets following...)
The spacing of the superscripts looks slightly odd, but I couldn't tell
you why...
Date: 12 Oct 2009 08:42:36
Message: <4ad3243c@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4ad31c78$1@news.povray.org...
>   \left[ ... \right]
>   \left| ... \right|
another nugget ... thanks
you are probably correct ...
> You could try \text{\emph{distance}} or something. That should typeset it
> in text italics, which is subtly different from math italics
no joy with this markup either ....
> Change "min" to "\min" to have it typeset correctly. (I.e., in Roman type,
> like all function names. It might even fix the spacing on the brackets
> following...)
worked ... thanks for the assist!
Date: 12 Oct 2009 08:50:13
Message: <4ad32605@news.povray.org>
>>   \left[ ... \right]
>>   \left| ... \right|
This method makes the brackets just big enough to contain the interior
text. You can also set the bracket size manually (e.g., if you want the
outer brackets big and the nested brackets smaller, to aid visibility),
but we won't worry about that. In this specific case, the brackets come
out reasonable sizes, so no need to fiddle.
You can also do stuff like this:
             | -1  if x < 0
   sign x = <   0   if x = 0
             |  1   if x > 0
Use "\left\{" to get the stretched symbol (you have to balance it with
"\right."), and then use an array environment to typeset the multiple rows.
I don't suppose for 13ms that there's any *documentation* for what the
wiki actually supports though...
Really? That's odd. Well, I guess the difference is quite small.
>> following...)
In general, any function name (sin, cos, tan, min, max, lim, etc.) wants
to be handled this way (\sin, \cos, etc.)
Now, in LaTeX there's a way to define new function names - but you have
to write the declaration in the document preamble. Not sure if you can
access this particular feature from the wiki...
Any further questions? :-D
