POV-Ray : Newsgroups : povray.off-topic : That time again [100 KB] Server Time
15 May 2026 19:56:15 EDT (-0400)
  That time again [100 KB] (Message 16 to 25 of 25)
Subject: Re: That time again [100 KB]
Date: 19 Jun 2009 11:11:10
Message: <4a3baa8e$1@news.povray.org>
Orchid XP v8 wrote:
> Yay! I suck. :-}
I'm assuming you're just being silly. I'm giving you an example of what an
editor would do for you. It's criticism along the lines that "this is so
well written it's worth my time helping you polish it so it doesn't have any
of the tiny flaws that stick out like splinters on an impressively artistic
wood carving."  If the paper wasn't already excellent, I wouldn't be
bothering to point out where you spelled a word wrong.
When you're done, put it up somewhere and put the URL in your resume. This
is the sort of stuff you should be putting in your resume. You do it very
well, and as you say some of your actual paid work doesn't sound very
impressive on a resume and you can't point a URL at the impressive paid work
you do.
>> Add a concluding section, and explain in the abstract why someone
>> might want to read the paper. These are two parts of any paper that
>> are difficult to get right.
> You're telling me...!
Let me give an example of an abstract and conclusion *I* would write for
your paper, just to offer a perspective.
The abstract should say "this is what I'll talk about and why you should
bother to buy/download/read the rest of the paper."  The conclusion should
say "this is what I covered and I expected you to get, and if you didn't,
you should read more carefully.
Again, take this as constructive suggestions from someone who spent years
learning to write this sort of paper, submitting them to panels of editors,
and getting rejected. ;-)
Abstract:
This paper describes a programming technique which is common in functional
languages like Haskell but not widely used in imperative and object-oriented
languages: the construction of combinator libraries. This powerful technique
is introduced by way of the concrete example of a parser for text. Such
parsers are common in all programming languages, so the contrast between the
mechanisms used in functional paradigms with other paradigms will be easily
recognized by programmers unused to functional concepts. Targeting readers
for whom combinator libraries are a new concept, simple common syntax is
used in the examples, leaving the introduction of Haskell's syntax to the
end. No knowledge of Haskell or functional programming is required.
Conclusion:
This paper has introduced the reader to the concept from functional
programming called a combinator, as well as given an example of how
combinators can be collected into libraries to create sophisticated tools
from a collection of simple operations. A combinator library for parsing
strings is developed and explained. The result has a uniquely functional
flavor that is unlike the solutions other paradigms would employ.
   Insanity is a small city on the western
   border of the State of Mind.
Date: 19 Jun 2009 11:23:42
Message: <4a3bad7e$1@news.povray.org>
>> Yay! I suck. :-}
Yeah, pretty much.
> an editor would do for you. It's criticism along the lines that "this is
> so well written it's worth my time helping you polish it so it doesn't
> have any of the tiny flaws that stick out like splinters on an
> impressively artistic wood carving."  If the paper wasn't already
> excellent, I wouldn't be bothering to point out where you spelled a word
> wrong.
Yeah, I got that part. ;-)
> This is the sort of stuff you should be putting in your resume. You do
> it very well, and as you say some of your actual paid work doesn't sound
> very impressive on a resume and you can't point a URL at the impressive
> paid work you do.
That's the plan, yes. It's part of the "portfolio" of (debatably)
well-written documents I'm building. (You might remember the one a while
ago on sorting/searching? I still have that.)
> should say "this is what I covered and I expected you to get, and if you
> didn't, you should read more carefully.
With most of the stuff I write, it's hard to think of a justification
for anybody bothering to waste their time reading what I wrote. But the
conclusion makes sense. ;-)
> Abstract:
> functional languages like Haskell but not widely used in imperative and
> object-oriented languages: the construction of combinator libraries.
