POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
14 Jun 2026 22:49:40 EDT (-0400)
  Tell me it isn't so! (Message 244 to 253 of 473)
Subject: Re: Tell me it isn't so!
Date: 27 Jul 2009 13:05:00
Message: <web.4a6ddd51ac52dfd4842b7b550@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> And not because of any of the dozens of *actual* reasons that have been
> described over the years.  No, just a conspiracy by the elite to make you,
> David Burns, feel bad that programming is hard. <plonk>
Hmm, I think plonking him is a bit too extreme a reaction...
Date: 27 Jul 2009 13:30:55
Message: <4a6de44f@news.povray.org>
Warp wrote:
>   The original BASIC was such ... that it was basically frowned upon by
> everybody from the beginning.
Welllll... I wouldn't go that far. It was acknowledged as simplified, in
much the same way that DOS BAT files are simplified or editor macros are
simplified. It was designed as a beginner's language, so it wasn't really
frowned upon any more than LOGO or PILOT is frowned upon.
It was only after people tried to turn it into something sophisticated they
could continue using for large professional programs with multiple
programmers that it was "frowned upon", methinks.
>   The original BASIC didn't even have the concept of functions.
And many of the languages of the time didn't have recursion even if they had
functions. :-)
>   Goto was an inherent part of the language, and used extensively. This,
> naturally, also caused criticism,
Except that BASIC was invented a couple years before structured programming
was, so this was only a criticism a decade after BASIC was popular. It also
started out with only what you might call "computed if" statements. I.e.,
the only valid thing after a "then" or "else" was "goto".
>   Even if we took goto as barely acceptable, its original implementation was
> very ascetic. AFAIK the original BASIC did not support named labels, but
> instead every line of code was numbered (by hand by the programmer), and
> gotos always jumped to a specified line number. AFAIK the numbering of each
> line was mandatory.
Yes. BASIC was revolutionary in that it had its own editor built into the
language, which was pretty nice in the days of punched cards and paper tape.
> Naturally this made it quite problematic to insert code
> between existing lines. While it was customary to number the lines in
> multiples of ten, this only gives the possibility of inserting 9 lines
> of code between any existing lines. If you run out of line numbers, you
> will have to start renumbering.
It also contributed to the spaghetti code, because if you ran out of lines
and didn't have a automatic renumbering program, you'd put a subroutine
somewhere, gosub it, and then return. Like patching assembly code. Good
thing all the variables are global. ;-)  That's why serious people used
counts of 100 instead of 10. ;-)
>   Control structures were ascetic and limited, as well as the possibility
> of creating things like data containers.
>   It's no serious programmer ever bothered with BASIC.
Not if there was a reasonable choice, and not if you had more than one
person working on the program. Unless you were just learning how to program.
Actually, I worked with lots of serious programmers that did extensive work
in BASIC. They were all people I didn't consider very professional, tho, and
the programs were fairly small compared to what you see for even a simple
program nowadays.
Except for the ones doing BASIC on the microcomputers, where it was actually
pretty good, since it was the main supported "high level" language. People
did some neat stuff in spite of the limitations.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 27 Jul 2009 13:34:41
Message: <4a6de531@news.povray.org>
clipka wrote:
> For quite a while you didn't get any programming language for free with
> IMB-compatible PCs when they replaced home computers as the private man's
I'm pretty sure you still had GWBasic in ROM. Indeed, that was one of the
reasons people wanted a "real" IBM PC and not just a "compatible" - you
could build the same hardware, but you couldn't include the GWBasic ROMs, so
code that called into the ROMs (for things like trigonometric functions etc)
wouldn't work on a "clone" at first. (Or was it "QuickBasic"?)
Date: 27 Jul 2009 14:04:34
Message: <4A6DEC33.3070508@hotmail.com>
On 27-7-2009 18:56, Warp wrote:
> clipka <nomail@nomail> wrote:
>> Not really the most modern of languages (unless you count VB/VBA, but as you say
>> yourself these are actually totally different beasts), and indeed one of the
>> most frowned-at languages (VB/VBA included in this case); I guess that's mostly
>> undeserved
>   The original BASIC was such a simplistic scripting language compared to
> way more advanced programming languages of the same era (including such
> masterpieces as lisp, which was surprisingly advanced and high-level taking
> into account it was invented in 1958) that it was basically frowned upon by
As was Pascal, dismissed as 'just an educational language' that was not
useful for real life projects.
