![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Kevin Wampler wrote:
> I looked it up and was glad to see that it's still significantly less
> expensive per weight than gold. Of course you don't often use gold as
> an ingredient in food (not that I ever cook with saffron either come to
> think of it.)
Goldschlager.
Oh, and I do have saffron in my spice rack. :D
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Raiford wrote:
> Darren New wrote:
>> Aluminum conducts heat almost as well as copper and is less prone to
>> corrosion and is lighter, so it's a good choice for cookware.
> Wasn't aluminum cookware linked to Alzheimer's?
Yes, mistakenly. They found aluminum in the brain tissue of alzheimer's
patients. Then they realized the dyes they used to detect alzheimers had
aluminum in them.
There's no CD like OCD, there's no CD I knoooow!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> to think of it.)
> Goldschlager.
That exact drink was actually the reason that I put the word "often" in
there. I suspect there's probably a few other dishes where it serves as
essentially a very expensive form of food coloring.
I've never quite been able to convince myself to buy any. Someday I'm
sure I'll spring for it, but given that I mostly live on ramen,
crackers, and pb&j it just seems like a bit much right now.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> OK, so I've been experimenting with Wolfram's Alpha thingy. Useful if
> you happen to want to know how long 10^15 seconds is, if you want a
> graph quickly, or if you want to look up the electrical resistence of
> silicon. Not much use for anything else.
> I did find some interesting information though...
> Alpha claims that the current trading price for gold is approximately
> t. (I had no idea Platinum was so expensive!)
A Troy ounce is 480 grains. There are 7000 grains in a pound. This
makes a Troy ounce about 31.1 grams or so.
> I tried to get similar data for other substances, but Wolfram's "data
> curators" evidently haven't got that far yet. I did find a website
> though that claims that the London Metal Exchange has the following prices:
> Sn $14.325 / Kg
> Ni $13.770 / Kg
> Cu $ 4.776 / Kg
> Pd $ 1.530 / Kg
> Zn $ 1.509 / Kg
> Al $ 1.384 / Kg
I'm rather surprised to see palladium going for $1.53 for a kilogram,
rather than $240 or so per ounce like it does on other sites, so I'd
have to say that Pd is really supposed to be Pb (AKA lead) above.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Right. So 31.1 grams of gold is... a pretty tiny volume, I would think.
>> prices:
>> Sn $14.325 / Kg
>> Ni $13.770 / Kg
>> Cu $ 4.776 / Kg
>> Pd $ 1.530 / Kg
>> Zn $ 1.509 / Kg
>> Al $ 1.384 / Kg
Owned.
Again.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Fredrik Eriksson wrote:
> I prefer iron; cookware that lets you cook *and* work out at the same time.
For anything that needs high, non-localised heat then nothing beats
high-quality iron cookware (take note of Jim Henderson's notes about
seasoning tho'). I've got a cast-iron skillet for steaks and a cast-iron
omelette pan. Neither has ever been washed, just clean with salt, oil
and kitchen paper; they get better as the years roll on.
John (dreaming of the perfect omelette)
"Eppur si muove" - Galileo Galilei
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> aluminum in them.
D'oh!
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On occasion I like to do fun things like make saffron rice...
But, yeah... if your diet consists of mostly ramen and pbj, ;)
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> alzheimer's patients. Then they realized the dyes they used to detect
>> alzheimers had aluminum in them.
> D'oh!
Is this like the thing where they discovered that the police
breathaliser machines were being kept in alcohol to keep them sterile?
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Gold's density is around 19.2 g/cm^3, and so a troy ounce of gold is
about 1.6 cm^3, which is about the volume of four and a half American
pennies. Not a bad way to carry around a few hundred dollars in value.
Just don't lose it.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
