POV-Ray : Newsgroups : povray.off-topic : Linux directory usage question Server Time
17 Mar 2026 01:11:28 EDT (-0400)
  Linux directory usage question (Message 21 to 26 of 26)
Subject: Re: ADS on NTFS and reported HDD usage
Date: 18 Sep 2009 07:47:03
Message: <4ab37337$1@news.povray.org>
TC wrote:
> Since some of you asked what I did not like about ADS on NTFS, here it is:
> There is no easy way to access ADS in Windows Explorer. The only way to do
> it is use API-calls to access the ADS (to my best knowledge).
In fact, you don't need any special API calls. There is a filename
syntax for accessing alternate streams. For example:
C:\> echo This is a test > Test.txt
C:\> echo This is another test > Test.txt:alt
Congratulations, you just greated a file with an ADS named "alt".
I will admit, however, that most programs don't know about this
"feature" and will complain if you try to use it. (E.g. both the TYPE
command and Notepad complain that no such file exists.)
> And most importantly, if you store data in ADS, it is nowhere reported in
> Windows Explorer.
This appears to be true. Even the "size on disk" field doesn't appear to
change when adding and removing ADS, with is rather anomolous.
Still, most ADS are so tiny it probably doesn't matter too much.
Date: 18 Sep 2009 08:34:38
Message: <4ab37e5e$1@news.povray.org>
So what you're basically saying is you don't hate ADS - you hate Windows
Explorer's poor (or actually nonexistent) support for it.
Date: 18 Sep 2009 12:08:16
Message: <4ab3b070$1@news.povray.org>
You can open any stream by name. It's
C:\Users\Darren\Desktop>echo hello >hello.txt
C:\Users\Darren\Desktop>echo goodbye >hello.txt:goodbye.txt
C:\Users\Darren\Desktop>type hello.txt
hello
C:\Users\Darren\Desktop>more < hello.txt:goodbye.txt
goodbye
Some programs try to parse the file name, but < and > don't, so it works fine.
Of course, yes, to get a list of what streams are out there, you need API calls.
> Again to my best knowledge (which is somewhat lacking in the field of file
> systems, admittedly), you have to scan every single directory using
> API-calls to determine which ADS-files are stored on your HDD.
Yes. As is true of Linux's extended attributes and Mac's file forks, too.
> So, if you are in the mood, you could fill a seemingly empty HDD by creating
> a few really huge ADS-files on  it.
Yep.
> Anybody wanting to write to this HDD should be ready for an interesting
> experience...
If you're malicious and don't care if you get caught after the fact, and the
person you're pulling this trick on doesn't know about ADS, then yes, this
can happen.
Now that you know, go download the free program that scans your disk and
finds your ADS's for you, and you don't have to worry any more. :-)
> I hope linux ext2 does not do the same.
I believe ext2 puts an upper limit on how much you can store in ADS.
Something like 64K IIRC.
Date: 18 Sep 2009 14:54:00
Message: <4ab3d748$1@news.povray.org>
Yes, I realize you are completely right ;-)
It is not the fault of ADS that Windows makes it hard for us to know what is
actually stored on the hdd.
I always wonder when the first virus/worms make use of this "feature"... do
you know if anti-vir scanners look for ADS-files with malicious payload?
"clipka" <ano### [at] anonymousorg> schrieb im Newsbeitrag
news:4ab37e5e$1@news.povray.org...
>> is:
Date: 18 Sep 2009 14:59:01
Message: <4ab3d875$1@news.povray.org>
Hi, Darren,
thank you, but I know of this and already have programs which can identify
ADS. Nonetheless, it is no fun scanning a couple of 1.5 TB for possibly
malicious files.
As clipka did make me realize: i really don't care for ADS one way or the
other - it might even be useful - but I hate Windows Explorers complete lack
of support for it.
"Darren New" <dne### [at] sanrrcom> schrieb im Newsbeitrag
news:4ab3b070$1@news.povray.org...
>> do it is use API-calls to access the ADS (to my best knowledge).
> hello
> goodbye
> fine.
> calls.
>> file systems, admittedly), you have to scan every single directory using
>> creating a few really huge ADS-files on  it.
> Yep.
>> experience...
> the person you're pulling this trick on doesn't know about ADS, then yes,
> this can happen.
Date: 18 Sep 2009 15:17:37
Message: <op.u0gvvnfy7bxctx@e6600>
On Fri, 18 Sep 2009 20:54:16 +0200, TC get-enough-spam-already-2498.com>
They already exist.
> do you know if anti-vir scanners look for ADS-files with malicious
> payload?
At least some of them do.
FE
