![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> How do you make the monitor waterproof?
> At least CRTs require air circulation. I actually don't know about LCDs.
Maybe it's watercooled? ;-)
Seriously though... The part of an LCD that gets hot is the flourescent
backlight. I'm no expert here, but I would imagine if you only run it
for a short time, it won't have time to heat up much. Those things don't
generate all that much heat. (Cathode ray guns require a heating
element, on the other hand...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> LCDs.
Depends on how much heat the backlight generates and what temperature it
needs to work in. If the waterproof LCD will be on a ship, I imagine you
can bolt it to a huge piece of metal which will work as a pretty good
heatsink. So long as you design the LCD backlight to have a good thermal
contact with the waterproof case from the inside it should work fine.
> backlight. I'm no expert here, but I would imagine if you only run it for
Umm yeh, I don't think that's going to be acceptable to anyone if you can
only run it for 15 minutes then have to wait an hour for it too cool down
before you can use it again.
> Those things don't generate all that much heat.
It's surprising how hot things get when they are in sealed boxes...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> flourescent backlight. I'm no expert here, but I would imagine if you
>> only run it for a short time, it won't have time to heat up much.
> can only run it for 15 minutes then have to wait an hour for it too cool
> down before you can use it again.
Depends what it's for.
If, as when this thread started, it's for a computer, then no, that
probably won't be much good.
True.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote:
> Tim Attwood <tim### [at] anti-spam comcast net> wrote:
> > Yeah, the waterproof ones are quite practical in marine
> > situations. You can hide a desktop box in a dry cabinet
> > and just have the keyboard and monitor exposed.
cabinets. Basically they were normal CRTs housed in a stainless steel or cast
iron cabinet with a toughened glass port, kept under positive pressure. No
problems with them running 24/7 for months.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, by marine I meant on a boat, I've
seen a couple types of monitor mount...
1. Flush console mount: the monitor is
flush to a surface, so only the front needs
to be water resistant, behind the monitor
is generally some empty space for various
wiring.
2. Wall mount: the monitor is attached by
bracket to a wall or ceiling, usually with
some sort of overhead rain protection, and
a closable cabinet, or a way to detach and
stow the monitor.
In both situations there's the option of just
putting the monitor behind some plexi-glass.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Using an LED backlight instead of fluorescent. Heat problem solved.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Haha if only that were true. LEDs are very concentrated sources of heat,
this generates very high maximum temperatures compared to CCFLs. LEDs get
less efficient the hotter they get (opposite to CCFLs) ... say hello to
positive feedback! And anyway, currently LEDs aren't *that* much more
efficient than CCFLs at converting electricity to light, you're certainly
not going to half your power or anything like that.
The big drive to change from CCFL to LED is mainly because mercury is banned
(or will be banned soon) in most applications.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> banned (or will be banned soon) in most applications.
Question: How do you make mercury switches without mercury?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You put a small metal rod in a glass tube ... (The AC system in my
apartment has one of these mercury-free mercury switches) it isn't
nearly as precise as a real mercury switch, either.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think so, I'd say they just require pretty intensive cooling.
You could use eg. A/C -style heat pumping to get the heat out of the
sealed box. or a liquid cooling systematically aimed for the heating
parts of the monitor. LCD is easier to cool, since it makes less heat.
Yes, it might cost significantly more than the monitor itself
(especially CRT on these days), but that doesn't equal impossible :-).
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
