POV-Ray : Newsgroups : povray.off-topic : Computer science Server Time
15 May 2026 21:01:49 EDT (-0400)
  Computer science (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Computer science
Date: 25 May 2009 09:55:25
Message: <4a1aa34d$1@news.povray.org>
Darren New wrote:
> Is there any other field of endeavor where a phrase like
> Like all of my examples it's one of those super-simple examples; small
> enough to be unreal, but hopefully enough for you to visualize what's
> going on without falling into the bog of a real example.
> is common?  Where people teach principles with overly-simplified and
> unrealistic bits because doing it for real is too obscure?
Physics is definitely taught this way.  Problems routinely involve
frictionless pulleys, drag that is a scalar factor of velocity (instead
of velocity squared), and other things that keep the math within the
first-couple-of-calculus-courses domain.
John
Date: 25 May 2009 10:42:45
Message: <4a1aae65@news.povray.org>
> enough to be unreal, but hopefully enough for you to visualize what's going
  How about math? When was the last time you were in a math class where
they discussed a *real-world* example, rather than a simplified artificial
example?
  I think this goes all the way from adding apples to calculating fourier
transforms.
Date: 25 May 2009 12:47:47
Message: <4a1acbb3$1@news.povray.org>
scott wrote:
> It wasn't until University that we solved that one with
> deformation of the surfaces and roughness.
That sounds pretty awesome. We never got quite *that* far. I think our
experiments weren't so precise we had to worry about anything more funky
than the total rolling friction of the cars. We didn't calculate the
deformation of the track or anything like that.
Altho I do remember that at one time I knew how to calculate the speed of
light given the mass and charge of an electron, and why it worked that way.
   There's no CD like OCD, there's no CD I knoooow!
Date: 25 May 2009 12:52:06
Message: <4a1accb6$1@news.povray.org>
> example?
Well, math isn't "real world", so I'm not entirely sure what you refer to.
Unless what you're saying is they don't teach real-world examples of
applying sufficient math to the real world to get real-world useful results?
I.e., they cover math that's too simple to be isomorphic to the real world
behavior of stuff? Stuff like (as your examples suggest) showing the fourier
transform, but not how it works on a real noisy and non-infinite sample?
Date: 25 May 2009 12:57:25
Message: <4a1acdf5@news.povray.org>
> results?
Speaking of which, I studied calculus for something like three years before
I did sufficiently "real" physics to say "Oh, so *that's* what integration
is for."  So, yeah, I guess physics is another one of those. :)
Date: 25 May 2009 13:00:37
Message: <4a1aceb5@news.povray.org>
  Math is exactly as "real world" as programming. After all, there isn't
that much difference between the two.
  You don't see "programs" in the real world. You can *express* some
real-world phenomena with a program, but so can you with math.
Date: 25 May 2009 13:47:03
Message: <4a1ad997$1@news.povray.org>
I see what you mean, yes. And it makes sense, I think, in that the places
where you see oversimplification are similar in both cases. Passing
arguments doesn't get presented in over-simplified ways. Only techniques for
working on million-line programs gets oversimplified. So yeah, math is a
good one.
Date: 26 May 2009 06:21:06
Message: <4a1bc292$1@news.povray.org>
Yeh that's fine for linear motion when you don't accelerate or brake too
hard, but when you are trying to calculate whether the front wheels or rear
wheels will start to skid first during a sharp corner you have to consider
how the tyre deforms.  The simple model you can use is to assume the tyre
surface is like a paint brush - covered in bristles all pointing outwards at
rest, but they have some stiffness (so they can bend in all directions).
The key point then is that when you start to steer (or brake or accelerate)
the bristles in contact with the road will bend a certain way, and the ones
near the edge of the "contact patch" will actually slide across the road
because they have a very low vertical loading.  As you
steer/brake/accelerate harder the % of bristles that are sliding across the
tarmac increase (in a positive feedback loop after a certain point) until
the whole tyre is skidding across the road.
> We didn't calculate the deformation of the track or anything like that.
For railway cars it's exactly the same situation, just that obviously steel
is more stiff than rubber, and the track deforms significantly as well.
> way.
I can't even figure out how a black hole manages to bend light when photons
have no mass :-(
Date: 26 May 2009 07:56:24
Message: <4a1bd8e8$1@news.povray.org>
> photons have no mass :-(
Supposedly it's bending the space through which the light is traveling,
not the light itself.
Tim Cook
http://empyrean.freesitespace.net
Date: 26 May 2009 11:46:06
Message: <4a1c0ebe$1@news.povray.org>
That's cool, yes. I'm sure that people actually engineering cars or trains
go though all that sort of stuff. I don't imagine the teacher would have
assigned the problem if we needed to calculate that sort of thing. :-)
>> of light given the mass and charge of an electron, and why it worked
>> that way.
They do have mass. They just don't have rest mass. Indeed, the color of the
photon tells you its mass. And, in theory, the photons are going in a
straight line, and it's only the spoon ^H^H^H^H^H space that's bent.
