POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
1 Jun 2026 13:29:58 EDT (-0400)
  Tell me it isn't so! (Message 311 to 320 of 473)
Subject: Re: Tell me it isn't so!
Date: 28 Jul 2009 04:00:00
Message: <web.4a6eafd6ac52dfd46dd25f0b0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> "David H. Burns" <dhb### [at] cherokeetelnet> wrote:
> > A convenient excuse anyway. "Everybody needs someone to look down on. If you
> > ain't got nobody else, well help yo'self to me!" -Kris Kristofferson
> > (quoted from
> > memory) :)
> "Jesus was a capricorn"
"Capricorn, eh? What are they like?"
"He is the son of God, our Messiah! King of the Jews!"
"And that's capricorn, is it?"
Date: 28 Jul 2009 04:10:01
Message: <web.4a6eb206ac52dfd46dd25f0b0@news.povray.org>
> > A peek function would still be useful, but a poke function on a multi
> > tasking system where
> > the operating system is in RAM ... well at best, you might reboot a lot.
> Would be very boring these days: At worst, poking around would get that
> particular app jam itself, and you'd have to kill it via the task manager.
In my particular example, of course, none of that applied. Being able to write
directly to memory from BASIC on the Acorns meant you could store large amounts
of data more efficiently without having to resort to assembler. And, since the
screen memory was in main RAM, you could write to the screen by storing your
pixel values directly to that block... :)
Date: 28 Jul 2009 04:31:12
Message: <4a6eb750@news.povray.org>
clipka <nomail@nomail> wrote:
> Neeum Zawan <m.n### [at] ieeeorg> wrote:
> >  I wonder when such editors came around. Ever since I used BASIC, there
> > was the RENUM command. Of course, I _started_ using BASIC long, long
> > after its invention.
> IIRC one of the main factors of BASIC's popularity - the all-time famous C-64 -
> did *not* have a "RENUM" command.
> The first computer *I* used, the Amstrad CPC, *did* - hehe :P
  Of course even in editors which did have a renum command, it would mess
up any numbering scheme you might have been using. For example, if you
started every subroutine using line numbers starting from multiples of 1000
(so that you could easily remember that "this subroutine started at line
3000, and that one at line 5000" etc) the renumbering would mess up all
that and you lost the semi-logical numbering.
  There were some BASIC interpreters (eg. in the ZX Spectrum) which supported
jumping to a line which number was specified by a variable. In other words,
you could do a "GOTO xyz" where xyz was a variable. The interpreter would
then jump to the line which number was the value of that variable, or the
next line closest to that number if it didn't exist. (This allowed writing
some elementary switch/case constructs etc.) Naturally the renumbering command
would have no idea about this, and it would break your code.
  Overall, BASIC programs were quite hard to read and understand. Most
editors in the old days did not support such a basic technique as code
indenting (iow. even if you tried to indent the code manually, the editor
didn't support it and you couldn't). This means that every single line of
code started from the same column, which made reading long nested blocks of
code a bit difficult.
Date: 28 Jul 2009 04:34:38
Message: <4a6eb81e@news.povray.org>
> I guess the graphics card would be perfectly fine with it - even today's
> graphics card still include backwards compatibility with VGA, if only for
> booting and just in case someone decided to run some old DOS.
  If you are having problems running old DOS programs with a modern PC,
all you have to do is to use the DosBox emulator. It's a full PC/DOS emulator
(ie. it emulates the entire hardware) and it works very well. Most DOS programs
run flawlessly and without having to configure anything. The emulator is
available for many systems (including Windows and Linux).
Date: 28 Jul 2009 04:49:45
Message: <4a6ebba9$1@news.povray.org>
I am 75% sure that the C64 would *automatically* indent your code. As
in, if you wrote a FOR-NEXT loop, the loop body would automatically
appear indented, and there was nothing you could do about it.
But sure, the whole concept of using line numbers for editing, must less
flow control, is fundamentally flawed...
Date: 28 Jul 2009 04:53:37
Message: <4a6ebc91@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> The problem with all the low-level languages like C and C++ and such is that
> they don't really come with the libraries you need to do modern stuff.
> There's nothing built in for threading, graphics, sound, IPC, etc. That's
> all left to libraries developed well after the language was standardized.
  The reason why languages like C++ don't come up with libraries which would
be handy (such as graphics and sound) is complicated.
