POV-Ray : Newsgroups : povray.off-topic : Building a new PC Server Time
15 May 2026 19:57:33 EDT (-0400)
  Building a new PC (Message 11 to 20 of 51)
Subject: Re: Building a new PC
Date: 19 Jun 2009 15:41:36
Message: <4a3be9f0@news.povray.org>
Mike Raiford wrote:
> Heh... I'm saying that about my 2.4ghz p4, now.. :/
Sorry.... 2.6ghz
~Mike
Date: 19 Jun 2009 16:00:54
Message: <4a3bee76@news.povray.org>
Mike Raiford <"m[raiford]!at"@gmail.com> wrote:
> For example, this flash game runs slowly enough that it's unplayable on
> my home PC, but my office PC, which has the same CPU speed, but is a
> Core 2 Duo runs it fine. I can't figure out why my processor seems to be
> slowing down, though.
  Which OS are you using? If Windows, what kind of maintenance do you
perform on it? For example, have you checked what programs start themselves
at startup? Have you tried defragmenters, registry and disk clenup, and
other such things? (And of course virus and adware scanning should be
rather obvious.)
  Have you checked your CPU temperature? Does the CPU fan tend to run much
faster nowadays than years ago? Assuming it's working properly, of course.
(A relatively remote, although plausible, explanation for real, rather than
perceived, slowdowns is that the P4 and newer processors actually decrease
their own clockrate if they become dangerously overheated. However, usually
you should notice this long before it happens, as the CPU fan will start
spinning like mad. Assuming it's working properly, of course.)
Date: 19 Jun 2009 16:11:52
Message: <4a3bf108$1@news.povray.org>
> rather obvious.)
Vista ... and yeah, I'm pretty anal about system maintenance. I watch
CPU usage very closely. I do have an errant task from the printer
sometimes that I have to kill. My startup apps are generally things I
want running/ need running.
I did this last night, in fact, while running a CPU intensive program,
throttling. The fan is running fine, though the heatsink was clogged
with dust, cleaned that out, No change in temp. I'm wondering if I need
new heatsink goop at this point
~Mike
Date: 19 Jun 2009 22:10:00
Message: <web.4a3c443b563dd8d73eea59080@news.povray.org>
A single core from the Core 2 architecture (Core 2 Solo?) is significantly
faster than a single core from the P4 architecture, even at the same clock
speed.
....Chambers
Date: 22 Jun 2009 04:39:47
Message: <4a3f4353$1@news.povray.org>
> I did this last night, in fact, while running a CPU intensive program, and
> throttling. The fan is running fine, though the heatsink was clogged with
> dust, cleaned that out, No change in temp. I'm wondering if I need new
Check in Control Panel -> System for the clock rate, it should say something
like "E8500 @ 3.16 GHz 3.17 GHz".  One of those numbers is the "name" of the
processor, the other is the actual clock speed at that instant.  If the CPU
is throttling then one of the numbers will be lower.
Date: 22 Jun 2009 04:41:30
Message: <4a3f43ba$1@news.povray.org>
> speed.
Yes, by a long way IIRC.
Date: 22 Jun 2009 09:01:21
Message: <4a3f80a1$1@news.povray.org>
>> significantly
>> clock
>> speed.
Interesting ... I figured it was multiple cores giving it its speed.
But, I suppose as technology improves ..
In that case a Core2 Quad should be a screamer. Then I can sit back and
impatiently wait for 3.7 to become a final release :-D
~Mike
Date: 22 Jun 2009 09:23:53
Message: <4a3f85e9$1@news.povray.org>
http://www.cpubenchmark.net/common_cpus.html
Subject: Pass Mark
Date: 22 Jun 2009 09:47:31
Message: <4a3f8b73$1@news.povray.org>
>>> significantly
>>> clock
>>> speed.
According to PassMark, a 3.00 GHz Pentium IV is rated at about 479 "pass
marks", while an Intel Core 2 Duo at only 1.86 GHz is rated at 1,220
pass marks. In other words, 2.563x faster. Now, it's 2x faster because
it's dual-core, but what about the other 56%?
The Core 2 architecture has a faster FSB (so the CPU spends less time
waiting around for data to arrive from RAM), bigger caches (so there's
fewer cache misses => less time waiting around for data), better branch
prediction (=> fewer pipeline stalls), more execution units (=> it can
execute more instructions simultaneously - assuming the program in
question is amenable to it)... it all adds up.
What do you have? Core 2 Quad Q9550 2.83 GHz? That's rated at 4,160 pass
marks.
(Bearing in mind that Pass Mark is a synthetic benchmark which measures
CPU performance under idellic conditions... But even if you assume all
your programs are single-threaded, divide pass marks by 4 gives you
1,040 pass marks, which is still 2.17x the Pentium IV above.)
Source:
http://www.cpubenchmark.net/cpu_list.php
Date: 22 Jun 2009 10:31:42
Message: <4a3f95ce$1@news.povray.org>
So, I bought a new heatsink from the local computer shop. It took the
guy 15 minutes of rummaging around in the back to find one to fit my
ancient system. Installed it.
CRAP.
I was poking around my PC last night, and noticed the air from the case
was pretty hot. (Seriously, I could use this thing in the winter to keep
Wonder what would change if I ran the case open. I lose the fan in the
case side, but maybe it'll give me adequate ventilation.
If I can just keep this thing from driving me bonkers (or possibly
failing due to thermal stress) until I build the new one (BTW, I think
I'm going to start with 4GB of DDR3 instead of 2GB... Might as
well....Memory is cheap)
~Mike
