Subject: Re: Watchmen vs The Incredibles
Date: 17 May 2009 18:03:33
Message: <op.ut3gv6or7bxctx@e6600>
On Sun, 17 May 2009 23:35:48 +0200, nemesis
<nam### [at] nospam-gmailcom> wrote:
> The problem I see is that wikipedia simply lacks common sense. Ok, so
> that's a encyclopedia thing.
Exactly. Encyclopedias are not about so called "common sense". They are
collections of verifiable facts, and as such must cite references to said
facts in order to maintain credibility.
From http://en.wikipedia.org/wiki/Wikipedia:Verifiability
"The threshold for inclusion in Wikipedia is verifiability, not truth—that
is, whether readers are able to check that material added to Wikipedia has
already been published by a reliable source, not whether we think it is
true."
> The fact that you have to source someone saying:
[snipped list of perceived similarities]
> rather than simply lookup such info in the works themselves -- pretty
> much a part of popular "inconscient collective" by now -- doesn't sound
> credible.
There is no such info in the works themselves. Nowhere in either movie
does anyone discuss - or even point out - the similarities of the two.
From http://en.wikipedia.org/wiki/Wikipedia:No_original_research
"Editors should not make the mistake of thinking that if A is published by
a reliable source, and B is published by a reliable source, then A and B
can be joined together in an article to reach conclusion C."
> Would the above newsgroups post serve as reference? A blog entry?
They would be considered to be sources of poor credibility at best, and
even that is under the assumption that you start with a phrase like "Some
people have noted similarities...".
"self-published media, whether books, newsletters, personal websites, open
wikis, blogs, Internet forum postings, tweets etc., are largely not
acceptable"
FE
> said facts in order to maintain credibility.
> truth—that is, whether readers are able to check that material added to
> Wikipedia has already been published by a reliable source, not whether
> we think it is true."
What could be more verifiable than the work itself?
>> sound credible.
First: I'm not comparing movies. I'm comparing the movie The
Incredibles with comic book Watchmen and comic heroes Fantastic Four.
I'm not comparing their lame movies with Pixar's masterpiece.
Second: it's not needed words, let alone in the movies itself, to
realize similar plots, similar powers, similar names and similar
uniforms. How does one quote similar imagery? It's just needed common
sense. Why shouldn't a link to an image of Fantastic Four hosted at
wikipedia itself suffice as a "citation" in order to show the similarity
between uniforms and super-powers?
> by a reliable source, and B is published by a reliable source, then A
> and B can be joined together in an article to reach conclusion C."
> "Some people have noted similarities...".
Exactly. I don't think linking to blog posts by fans who know both
works would gain much relevance. They only allow it from the mouths of
the creator or from cinema critics who don't know much about comics.
Despite any evidence or even images.
> open wikis, blogs, Internet forum postings, tweets etc., are largely not
> acceptable"
Indeed.
On Sun, 17 May 2009 18:04:25 -0300, nemesis wrote:
> Nicolas Alvarez wrote:
>> nemesis wrote:
>>> If that's not enough for a link, I'll eat my underwear...
>> Nobody cares how obvious it is. I believe you need to cite sources when
>> you say water is made of two hydrogen atoms and one oxygen atom.
> I clarified this already elsewhere: I tried being more polite a second
> time and just listed the shared plot points in the critics sections
> rather than plainly suggesting inspiration.
Maybe they decided that since you'd already tried one version that came
out and said it was the inspiration without documentation that further
attempts would be non-objective.
> Still, the only source I can find is the book itself. You read it and
> you realize the plots are very similar.
"Similar" and "inspired by" are two different things. We've been over
that before.
Jim
The work doesn't state its inspiration. The work is the work, not a
"making of the work" work.
Jim
Date: 17 May 2009 19:01:36
Message: <op.ut3jkxtn7bxctx@e6600>
On Mon, 18 May 2009 00:31:19 +0200, nemesis
The work itself does not provide any comparison to other works.
