![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 11-6-2009 12:53, Invisible wrote:
> You know when somebody says that something is "astronomically big"?
> ...well, it turns out astronomers use some pretty freakin' big numbers!!
> o_O
> Anyway, I have collected the following series of numbers from Wolfram
> Alpha:
> 1.1 10^11 Number of people who have ever lived.
I don't believe that number. I think if you add all people since the
last ice age you get someting like 10-20 e9. This number also seems to
assume that there have been on average .5-1 million people on this earth
for the past 2 million years or so (half that if you think mankind is 4
million years old). I'd like to see evidence for that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> 6.0 10^23 Number of atoms in 12 g of Carbon-12.
You realize why this number is important, right? :-)
> 8.1 10^53 Number of elements in The Monster Group.
I haven't any idea what this is. :-)
<google> Oh, see, this is the sort of thing I'd have to spend a day chasing
references around to even figure out what this means.
> 4 10^68 Number of H atoms in a "typical" galaxy.
> 4 10^41 Kg Mass of a "typical" galaxy.
68-23=45 45-3=42. One power of ten missing.
> 3 10^52 Kg Mass of the observable universe (exluding Dark Matter).
I wonder if they're just talking about rest mass or what.
Insanity is a small city on the western
border of the State of Mind.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What, Avagadro's number? (Or however the hell you spell it...)
> chasing references around to even figure out what this means.
Apparently, there's a class of groups which can be completely classified
into something like 6 different kinds, except for a small handful of
unique groups that don't fit this classification. The "monster group" is
the largest such - and it's frickin' HUGE!
Wait - you know what a group is, right?
I fail.
I'm fairly sure it's rest mass, yes. Basically, number of atoms times
mass of an atom.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes. You know why anyone cares about Avagadro's number? I.e., what the basic
thing it's measuring is?
Vaguely. I'd have to look up the definition again to be sure I'm not
confusing it with a ring or field or something. My higher-level alegbra is
way old. :-)
> I fail.
No, it just means that either measurements are very sloppy, that "typical"
means something different in those sentences, or there's 10x times as much
mass in a galaxy as their is mass in the H atoms of the galaxy. Which isn't
completely impossible - see "giant black holes", "dark matter",
"relativity", etc.
> mass of an atom.
Yeah. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> basic thing it's measuring is?
Number of atoms? (Or sometimes ions, or subatomic particles of some
kind. Make sure you specify; it kinda makes a difference.)
> is way old. :-)
There's a whole zoo of algebraic systems (I think that's the term) -
monoids, semigroups, groupoids, groups, rings, fields, etc. They're all
essentially the same "thing", just with differing numbers of properties
guaranteed.
Personally, I only bother with fields and groups. A group is closed,
associative, and possesses a unique identity element and an inverse
element for every member. An Abelien group or commutative group is...
self-explanatory, actually?
>> I fail.
> "typical" means something different in those sentences, or there's 10x
> times as much mass in a galaxy as their is mass in the H atoms of the
> galaxy. Which isn't completely impossible - see "giant black holes",
> "dark matter", "relativity", etc.
More likely I copied the number out wrong...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible <voi### [at] dev null> wrote:
> 4.33 10^19 Number of valid combinations for a Rubik's Cube.
I think the correct term is permutations, rather than combinations.
(There *is* a difference between these two terms. They certainly are not
synonyms.)
Btw, the classic Rubik's Cube has about 4.33*10^19 permutations, but if
you mark the pieces such that their orientation becomes discernible and
thus part of the correct solution (relevant only with the center pieces,
but the other pieces also have to be marked in order to distinguish the
proper orientation for the center pieces), the total number of permutations
increases to 8.9*10^22. In other words, there will be a bit over 2000 times
the amount of permutations, making it slightly more difficult to solve.
The Rubik's Revenge has about 7.4*10^45 permutations, ie. about 10^26
times more than the Rubik's Cube. Curiously, though, it's only slightly
more difficult to solve. The solving difficulty is in no way related to
the increased number of permutations.
(The main reason why Rubik's Revenge is only slightly more difficult to
solve than the Rubik's Cube is that the former can be partially solved to
a state where it becomes completely equivalent to the latter, after which
Rubik's Cube solving techniques can be used to solve it. Thus all the
additional techniques you need to solve Rubik's Revenge are the ones needed
to make it equivalent to the Rubik's Cube. Then just solve the it like the
Rubik's Cube.)
(Ok, there's one slight difference: With the Rubik's Revenge it's possible
for a single "edge piece" (which in this case will be an edge piece pair) to
end up in the wrong orientation, which is impossible in the Rubik's Cube.
However, it can be turned around with a fixed sequence which you can
memorize.)
Likewise larger versions of the cube exhibit the same phenomenon: The
amount of permutations grows exponentially, but solving them doesn't
become significantly more difficult. Only the amount of rotations needed
increases with the size of the cube, but the same principles can be applied
to all cubes from 5x5x5 up.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> o_O
Yeah, the US national debt is about $11.3*10^12 ...
or $113 for every star in the milky way,
or $1738 for every person alive on earth,
I guess that makes it astronomically big.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
12 grams of carbon-12. Avagadro's number is the number of neutrons in one
gram of neutrons. 1/A is the weight of a neutron.
They specify "carbon 12" because not all neutrons weigh the same amount, due
to E=Mc^2.
> guaranteed.
Right. I'd have to go look up the details.
That was my memory, yes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
oh good! I tried to mentally count the weight of Frankenstein, Medusa,
Hydra and others but quickly realized it wouldn't quite fit. :)
> mass of an atom.
It's quite heavy. Perhaps we should do a galaxy jump day to relief a
bit of that weight from Atlas' boss' shoulders. ;)
BTW, astromonical was truly devilish... :P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ken wrote:
> "Invisible" <voi### [at] dev null> wrote in message
> news:4a30e22e@news.povray.org...
>> 5 10^22 Number of stars in the universe.
> 5 10^30 Number of bacteria on the planet Earth
> Assuming bacteria is not unique to this planet how many bacteria inhabit
> the known universe?
According to the Hitchhiker's Guide to the Galaxy, the universe is
infinite so it's overall population is 0 because whatever astronomical
number n you put for the number of people/animal/bacteria/whatever it's
still n/universe_size, which turns in n/infinite, thus yielding 0 or
very close. :)
that's why it's so quiet out there... :P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