  There is no one single unambiguous, clear way of drawing graphics easily
and as efficiently as possible in all systems (never mind the fact that C++
is designed to be portable and not all computers even *support* any kind of
graphics). For example, if you were in Windows, how should a graphics library
work? Should it be a full GUI library like Qt or WxWidgets? Or should it be
simply a library which draws on some drawing surface/frame buffer, but leaving
GUI elements up to the (non-standard) system libraries? Should the graphics
be drawn using the Windows API, DirectX or maybe OpenGL? These are mutually
incompatible techniques which have their advantages and disadvantages, and
it's very difficult to create a library which would be agnostic to the choice
(and still be fully useful). Also if you wanted to draw accelerated 3D
graphics, there is no one single unambiguous, clear way of doing that either.
You could try to replicate OpenGL or something like DirectX, but since hardware
is constantly developing, the standard library would get old really quick.
It would be basically useless for anything new.
  Also such library would be highly non-portable. For example, if the C++
standard dictated some kind of GUI library, how would you implement it eg.
for the iPhone? You just can't. This would mean that for such systems you
would have to use a crippled version of the language which may or may not
compile some existing code.
  A standard library to play sounds would run into similar problems, as well
as its own. The source of the sound would be a difficult question. Usually
you would want to play a sound from a file. Which sound file formats should
be supported by a standard library? Many of the most useful formats have
license restrictions, which is something you really don't want to be using
in a programming language standard. Usually international standards for a
portable programming language try to be neutral with respect to proprietary
licensed file formats and such, for a good reason. Thus a standard sound
library would necessarily be very limited and mostly useless. It would also
probably get old quickly, as new, better formats are being developed all the
time.
Date: 28 Jul 2009 06:10:01
Message: <web.4a6ecd69ac52dfd4813466d60@news.povray.org>
> I blamed those "access violations" that occasionally show up on Windows. So
> their really due to a "safety" feature in Intel's hardware. Is that why
> machines with
> AMD processor's (reportedly) crash and hangup less frequently?
No, not really: AMD processors use the very same features.
They do have a fierce and long-standing competition however, as to who can get
the most computing power out of a single chunk of silicon; naturally, this
involves pushing the CPUs quite close to their limits of stable operation; if
these limits are exceeded, once in a while a glitch may occur and just throw
the computer off-track; in such a case, anything might happen then, from a
computation error, to a messed up address pointer or misread programm command
that may have the CPU's / operating system's safety measures kick in as
response.
I guess it is worth noting here that not every such access violation message is
due to a glitch in the CPU; probably the vast majority of such messages in
everyday use is due to straightforward programming errors (often flawed pointer
handling in C/C++ code). Instead, true glitches are most frequently observed by
high-end gamers trying to push the system even closer to its limits than AMD or
Intel decided to, by operating them beyond the official operational parameters
(bus clock, clock multiplier, memory access timings, voltages and the like).
The allegations about processor stability tend to change over time, too: A few
years ago, it was Intel CPUs that were considered more stable.
So to wrap it up, those "access violations" are actually the applications' fault
- even though they seem to be a rather Windows-typical phenomenon, but I
attribute this to some good degree to the fact that Windows just happens to be
the most popular target for unexperienced or lazy program authors.
Date: 28 Jul 2009 06:15:00
Message: <web.4a6ece8eac52dfd4813466d60@news.povray.org>
No need to tell me that - I had an Amstrad CPC, which featured 16K of display
RAM so there was plenty of poking you could do :)
Date: 28 Jul 2009 06:25:00
Message: <web.4a6ed1a7ac52dfd4813466d60@news.povray.org>
Actually, the Amstrad CPC's BASIC was remarkably sophisticated about that,
allowing you to renumber only a subset of lines, to start from a specified new
number and at specified intervals.
IIRC, really the *only* problematic statements were GOTOs to non-existent lines,
which would by default go to the next higher existing line number; these could
indeed be broken.
Truly computed GOTOs, as far as I can remember, weren't supported by the Amstrad
CPC's BASIC (except with some obscure RSX tools) - only a "ON ... GOTO
line1,line2,line3,..." to pick one of a predefined set of jump targets.
Still, with some discipline it was possible to write well-maintainable code.
(Though I agree that there are languages that make it far easier.)
Date: 28 Jul 2009 06:40:01
Message: <web.4a6ed471ac52dfd4813466d60@news.povray.org>
I'm 99% sure it did *un-indent* the code no matter how hard you tried... (just
googled for a few C64 BASIC code snippets, and found them all not indented)