> This powerful technique is introduced by way of the concrete example of
> a parser for text. Such parsers are common in all programming languages,
> so the contrast between the mechanisms used in functional paradigms with
> other paradigms will be easily recognized by programmers unused to
> functional concepts. Targeting readers for whom combinator libraries are
> a new concept, simple common syntax is used in the examples, leaving the
> introduction of Haskell's syntax to the end. No knowledge of Haskell or
...damn, you're good. o_O
> Conclusion:
> tools from a collection of simple operations. A combinator library for
> parsing strings is developed and explained. The result has a uniquely
> functional flavor that is unlike the solutions other paradigms would
> employ.
You've done this before. :-P
Hmm... clearly I'm going to have to devote some serious attention to my
existing two documents. ;-)
Date: 19 Jun 2009 11:25:42
Message: <4a3badf6$1@news.povray.org>
Invisible wrote:
> - I put all the technical terms in italics and coloured them blue. Does
> that "work"? Or does it just look like regular emphasis?
That works. Generally, I'd avoid straying from black-and-white for something
like that, only because people might print it in black and white. Since you
use italics for emphasis, perhaps boldfacing the first instance of a
technical term would work well.
> - Does section 3 add anything to the document? Should I make it bigger?
> Should I take it out?
Either expand on it and include at least three examples, or simply conclude
section 2 with "by the way, there are other things this works for, like
financial contracts, expert systems, simulations of physics, ...." or
whatever it works for.
Expanding section 3 to have three or four examples, but squashing each
example into just one paragraph without explaining so much would work best,
in my opinion. I.e., you'd want to say "this works for more than just
parsers" without turning it into a whole nuther paper.
Combinator libraries are useful for much more than just parsers. Many domain
models can benefit from a representation of simple operations infinitely
combinable.
For example, financial contracts are often represented this way. A contract
might have a value which never changes or which changes as a simple function
of time. One combination might be summing the values when building a
portfolio.  Another might be a balloon payment, combining two simple-valued
contracts by switching from one to the other on a certain date. Another
might by an option contract, where the combination has one value until
exercised, after which it has another value. The possible combinations are
legion, allowing for tremendous flexibility in a way that is still easy for
a computer to calcuate.
Then do a couple more paragraphs like that. Maybe an expert system, or a
physical simulation of an electric circuit or something.  I.e., enough to
give the reader a bunch of examples of the simple operations and the types
of combinations for a variety of fields. Then you can conclude with
As the reader can see, using functional techniques to combine a variety of
simple (even trivial) operations in arbitrary combinations is a powerful
technique capable of modeling a variety of both mathematical and real-world
domains.
> - What the hell would a real abstract and conclusion actually look like?
I answered that in another post. I was actually thinking about it during
breakfast. It isn't just newbies whose minds your writing stretches, altho
probably not in the way you had intended when you wrote it. :-)
Date: 19 Jun 2009 11:34:28
Message: <4a3bb004$1@news.povray.org>
>> Does that "work"? Or does it just look like regular emphasis?
> something like that, only because people might print it in black and
> white. Since you use italics for emphasis, perhaps boldfacing the first
> instance of a technical term would work well.
Yeah, bold is generally discouraged because it tends to stand out too
much in the middle of the page. (Hmm, and bright blue doesn't?) I've
also tried slanted on occasion, but it looks too similar to italics. Hmm.
Oh man... you haven't seen the document I'm writing right now! Terms in
blue, source code in red, source comments in green, type signatures in
royal blue, keywords in bold\ldots it's a friggin' technicolour rainbow!
I should probably stop that. ;-)
>> bigger? Should I take it out?
> best, in my opinion. I.e., you'd want to say "this works for more than
> just parsers" without turning it into a whole nuther paper.
Hmm, yes... OK, I'll aim for that then.
> altho probably not in the way you had intended when you wrote it. :-)
Yeah, I saw that.
Which time zone do y-- oh, right.
Date: 19 Jun 2009 11:39:03
Message: <4a3bb117$1@news.povray.org>
Yes. Cool. I bet folks here would help you polish them up again.
It always helps to go back a month later and read it again, too.
Nonsense.
Practice.
In grade school, we started in (IIRC) seventh grade.