>   The original BASIC didn't even have the concept of functions. It had a
> very primitive version of them, subroutines (which are like functions which
> don't take parameters nor return anything, and without any local scope).
> The only thing which differentiated a subroutine call from a goto is that
> the subroutine call pushed the caller's address onto a stack, so that a
> "return" statement could return there when the subroutine ends. But that's
> about it.
>   More jarringly, every single variable was global. The concept of local
> variables was inexistent, obviously because of the lack of proper functions.
> naturally, also caused criticism, as liberal use of gotos easily disrupts
> the logical flow of code and makes it harder to follow and understand, even
> if the obfuscation is not intentional.
Some historical context: BASIC is from 1964. The famous 'Go To statememt
considered harmful' dates from 1968. At the time of design goto was
excepted and even the norm. You can't blame the designers for that. Not
even with 40+ years hindsight.
> line was mandatory. Naturally this made it quite problematic to insert code
> will have to start renumbering. And good luck trying not to break existing
> gotos if you start renumbering. (Some later BASIC text editors supported
> automatic renumbering, including all gotos, but naturally no such editors
> existed back then, when even having an interactive text editor in the first
> place was luxury.)
Indeed, when I started at uni ('82) I had to use a line editor for my
programs on the mainframe. At home and elsewhere I had been using full
screen editors for many years.
If you look at what the design constraints were you will find that it
perfectly fitted. As much as everybody would have loved to have more
expressivity it would not have fitted in the ROM of these days.
On the contrary, many did. Those that were designing software that had
to run on cheap general purpose computers like Apple II and the
Commodore PET series and the like. Many very serious programmers were
involved in writing BASIC interpreters and compilers. Perhaps the only
place it was not as much used was in the just starting computer science
departments of those days. And if they didn't it was more because they
had no feeling with the real world outside than anything else.
Date: 27 Jul 2009 15:00:29
Message: <4a6df94d@news.povray.org>
> undeserved, however: The frowns should go to the people who thought it a good
> idea to introduce "GOTO" as the second statement after "PRINT", thereby
> inviting virtually the whole Home Computer Generation to become hobbyist
> spaghetti code producers.
Of which I'm one. But to my mind any good computer language should allow
one to produce
"spaghetti code" (I had forgotten that term) if one wanted to. The
"GOTO" statement
deserves much of the frowning it gets, but not all.
> Normally, the first two programs would be:
I remember right the first "real program" I ever wrote was a program to
calculate ozone
concentration on a Commadore Pet. It was the first computer I ever dealt
with
and after a *very* short time playing with it I was able to write a
program to replace
the one we had been using on a TI55(?) calculator (the one with the card
reader --remember
that?) The Pet had a version of Microsoft BASIC in ROM. For years
afterwards --
until Windows 95--Microsoft was my favorite software company! I had
never even been
in the room with a computer before and could hardly use an adding
machine. but I was
able to write a useful program with almost no experience. I don't see
any good reason
why the basics of *any* high level computer language should not be
almost that easy to
learn!
> It's really a matter of programming style whether a BASIC programmer should be
> despised or not. BASIC allows for a broad spectrum there. But then again, ever
> since I've seen the C source code of "NetHack", I can tell that at least C
> programs - even when not deliberately obfuscated - can be just as messy as any
> BASIC code.
Much more so, I am assured. "Document the H* out of your C code!" was
one of my
teacher's advice.
>> QuickBasic was it's highest development.
> Just out of curiosity: Did they ever introduce such things as structs (records
> in Pascal)? That was the thing that bothered me most about BASIC ever since I
> first wanted to store a list of data tuples. Using a separate array for each
> "dimension" of the tuple just didn't feel right.
Not in QB as I recall. You can do it sort of in VB4, but ir fights you.
