POV-Ray : Newsgroups : povray.off-topic : For a price Server Time
15 May 2026 16:29:56 EDT (-0400)
  For a price (Message 17 to 26 of 26)
Subject: Re: For a price
Date: 18 Aug 2009 07:54:59
Message: <4a8a9693$1@news.povray.org>
>> I think the basic problem is that even if I do all this, it's never
>> going to be exactly like a real organ peddalboard.
> Isn't there any way you can replicate what the pedal is actually
> connected to in a real one?  It shouldn't be hard to think of something
> to replicate the feeling.
I was thinking that I'll never get the exact spacing between the notes,
the curvature of the peddals, etc. exactly right.
Date: 18 Aug 2009 08:09:01
Message: <4a8a99dd@news.povray.org>
There's probably some design information on the internet somewhere that can
help you out with that.  Or just take a ruler and a notebook one time to the
church...
Date: 18 Aug 2009 21:51:06
Message: <4a8b5a8a$1@news.povray.org>
Invisible wrote:
> Chambers wrote:
>> How hard would it be to get a couple of pressure sensors, and wire
>> them up to a MIDI plug so you could have your own?
> Harder than you'd think.
> A peddleboard needs to not break when an 80 Kg person stamps on it. This
> is non-trivial.
Not necessarily.  If, as you stated, all you need to do is close a
circuit... well, you can do that quite easily.
> Where the hell do you buy pressure sensors?
Take apart any electronic scale, if you must.  Other than that, I'm sure
Radioshack has them (though I don't know about the tolerances of their
models).
> You realise that MIDI is a serial communications protocol, right? It's
> not like you just connect each sensor to a different pin on the plug;
> you need some fairly elaborate electronics in there.
Good point; maybe just wire it up to a parallel port, then, and generate
the MIDI signal via software.
Or, put something together with that breadboard you've been playing with ;)
>> Then you could go to the pub and tell some random girl, "Hey, baby,
>> you ever dated a guy who wired his own base?" :)
> *facepalm*
What, girls like a guy who can get things done! :)
...Chambers
Date: 19 Aug 2009 01:12:13
Message: <4a8b89ad$1@news.povray.org>
My choices are places like Adafruit and Sparkfun. Digikey, Mouser for
bulk parts, or for catalogs that are great brainstorming material (open
to random page, what could this part be used for). Radioshack if you
must. Or call a company that makes the sensor and ask for some samples
for a project you are developing.
Thinking about it, I don't know that I would use pressure sensors unless
you wanted pressure measurements. I don't know if that would matter for
pedals, as the pressure is going to be checked only once you have
already pushed it down. Simple dial resistors on each pedal would tell
you how far down they were pressed; optical encoders would work too
(dead mice scroll wheels, if you want those cheap). For more accuracy
than that, I would have to think about it more. Magnetic sensors might
work, but you would have to calibrate the whole set.
At the very simplest form, one input pin on any ol' micro-controller for
each pedal. If you have a force sensitive resistor (basic pressure
sensor) that is high resistance with no pressure and low when it has
pressure, use it to pull the pin low when pedal is pushed.** Wire it
differently if the sensor is different. Controller can just poll each
pin, or batches of pins where speed is an issue, and create the MIDI
packet to send. And if you are really set on having X packets per
second, the poll routine just stores the bits, and a timer interrupt
creates and sends the packet. Just make sure to have an optoisolator on
. . . crud, it has been forever since I did anything MIDI, I don't
remember if it is on the TX or RX wire.
Throw a multiplexer in, and you could use fewer i/o pins at the cost of
extra cpu cycles switching and waiting on the multiplexer. Going the
other way, a bigger chip so you can use 4 8-bit reads to get 32 pedals.
Or, really fancy, a 16 or 32-bit controller.
Elaborate? $8 micro-controllers are absurdly powerful now, and very easy
to program. Granted, most of the time it is assembly or some odd looking
java-esque language, but GCC will cross-compile to AVR and ARM chips.
The soldering might be tough, but for a prototype just breadboard it.
**I think that would result in less power drain than the other way
round, but I hack at these kinds of things, I don't engineer them.
Current limiting resistor on either supply or ground side, depending on
where you put the sensor, of course.