7th: Here's the topic. Come back next week with a rough draft of a 2-page paper.
8th: Here's the topic. Come back next week with a rough draft and finished
2-page paper.
9th: Here's the topic. Come back with an outline for a 2-page paper, and
write the paper in class.
By 12th grade, it was "here's the topic. You have 20 minutes to turn in an
outline and finished paper on the subject 2 pages long."
I guess it's unusual, because I keep running into people all thru college
and life that *can't* sit down with a topic (even one they're familiar with)
and just start writing somehting interesting about it.
*That* is the sort of stuff a PhD teaches you, more than anything technical.
Yes.  And think up some abstracts/conclusions for other papers you might
want to fill in some day, and ask "would you read this if this were the
abstract?"
Date: 19 Jun 2009 11:44:55
Message: <4a3bb277$1@news.povray.org>
Small caps?  Courier?  A san-serif font?
When it's lots of colors, people will print it in color. If they just want
to print a copy of a document where three words are in blue, they might not
want to spend the money on color.
Just a suggestion, mind. If you want to turn it into an entire section, that
works too. I *would* suggest more than one example, since that's the point
you're trying to make.
Clever, huh? That's why it's there. ;-)
Date: 19 Jun 2009 11:49:36
Message: <4a3bb390@news.povray.org>
>> while ago on sorting/searching? I still have that.)
Heh, yeah probably. Maybe I'll go look at that next week.
> technical.
Hehe. In the style of XKCD:
"My hobby: Watching professionals at work, and then saying with
suspicion 'you've done that before!' "
>> my existing two documents. ;-)
> abstract?"
Yeah, but... it's *me*! I'll read anything with computing, algebra or
pretty pictures in it. ;-)
Date: 19 Jun 2009 11:52:40
Message: <4a3bb448$1@news.povray.org>
I've tried smallcaps. I'm not sure I entirely like the effect. Courier I
reserve for code, and I abhor sans-serif fonts.
>> in blue, source code in red, source comments in green, type signatures
>> in royal blue, keywords in bold\ldots it's a friggin' technicolour
>> rainbow! I should probably stop that. ;-)
"\ldots"? Jesus, I've written far too much TeX today! o_O
> want to print a copy of a document where three words are in blue, they
> might not want to spend the money on color.
Heh, yeah.
Maybe I should just make the text a sufficiently light shade of blue
that it works in greyscale acceptably?
> that works too. I *would* suggest more than one example, since that's
> the point you're trying to make.
I'm going to have to find more examples...
I think I might mention in passing "comparisons to the Composit design
pattern are left as an exercise for the reader". ;-)
Do you guys still observe DLS?
Date: 19 Jun 2009 12:21:02
Message: <4a3bbaee@news.povray.org>
Nah. As it is is fine, as long as you *also* keep the italics.
Sadly, yes.
Date: 19 Jun 2009 15:36:05
Message: <4a3be8a5$1@news.povray.org>
On Fri, 19 Jun 2009 07:16:52 +0100, Orchid XP v8 wrote:
>>>> Why would we point and laugh? It's very clear and well presented.
>>> Really?
>> Yeah, really.  I read a bit of it (I'm not a hard-core programmer so
>> the topic isn't as much of an interest to me, but I've said it before
>> that you write well and I stand by that assessment).
> Nice that somebody thinks so...
Well, like I said, it's a true statement.  You write well - it's
something you should consider a strength. :-)
>>>> Nits:
>>> Oh goodie.
>> Hey, all people can stand to improve on their writing.  Don't take it
>> so personally - it's called "constructive criticism".
> Yeah, I wasn't completely serious about that comment. ;-)
Fair enough, that means you're learning. ;-)
>> As I mentioned
>> before, professional writers usually use an editor as well because when
>> you write tohusands of words, you're bound to mess some of them up.  It
>> happens to everyone. :-)
> You don't even have to write "tohusands" of words. Apparently. :-P
LOL!  Would it help if I said I did that intentionally?  (No, I didn't
think so, but it couldn't have hurt to ask, could it? <G>)
Jim
