POV-Ray : Newsgroups : povray.off-topic : A fatal mistake Server Time
1 Apr 2026 16:14:48 EDT (-0400)
  A fatal mistake (Message 21 to 30 of 45)
Subject: Re: A fatal mistake
Date: 4 Oct 2009 14:26:25
Message: <4AC8E8CF.7050408@hotmail.com>
On 4-10-2009 19:12, Orchid XP v8 wrote:
>>> In seriousness for a moment... Do you have ANY FRICKIN IDEA how long
>>> this took to do?!
>> Lets see, a pipe is a hollow cone plus a cylinder (2 minutes) add some
>> csg for the red part (another five minutes). Debugging the loop and
>> passing of parameters (+5) adding a wooden box (1 +6 for selecting the
>> right texture), getting the viewpoint right (3 minutes).
>> adding up... something under 15 minutes I would guess. Am I close?
> Have you *tried* doing CSG with SketchUp? You don't just say "please
> intersect these two things".
> First it takes about 10 minutes to try to persuade it to position the
> items where you actually ****ing want them. Then you say "intersect",
> and all it does is alter the polygon mesh slightly. YOU must then,
> manually, delete the faces you don't want any more. One at a time. You
> see, any curved surface becomes 25,000 polygons, which you must delete
> individually, one at a time.
> Just to make things better, I got my CSG slightly wrong anyway, and it
> took longer to fix it.
> So, now you have one pipe. But I want 23 pipes. So, first select the
> pipe and ask SketchUp to make 12 copies of it. (Fortunately, there *is*
> an automatic way to do this!) Now select 11 of those copies, and make
> them all 5% smaller. Select 10 copies, make them all 5% smaller. Select
> 9 copies. Make them all 5% smaller. (Are you bored yet?) Eventually, you
> have 12 pipes, all different sizes. Now the fun part. Copy them,
> reposition the copy. Mirror it. (Do NOT rotate it as I mistakenly did!)
> Spent 20 minutes trying to make it line up properly with the existing
> pipes.
> And, yes, stick them in a box, which takes about 45 seconds.
> I can't help but feel that POV-Ray could have done this radically
> faster. And the pipes would be *real* cylinders, not 24-gon prisms. And
> they would be *shiny*!
YOu missed the point, which is simply: you are using the wrong tool for
this project. If it is to learn sketchup it is OK. If you want to create
an image, you should reconsider.
Date: 5 Oct 2009 00:55:00
Message: <web.4ac97b2c122d4517cac4259f0@news.povray.org>
I haven't played with Sketchup.  What's it good at?
Charles
Date: 5 Oct 2009 02:43:12
Message: <4ac99580$1@news.povray.org>
> Now, sure, if your window is rectangular, the push/pull tool makes it easy
> enough to continue. But what if you made a *circular* window? Or some even
> more complex shape?...
...you need to get a proper 3D CAD program? :-)
Can you not edit the vertex positions of the hole?  I would say in Blender
just select the vertices or edges of the hole and then translate/scale
them - I can't believe the same isn't possible in even a very basic 3D tool.
Date: 5 Oct 2009 04:56:24
Message: <4ac9b4b8$1@news.povray.org>
>> easy enough to continue. But what if you made a *circular* window? Or
>> some even more complex shape?...
Yeah, figures.
Although, as I said, I've used a lot of 3D editors, and SketchUp is at
least the first one good enough to make nontrivial objects with. I
suppose that's something. (It *really* annoys me that it can't do real
curves though...)
> Blender just select the vertices or edges of the hole and then
> translate/scale them - I can't believe the same isn't possible in even a
> very basic 3D tool.
Oh, you *can* move the individual points or edges around if you like.
But if your surface is particularly complicated, this becomes
intractably difficult extremely fast. Nowhere near as easy as just
moving the shape around before you make the cut.
Date: 5 Oct 2009 04:58:47
Message: <4ac9b547@news.povray.org>
Quickly throwing together moderately complex 3D objects. Particularly
ones with lots of straight lines. (E.g., buildings, machinery, tools, etc.)
There's a bunch of tutorial videos on Google's website. For example, in
one a guy spends 10 minutes tracing a (very complicated) CAD drawing of
a building interior. Trace it in 2D, extrude into 3D, cut out a few
rectangular doors and windows, in about 30 minutes total you have a true
3D model of the main parts of this house...
It's great fun, but frustratingly hard to do certain things.
Date: 5 Oct 2009 04:59:53
Message: <4ac9b589$1@news.povray.org>
>> Sketckup is a lot of fun,
> Can it export stuff POV-Ray can use?
It can export data as some kind of XML format. (Apparently it's an open
standard - I don't know how well documented!) If you wrote a converter,
then... supposably.
Date: 5 Oct 2009 05:01:02
Message: <4ac9b5ce$1@news.povray.org>
>> welcome to 3D visual modelling! :D
> *That* is what I want Minority Report gloves for! :-)
Ah, Minority Report. How often does a film come along that makes
everybody want a particular fictional technology?
Date: 5 Oct 2009 05:29:19
Message: <4ac9bc6f$1@news.povray.org>
> Yeah, figures.
Most CAD programs I've used store a tree of features/actions used to get to
the final shape, this means you can go back and edit any of those previous
steps.  In your example the shape you drew to make the hole is stored
exactly as that in the file, then of course you can edit it and see the
result.  I saw partly this kind of behaviour in 3D Studio Max (or whatever
it's called now), in that you could keep two separate objects and see the
intersection of them, but most mesh editors just store the mesh and no extra
data.
Date: 5 Oct 2009 05:38:11
Message: <4ac9be83$1@news.povray.org>
> to the final shape, this means you can go back and edit any of those
> previous steps.
That sounds like a more logical way to work.
Presumably CAD also allows you to do things like "find a point 3/5 along
the length of this edge". SketchUp automatically marks the 1/2 point for
you, but for any other point you've got to get out a calculator.
Other annoying SketchUp features include the lack of the ability to
manipulate a circle be its center. (Because, of course, once you've
created it, it's not a circle any more. It's 24 unrelated edges.) And
the best feature of all is the way surfaces "stick" to each other as
soon as they touch...
> (or whatever it's called now), in that you could keep two separate
> objects and see the intersection of them, but most mesh editors just
> store the mesh and no extra data.
Yeah. How SketchUp does intersection is that you line up the two
objects, press "intersect", and then delete the geometry you don't want.
Manually. Which, for curved surfaces, takes a really long time.
(Because, naturally, those surfaces aren't really curved. Stupid
idea...) Also, you can't delete any item smaller than a certain size on
screen. You have to zoom in first. And the minimum size is significantly
larger than you'd expect.
Date: 5 Oct 2009 06:38:28
Message: <4ac9cca4@news.povray.org>
AFAIK there is not usually any automatic way to do that, you'd just need to
add a formula to one of the point dimensions that says something like
"Edge1.Length * 3/5".  That way, whenever the length of that edge changes,
the point is always fixed 3/5 of the way along.  You could then draw some
geometry referenced to that point, then of course that would all move with
the point too.  It gets a bit like POV, where you can just define a variable
for something like "screw position", and then drive lots of other features
like holes and cut-outs in lots of parts from that one variable.  The
benefit of this is when your customer says "ok we need that screw moved
1.2mm" it only takes you a few seconds to update all your parts rather than
an hour or two.
> the best feature of all is the way surfaces "stick" to each other as soon
> as they touch...
> Also, you can't delete any item smaller than a certain size on screen. You
> have to zoom in first. And the minimum size is significantly larger than
> you'd expect.
I would expect there would be settings for these sorts of things?