That would
have been one of the next logical steps, along with C-like pointer
capability and, of
course Windows graphic capability. If I remember right, the QuickBASIC
and QuickC
IDE's were models of what a good simple IDE should be. Microsoft was
good in those
days!
>> I was able to display an image and VBnet seemed to promise good image
>> handling capabilities if one could only figure them out.
> If graphics (or any other non-textual user interaction, for that matter) is what
> you want to do, it comes as no surprise to me that you don't like modern
> computer languages. The major problem, however, is not an inherent feature of
> the languages themselves, but of graphical user interfaces (at least as far as
> Windows is concerned;
Yes access to Windows graphic functions seem unnecessarily complicated and
poorly documented. I can't see any good reason for this.
I never got to have a look at X Window or the like),
> which follow an *event-driven* paradigm - i.e. *they* want to tell your program
> when to do what, which is almost perfectly incompatible with the classic
> application-driven paradigm. And although I guess this is exactly what you're
> wrongly attributing to OOP, you're not so far off the mark: As a matter of
> fact, an object in OOP can be regarded as an event-driven piece of software
> (each method call constituding an event), so OOP is a very good paradigm to
> model an event-driven application: All you need to do is consider your whole
> application an object, too - which I admit is indeed *not* a natural way of
> thinking.
> (However, while the event-driven paradigm *is* an antithesis to the classic
> application-driven paradigm you undoubtedly favor, OOP can be used perfectly
> well for both.)
> Unfortunately, modern mainstream programming environments indeed don't seem to
> come with any framework to support the classic application-driven paradigm,
> except for purely textual interfaces ("console application" in Microsoft terms)
> or a static sequence of dialogs ("wizards").
I don't understand a lot of what you say, but it fascinates me, I may
have to learn OOP
and more about modern programming just for the fun of it.
> Speaking of Borland, maybe they still come with the good old "graph" library and
> the BGI graphics driver format, in which case I'd expect them to include a BGI
> to interface to Windows, too.
Maybe it does, if so I haven't be able to find it--or recognize it. The
old "graphic.h" was for DOS and
won't work on XP, anyway, and I think the routines are incompatible with
modern graphic
cards.
> C is really not a pretty language, by the way.
No, but it's fascinating, and in my little experience addictive.
David :)
Date: 27 Jul 2009 15:11:20
Message: <4a6dfbd8$1@news.povray.org>
>> undeserved
> about it.
> place was luxury.)
Clearly, I am no serious programmer. That charge, I accept gladly and
rejoice in it!
Thanks for the history of BASIC, I didn't know anything about it. As I
said elsewhere,
my first experience of it was Microsoft Basic and serious programming
language or not,
it was *very* useful at work and at play! And by it, I learned that even
I can program,
though perhaps some would hesitate to admit that. :)
David
Date: 27 Jul 2009 15:13:14
Message: <4a6dfc4a$1@news.povray.org>
Much of that comes from not having standardized the libraries, by the way.
Most of the languages from the early 60's lived or died based on how well
you could interface to the OS without learning the details too hard. If you
couldn't open a file by name with your language, you were pretty much doomed
to obscurity. If you couldn't read and write the standard files that the
"real" programming languages (FORTRAN, COBOL, etc) created (regardless of
whether you had to open them outside the program), you didn't even get off
the ground.
Date: 27 Jul 2009 15:20:35
Message: <4a6dfe03@news.povray.org>
What's "plonk"? Or maybe I don't won't to know. ;)
David
Date: 27 Jul 2009 15:26:51
Message: <4a6dff7b$1@news.povray.org>
clipka wrote:
> (Yes, you *definitely* should spend more time with Wikipedia - she's your friend
I'm beginning to see that. I see that there's a group working on a "QB64".
David
Date: 27 Jul 2009 15:47:30
Message: <4A6E0454.2090507@hotmail.com>
>>> you,
plonk is the sound made when someone is dropped in a kill-file
http://catb.org/jargon/html/P/plonk.html
http://catb.org/jargon/html/K/kill-file.html
in short he said he is going to arrange that he won't see any message
from you again. Even shorter, he decided you are a troll.
BTW I agree with clipka, it is a bit of overreacting. It is also a bit
out of character for Darren, so I guess he was just tired.
