POV-Ray : Newsgroups : povray.off-topic : You thought 4K graphics demos were impressive? Server Time
24 May 2026 15:24:35 EDT (-0400)
  You thought 4K graphics demos were impressive? (Message 3 to 12 of 42)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: You thought 4K graphics demos were impressive?
Date: 27 Aug 2009 21:00:26
Message: <4a972c2a$1@news.povray.org>
Darren New schrieb:
> http://nanochess.110mb.com/chess3.html
CAUTION:
My virus scanner warns me about some of that page's content! I didn't
check whether it's a true or false alert, but I'd recommend a heightened
attention to potential security issues when visiting that page.
Date: 27 Aug 2009 21:45:00
Message: <web.4a9735bea684af8f4c8f68f10@news.povray.org>
that man is clearly a real programmer. ^_^
also amazing the things he does with javascript, the zooming of the photo...
checked the source? :)
http://nanochess.110mb.com/efectos.js
perhaps he generated it from perl... :P
Date: 28 Aug 2009 00:55:00
Message: <web.4a97630da684af8f958421d50@news.povray.org>
That's pretty amazing.  Did you try it?  How well does it play?  I mean, not
well of course, but is it at least somewhat competent?  I saw a similar program
whose features included occasional suicide and such.  One of those "features,
not bugs" sort of things.
I've played around with these obfuscated things a little, and I was pretty
surprised how much you can fit in a kilobyte or two of c.  Not to toot my own
horn, but I'm not a skilled programmer in the least, and for 1728 bytes, I
managed to get a 3D incompressible fluid simulator with temperature convection
and buoyancy, adjustable size, an X11 display, volume rendering with faked
scattering, and animation output and playback.  Of course it's no chess
program, but the only trick is to do exactly what he did and iterate about five
times, realizing each time the way you should have done it.  It's actually
pretty addicting...  I think the most elegant I ever saw was this:
http://www.ioccc.org/2000/dhyang.c
 - Ricky
Date: 28 Aug 2009 01:04:54
Message: <4a976576$1@news.povray.org>
No.  He says it goes 6 ply on that page, tho.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 28 Aug 2009 02:21:45
Message: <4a977779$1@news.povray.org>
Only looks that elegant at first glance, until you notice that he's
actually kind of cheating: First line defines a single-character empty
preprocessor macro, which he makes quite liberal use of to achieve the
desired formatting of the code.
Date: 28 Aug 2009 02:55:00
Message: <web.4a977f13a684af8f958421d50@news.povray.org>
Did you run it?  If you run it, the output is a different beautifully-formatted
c-code.  If you run that, the output is another formatted c-code.  If you run
that, the output is another formatted c-code.  If you run that, the output is
the first result again.  Basically:
original -> #1
#1 -> #2
#2 -> #3
#3 -> #1
It's probably more mundane than it looks, but at a glance it's pretty slick.
Maybe RLE compression?
 - Ricky
Date: 28 Aug 2009 08:34:34
Message: <4a97ceda@news.povray.org>
> original -> #1
> #1 -> #2
> #2 -> #3
> #3 -> #1
  It's one of the best self-replicating programs I have ever seen.
  Most self-replicating programs just replicate themselves, and that's it.
No ascii art either.
  This program, however, prints a different program, which prints a third
program, which prints the original program. And all these programs use
ascii art formatting. That's some self-replication there.
  It's just incredible how he could store the *shapes* of all four programs
inside a single self-replicating program.
Date: 28 Aug 2009 12:31:21
Message: <4a980659$1@news.povray.org>
FWIW, this is called a "quine", after the philosopher Quine.
http://en.wikipedia.org/wiki/Quine
Date: 28 Aug 2009 12:46:24
Message: <4a9809e0@news.povray.org>
  I wonder what a quine in haskell would look like.
Date: 28 Aug 2009 13:10:00
Message: <web.4a980e6ca684af8f958421d50@news.povray.org>
I don't know exactly how he did it, but if I had to do it, I would use 1/3 of
the junk at the beginning to define each image (It actually looks like he's
divided them in half).  I would RLE compress the image and add or subtract a
constant until the ascii values were all in the printable range.  If you just
reprint the data section each time with different whitespace and the same
program at the end, maybe you could pull it off.  That's a million miles away
from actually pulling it off, but maybe it would work.
 - Ricky
