POV-Ray : Newsgroups : povray.off-topic : Another Vista stupidity Server Time
16 May 2026 00:36:23 EDT (-0400)
  Another Vista stupidity (Message 31 to 40 of 42)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Another Vista stupidity
Date: 15 May 2009 14:41:22
Message: <4a0db752$1@news.povray.org>
On Fri, 15 May 2009 19:28:27 +0100, Orchid XP v8 wrote:
> Nicolas Alvarez wrote:
>> Warp wrote:
>>>  Not even big rich companies are safe
>>> from this kind of tampering (just ask Sun Microsystems).
>> Sun isn't a big rich company anymore, though :)
> Yeah - I heard an unsubstantiated rumour that Oracle bought them...
It's not an unsubstantiated rumour - it's a fact:
http://www.oracle.com/sun/index.html
http://www.sun.com/aboutsun/pr/2009-04/sunflash.20090420.1.xml
Jim
Date: 15 May 2009 17:20:14
Message: <4a0ddc8e$1@news.povray.org>
...OK, so now it's substantiated rumour.
It still doesn't make any sense to me though. Sun is multiple times
larger than Oracle - so how was Oracle able to buy them?
http://blog.orphi.me.uk/
Date: 15 May 2009 17:26:15
Message: <4a0dddf7$1@news.povray.org>
It's not a rumour.  It's a fact, Sun is being bought by Oracle.
Because Sun isn't as big as it used to be, and Oracle is bigger.
That said, smaller companies do buy bigger companies from time to time.
I worked for a large food & drug retailer here in the US that got bought
by a smaller (by about 50% if size is measured by "number of stores")
company.  They were able to afford it.
And the management was looking to sell.
Jim
Date: 15 May 2009 17:31:25
Message: <4a0ddf2d$1@news.povray.org>
Also, look at the market caps for the two companies:
Oracle, based on stock price today, is $91.79 Billion.
Sun, based on stock price today, is $6.72 Billion.
IOW, Oracle's market cap is just over 13.5 times Sun's = another measure
that Oracle is much bigger than Sun.
Jim
Date: 15 May 2009 17:36:14
Message: <4a0de04e$1@news.povray.org>
Is this before or after the buyout was announced? ;-)
Besides, I was under the impression that a stock price is simply an
arbitrary figure plucked out of thin air and having no particular
relation to reality...
Date: 15 May 2009 18:00:59
Message: <4a0de61b$1@news.povray.org>
>> measure that Oracle is much bigger than Sun.
The purchase price was around the $6.72 billion, so before.  Mergers and
acquisitions often mess with the stock price, but generally not very much
- depending on whether the shareholders see it as a good thing or a bad
thing.
It's not "picked out of thin air", but based on what the market values
the company at and the outstanding number of shares at any given time.
It's not particularly arbitrary.
Jim
Date: 15 May 2009 20:49:12
Message: <4a0e0d88$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Warp wrote:
>>>   "How do I do that?" Right, he was in Windows, and there's no diff in
>>> Windows. We pondered for a moment what would be the easiest solution.
>> Download diff for Windows? :-)
>   That's precisely the problem I was talking about. *Nothing* comes with
> Windows by default, and for everything you would have to search and download
> some third-party, non-standard utility which might or might not do what you
> want.
>   (Additionally, Windows' command prompt just isn't as easy to use as
> unix's. It's just a PitA to try to do anything in it.)
Yeah. Just one example: 4DOS.
Features, if you can even find a copy that isn't pay to use any more, or
one at all (I haven't looked recently):
1. ANSI support built in to the command.com replacement.
2. Color coding of files by type.
3. File sorting and other options.
4. List command, so view > 32k files, a page at a time, with the ability
to do searches in the text *and* go forward of back in the file (built in).
5. Other stuff I don't remember.
MS' solutions?
1. Sorry, not even supported, as far as I know, as a "functional" part
of the command line even in XP, Vista, or likely 7. You can hunt down
some third party file from PC World, or someone, which was written in
the 1990s, and use that to get ANSI support. Otherwise, its only
available via ansi.sys, if you boot into DOS mode.
2. Woops... This won't work without #1, so you are SOL.
3. Umm.. Kind of, if you string a lot of files together. I think they is
a sort function in the DOS utilities, though I don't think it comes
"with" Windows, and I doubt you can find DOS any more. But, it would
work something like, "dir {flags for the stuff that is supported} | sort
| more", easy... As long as you don't want "any" bloody real control
over what is going on in those steps, and you don't mind looking up sets
of commands flags you never use, for 2-3 utilities. You, well... can't
do some of it at all in the GUI, not really, at least not as cleanly, or
clearly, as you can in the prompt.
4. Lets keep using QBASIC running in "EDIT" mode (this is literally
their solution), until we have Notepad, then give Notepad the same 32k
limit, and keep it that way, and as the "default" txt file reader, until
XP, and worse, only allow it to "recognize" .txt as a valid extension,
so you can't open any other text files. Oh, and.. lets **never** bother
to implement a way to read non-DOS files, which don't use the CR+LF
method of terminating lines.
5. You name it, they either ignored it, or made up their own, which
doesn't work like anyone else's. Such as, who in their right mind would
want VBscript or Jscript as the command line script system, even if...
again, they didn't bother even "supplying" something more interesting
than .bat files until XP came out? lol
Not made for developers? Its not made for anyone with any clue at all,
and that includes people that where doing things under DOS, near the end
of its life, which are "vastly" superior to everything they provide
"today" in the same command prompt.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 15 May 2009 21:26:08
Message: <4a0e1630$1@news.povray.org>
What do you mean "file sorting"? Sorting the contents of a file, or sorting
directory listings? Both come with Windows.
> | more", easy...
Um, why doesn't that work?  And why wouldn't you just pass the flags to dir
to make it do the sorting?
So, you're complaining that *DOS* is lame because you have to know what the
command flags are to make the commands to things? Have you looked at the
size of the bash man page lately? ;-)
> their solution),
Uh, until maybe 15 years ago, yes.
> until we have Notepad, then give Notepad the same 32k limit,
Until you had the 386....
> and keep it that way, and as the "default" txt file reader, until XP,
Possibly. SO you're still bitching about an OS that's two generations out of
date?
Always amused to see people complaining about things they don't know
anything about. As far as I know, that's *never* been the case. I used
notepad to edit .exe files back in Win3 days.
Cause, like, you don't even know what you're talking about, but you'd best
bash it, right?
Probably anyone that worked with VB before? Like Windows developers?
   There's no CD like OCD, there's no CD I knoooow!
Date: 17 May 2009 15:52:40
Message: <4a106b06@news.povray.org>
Wrong, you can print colors in a Windows console. You just can't do it with
ANSI codes. A 'dir' that prints color is still possible.
'dir' has switches to sort by different criteria. There is also a 'sort'
command that works as a filter you can pipe stuff into.
Date: 17 May 2009 16:10:05
Message: <4a106f1d$1@news.povray.org>
Indeed, I've posted (Haskell) source code to do it.
> You just can't do it with ANSI codes.
...despite certain sources claiming that you can. (Apparently it used to
be possible, but isn't any more.)
