POV-Ray : Newsgroups : povray.off-topic : Backward Server Time
15 May 2026 17:45:16 EDT (-0400)
  Backward (Message 21 to 30 of 33)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Backward
Date: 17 Aug 2009 10:45:54
Message: <4a896d22$1@news.povray.org>
>>> Can't you just lock the machine instead of logging off?
>> The issue being that it is then impossible for anyone except the
>> person logged on to discover if the machine is still running OK, how
>> far it's got, etc.
> Set up a "lab" user or some such that everyone knows the login for
Then the *other* piece of software running on the computer wouldn't be
able to log audit events under the correct username.
> OOC, are normal applications required to carry on
> running if the user who started them logs off?  I have no idea.
Under Windows, any processes started by a user ordinarily get terminated
when that user logs off. Unless they do something special to prevent this...
Date: 18 Aug 2009 02:47:25
Message: <4a8a4e7d@news.povray.org>
Why not?  If it can log them under the correct username when nobody is
logged on, why shouldn't it be able to do it when someone else is logged on?
> this...
Like what? Do most programs cope OK with running when nobody is logged on?
I would have thought some get a bit screwed up what with there being no
desktop or whatever.
Date: 18 Aug 2009 04:19:55
Message: <4a8a642b@news.povray.org>
> on?
The program continues to run with nobody logged on, and continues to
execute any instructions it has been given. However, to give it
instructions, you have to log on, and it records the username of the
person giving the instructions. If we had a single logon, there would be
no record of who issued those instructions.
>> terminated when that user logs off. Unless they do something special
>> to prevent this...
> on? I would have thought some get a bit screwed up what with there being
> no desktop or whatever.
No, I meant unless the *program* does something special to tell the OS
it wants to keep running.
It sounds like the guys at HQ are looking at trying to run our problem
software as a service somehow... We'll see if they can actually get it
to work. (I rather suspect not.)
Date: 18 Aug 2009 05:16:15
Message: <4a8a715f$1@news.povray.org>
Just set it up so the program that you give commands to cannot be started as
the lab user, and then do "Run As" the real user when you need to issue
commands...
BTW I thought you could switch users on XP and Vista without the first
user's programs being shut down.
Date: 18 Aug 2009 05:38:24
Message: <4a8a7690$1@news.povray.org>
>> be no record of who issued those instructions.
> started as the lab user, and then do "Run As" the real user when you
> need to issue commands...
That could work, I guess.
Uh... yeah, possibly.
Date: 18 Aug 2009 11:23:18
Message: <4a8ac766$1@news.povray.org>
You do know you can have two people logged on at the same time, yes?
Start program one, lock the screen, log in as second user, start program
two, lock the screen.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 18 Aug 2009 11:24:09
Message: <4a8ac799$1@news.povray.org>
Actually, that might be slightly harder with AD. You might have to log in
remotely to have multiple accounts logged in at once.
Date: 20 Aug 2009 00:50:17
Message: <4a8cd609@news.povray.org>
In Windows XP, you cannot "switch users" like that if the computer is part
of a Windows domain. But it is supported since Vista.
Date: 20 Aug 2009 01:49:56
Message: <4a8ce404$1@news.povray.org>
Is that true even if you log in remotely with RDP? I know we did that with
Win2000, so I find it hard to believe XP can't?
Date: 20 Aug 2009 04:07:40
Message: <4a8d044c@news.povray.org>
>> part
> with Win2000, so I find it hard to believe XP can't?
Windows XP Professional supports 1 user logging in via RDP (but only if
nobody is logged in remotely). Windows 2003 Server supports multiple RDP
sessions, but Windows XP supports only one at a time. As in, before
anybody else can connect, you must disconnect (i.e., log out).