Date: 19 Aug 2009 03:24:30
Message: <4a8ba8ae@news.povray.org>
I've made a few sets of pedals for car racing games (where I think the
forces on the brake pedals are much higher than what would typically be used
to activate an organ pedal).  The usual construction is to have the pedal
rotating on a bearing with a big stiff spring giving the resistance force,
then a simple rotary potentiometer (variable resistor) is wired up as a
voltage divider (0V on one end, 5V on the other end) on the pedal axle with
an ADC (as you say often part of the microcontroller itself) converting the
centre tap into a digital signal that can be sent to the PC via USB.  This
setup is accurate enough to give good control over controlling the brakes in
a car racing game without any noise or spurious signals, so it should be
fine for controlling an organ pipe :-)
It would be a nice little project, you can buy ready-made PCBs with USB
interface and analog/digital interfaces if you don't feel like doing too
much of the electronics and microcontroller software yourself.
Date: 19 Aug 2009 06:05:49
Message: <4a8bce7d$1@news.povray.org>
>> *facepalm*
They also hate nerds with a passion.
Date: 19 Aug 2009 11:49:56
Message: <4a8c1f24$1@news.povray.org>
Many of them even have BASIC interpreters on chip, don't they? Or FORTH?
Weird stuff like that?
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 19 Aug 2009 15:32:27
Message: <4a8c534b$1@news.povray.org>
I know that some of the PIC boards come with BASIC software, google says
that they also have support for FORTH. From what little time I have used
PIC BASIC, it isn't something I would recommend. In the version I had,
you could only read or set one I/O pin per instruction, even digital
pins, instead of reading and setting 8 pin banks. For what I was doing,
and for a 25 pedal controller, that seems just a bit slow. For FORTH, I
don't have any more info than what google just showed me, that there
isn't a GCC port for PICs, and that most of the compilers are
proprietary. Don't have a clue how many are free and proprietary.
Date: 20 Aug 2009 05:55:23
Message: <4a8d1d8b@news.povray.org>
> each pedal.
Micro-controller? Ouch.
> packet to send.
Not quite.
MIDI sends note-on and note-off messages, so the controller needs to
"remember" the previous pin state to decide whether anything has changed.
MIDI is simplex, not duplex. A single MIDI cable carries messages in one
direction only. And I'm pretty sure it's the receiving end that's
supposed to be opto-isolated. (I.e., I don't have to do anything.)
1. I'd be very surprised if you can buy any sort of microcontroller for
2. A microcontroller on its own isn't going to do much good - unless I
also go out and buy a RAM ship and either a PROM and burner or some
flash RAM. I would think a PIC would be the way to go.
3. Even a PIC is probably vastly too difficult to program. And if it
doesn't work? It's not like you can debug it...
Date: 20 Aug 2009 11:26:05
Message: <4a8d6b0d@news.povray.org>
>> each pedal.
>> packet to send.
> Not quite.
So, you need RAM, no problem. Poll the pins, compare the state, and
construct the packets to send. Even without RAM, a few bytes of cache
would be enough. Even with 25 pedals and 10-bit ADC, that is still only
250 bits.
Shows how long it's been since I've done anything with MIDI. But if you
have a controller, why not have it capable of receiving MIDI
instructions? May want to use it for something else later.
Atmel's ATmega168 in DIP form are under $3 each. The 128, which has
enough digital I/O pins for 25 pedals is under $10. For 25 analog pins,
you may have to look elsewhere. Off hand I can't think of any, so
multiplexers might be the only way. Still, a $3 controller and a few $1
mux chips.
Most of them, now days, have built in flash memory for code, EEPROM that
the code can store stuff in over power loss, and built in RAM. The 168
has 1kB of RAM, 512B EEPROM, built in serial and 16kB of flash.
For programing, serial to a simple JTAG programmer (6 wires, right from
the serial port to certain pins) works great. If you prefer USB, look at
something like the Arduino, with built in USB, a custom bootloader, and
an development environment.
Why can't you debug them? Connect it to a PC via USB or serial, throw
some printf statements in to chat over the serial conncetion, and watch
what happens. Or use an in circuit debugger. It isn't what programmers
normally think of as debugging, but you could have it print blocks of
memory out, and only work through the next step of code when you send a
certain command. Takes longer to program that way. Some chips probably
have in chip debuggers, I think I have seen that on some Motorola or
another.
For easy programing, assuming C doesn't feel too low-level, take a look
at the Arduino. Lots of different forms, from really small breadboard
units, to full programers, a variety of chips for various pin counts,
with or without USB and headers for lots of external devices, and for
the most part they are around $30; 10 for breadboard kits, around 50 or
60 for larger pre-made boards with lots of I/O pins and RAM.
All prices are in USD, and as you can guess I use AVRs a lot more than
most of the other chips. I don't want to start the avr/pic/arm/mips holy
war here, those are just the chips I know.