Irrelevant. There are no such comparisons in the comics either.
> sense.
Again, encyclopedias are not about "common sense".
*You* have looked at the movies/comics.
*You* have noticed similarities.
That is called "original research", in this case performed by you. Unless
you can get this "research" published in a credible medium, you will need
other sources to back up your claims.
The fact that others may share your opinion is irrelevant, unless one of
them gets it published in a credible medium.
> Why shouldn't a link to an image of Fantastic Four hosted at wikipedia
> itself suffice as a "citation" in order to show the similarity between
Because similarity is a matter of opinion. Also, an encyclopedia cannot
credibly cite itself.
> I don't think linking to blog posts by fans who know both works would
Because they are not considered credible. Neither are you, for much the
same reason.
> They only allow it from the mouths of the creator or from cinema critics
Citing the creator is only credible if the point you are backing up is
"The creator said...".
Citing movie critics is only credible if the point you are backing up is
"Some movie critics are of the opinion that...".
An encyclopedia is not the proper medium for presenting evidence.
FE
"nemesis" <nam### [at] nospam-gmailcom> wrote in message
news:4a10508b$1@news.povray.org...
> He also denies Fantastic Four, but still you have a family quartet with:
> * similar name for the heroes (Incredible/Fantastic)
I take it "Average Joe" was taken.
> * similar uniforms (different color, i instead of 4)
Besides being both super-dorky, as is common to the genre, how are these
uniforms in any way or form similar?
http://en.wikipedia.org/wiki/File:Tiposter.jpg
http://en.wikipedia.org/wiki/File:Watchmencharacters.jpg
> * a super-strong being (Mr. Incredible/The Thing)
A super-strong being in the super hero comic. What are the odds!
I don't doubt there are similarities. And you might be even correct about
direct inspiration. But it's probably next to impossible to prove anything
within such a formula based genre. I am afraid it looks like you are letting
your good judgement be clouded by your contempt for Disney and adoration of
Moore.
I was talking in the context of Fantastic Four.
The odds are as low as finding one right next to an elastic one and an
invisible force-field generating another in the very same quartet with a
very similar dorky costume design.
> Moore.
Fantastic Four has nothing to do with Moore. It was Marvel Comics first
successful comic book and has spanned a well-known comics doomsday saga
in the form of the Galactus/Silver Surfer one.
I just find it truly hard to believe people would go on to create a
super-heroes animation and not pay homage to/be aware of some of the
best known works in the genre, that's all.
And there's far more comic book references one can distil, for instance:
* the villain Bomb Voyage looks a lot like Batman's The Joker down to
the large maniacal smile;
* Frozone has similar powers to X-Man Iceman. This is acknowledged in
wikipedia, despite no references.
* Gazerbeam has similar powers and similar mask to X-Man Cyclops.
Someone removed the similarity I one saw in wikipedia.
* Rick Dicker, a government agent in The Incredibles looks a lot like
Richard Nixon, which is a prominent figure and still in power in
Watchmen's alternate universe. The name itself sounds like a pun.
* Mirage has the looks of X-Man Tempest
* Mr Incredible and Frozone are seen remembering old times in the car by
laughing over old villains. This scene is pretty much the same as in
the opening chapter of Watchmen, with retired Nite Owl and Nite Owl II
having a similar talk. Page 9 to be exact. You can read this one in
chapter one of Watchmen for free on DC's own site:
http://www.dccomics.com/media/excerpts/1462_1.pdf
But I was only interested in Watchmen so far because it turns out I only
read it now before going to see the movie.
I think by now it's pretty much clear that I dropped altogether trying
to imply The Incredibles is *inspire by* Watchmen and was just trying to
list the plot points similarities, right? Which is not possible, either.
Fine.
"hard to believe" isn't proof, though. You seem to be missing that point
- belief != proof.
Jim
