POV-Ray : Newsgroups : povray.off-topic : Backward Server Time
15 May 2026 16:30:31 EDT (-0400)
  Backward (Message 11 to 20 of 33)
Subject: Re: Backward
Date: 13 Aug 2009 04:17:11
Message: <4a83cc07@news.povray.org>
SharkD wrote:
> What OS can the software run in? You might make use of virtualization
> (VMWare, VirtualPC, etc.) to solve your problem.
Yeah, I've been thinking about that.
I have a laptop with a USB to serial adaptor, but the software
stubbornly *refuses* to use it. If I were to set up a virtual machine,
then the software would be unable to tell it's accessing a USB device;
it would look like a native serial port.
OTOH, last time I tried to set up a virtual machine, it took two days
just to install Windows XP and update to service pack 3. That's quite
absurdly slow...
Date: 13 Aug 2009 12:47:40
Message: <4a8443ac$1@news.povray.org>
> absurdly slow...
You need better hardware.  It should never take that much time to install
an OS - in my VMs, it never took that long....
What specs on the machine (including host OS)?
Date: 13 Aug 2009 14:06:49
Message: <4a845639@news.povray.org>
> absurdly slow...
Was it VirtualBox 3.0 with multi-core (SMP) enabled?
When I tried that, it took several hours for Windows XP to install, on an
AMD 4200+ CPU. VBox SMP support still sucks.
Date: 14 Aug 2009 06:19:07
Message: <4a853a1b@news.povray.org>
>> absurdly slow...
 From memory, it was a 4 GHz Pentium IV with 512 MB RAM, running QEMU.
(The laptops I'm looking at using are this spec or worse.)
Date: 14 Aug 2009 19:52:23
Message: <4a85f8b7$1@news.povray.org>
>>> absurdly slow...
>> install an OS - in my VMs, it never took that long....
Memory would be the issue here, no wonder it took forever to install, it
was probably swapping fiercely.
For good virtualization, you really need to have at least 1 or 2 GB of
memory.  Insufficient host memory can lead to serious performance
problems.
Jim
Date: 15 Aug 2009 02:13:46
Message: <4a86521a$1@news.povray.org>
>>>> absurdly slow...
> problems.
It didn't seem to be swapping *at all*. Hardly any HD activity. Just
100% CPU, constantly.
I've heard people claim that the problem is QEMU - which is a user-mode
hardware emulator rather than a virtualisation program that runs most
code natively... but having never seen any other VM product, I don't
know if it makes much difference.
http://blog.orphi.me.uk/
Date: 15 Aug 2009 14:40:49
Message: <4a870131@news.povray.org>
>>>>> days just to install Windows XP and update to service pack 3. That's
>>>>> quite absurdly slow...
>> it was probably swapping fiercely.
>> problems.
If for some reason the guest OS isn't relinquishing control to the host
(which can happen), that also would explain it.  But if your host OS
requires 256 MB to run and the guest requires 256 MB to run, there's no
memory left for the actual virtualization software, so it has to get
memory from somewhere.
512 MB is a fairly low spec for any system doing virtualization,
regardless of the software.  My bet is still on memory.
Grab VMware Server from http://www.vmware.com - it's free.  Not quite as
easy to use as VMware Workstation, but WS is a pay-for product.
Jim
Date: 17 Aug 2009 08:49:04
Message: <4a8951c0$1@news.povray.org>
> We have some equipment in our lab. It needs a computer to control it.
> Unfortunately, the control software requires somebody to be logged in. As
> soon as you log out, it quits the control program, halting the machine.
Can't you just lock the machine instead of logging off?
> Except that the control software stubbornly, repeatedly *refuses* to
> believe me that the USB serial port actually exists. Every other piece of
> software I've tried can access it without issue. But not the one piece of
> software that we *need* to access it. No sir. Not interested. It can "see"
> the port, but it refuses to *select* that port. And nothing I've done so
> far seems to convince it to work.
OOC what COM port number is assigned to the USB COM port?  If it's higher
than 4 then you might try changing it to 4 or below (you can usually do it
from device manager under the properties of the USB-COM adapter).  Some
older programs don't like working with things like COM7 which those USB
converters typically come up as.
Date: 17 Aug 2009 09:10:01
Message: <4a8956a9$1@news.povray.org>
>> As soon as you log out, it quits the control program, halting the
>> machine.
The issue being that it is then impossible for anyone except the person
logged on to discover if the machine is still running OK, how far it's
got, etc.
If we used the other software, this problem would be 100% solved. The
other software runs as a service, multiple people can access it, you can
set up access controls and auditing... the whole nine yards. But the
people at the top can't be bothered to put in the effort to test it, so
we can't use it.
>> of software I've tried can access it without issue. But not the one
>> piece of software that we *need* to access it. No sir. Not interested.
>> It can "see" the port, but it refuses to *select* that port. And
>> nothing I've done so far seems to convince it to work.
> higher than 4 then you might try changing it to 4 or below (you can
> usually do it from device manager under the properties of the USB-COM
> adapter).  Some older programs don't like working with things like COM7
> which those USB converters typically come up as.
Defaults to COM3. I've tried changing it to COM2 also. (COM1 is the
built-in modem.)
However, today I obtained the latest version of the control software,
and it now works perfectly with the USB adaptor. Go figure...
Date: 17 Aug 2009 10:17:23
Message: <4a896673@news.povray.org>
>>> machine.
> got, etc.
Set up a "lab" user or some such that everyone knows the login for, we have
that here to solve exactly that problem with our temperature logging
software.  OOC, are normal applications required to carry on running if the
user who started them logs off?  I have no idea.
