POV-Ray : Newsgroups : povray.off-topic : A tricky rendering problem Server Time
13 Sep 2025 00:47:58 EDT (-0400)
  A tricky rendering problem (Message 14 to 23 of 23)
Subject: Re: A tricky rendering problem
Date: 8 Apr 2009 16:07:46
Message: <49dd0412@news.povray.org>
>> Oh, you can even add labels to the edges directly withput having to
>> add a node :-)
>> If edge order is important apparently adding ordering=out at the graph
>> level will draw the outgoing edges of each node in the order they are
>> encountered. Of course this will possibly create more edge
>> interesections than necessary...
> That's interesting. I'll have to take a look at that.
This is the best I've managed to come up with so far using dot. It's
still not perfect, but it's just about readable.
http://blog.orphi.me.uk/
Download 'fibs3.png' (21 KB)
Preview of image 'fibs3.png'
Date: 8 Apr 2009 16:28:41
Message: <49dd08f9@news.povray.org>
Invisible wrote:
> OK, well that's pretty smooth looking. Certainly neater than what my
> program produced.
> The only thing I can think of is that maybe last time I tried dot out
> while I was trying to do really complex mind maps and the vast number of
> nodes and dense interconnections upset the layout algorithm. Certainly
> your examples seem to be laid out just fine.
Case in point: see attachment.
It appears that the problem is that neato produces ridiculously bad
layouts. The dot program seems to actually do quite well, generally.
Download 'haskell1.jpg' (110 KB)
Preview of image 'haskell1.jpg'
Date: 8 Apr 2009 16:42:36
Message: <49dd0c3c$1@news.povray.org>
Vincent Le Chevalier wrote:
> You might take a look at GraphViz if you haven't done so already:
> http://www.graphviz.org/
> I bet you'd find in their papers plenty of ideas to make a better
> rendering... Assuming you want to do it by yourself and not just use
> existing tools.
I'm currently looking through
http://www.graphviz.org/Documentation/TSE93.pdf
which describes the layout algorithm for dot.
Amusingly, many of the algorithmic steps appear to be identical to what
I came up with myself. Specifically, cycles in the graph are broken
internally, nodes are arranged into "ranks" (rows), and then the
positioning algorithm decides where to put them. All of this is
*identical* to my own program. What I don't have is a special
algorithmic stage to rearrange the nodes (since I explicitly don't
*want* their horizontal positioning rearranged for these particular
graphs), and a stage for properly routine the edges (which is why they
keep intersecting things).
It's... encouraging to know that I accidentally managed to get so much
nearly right.
Date: 8 Apr 2009 21:50:01
Message: <web.49dd53e5c22165a3bbbb20030@news.povray.org>
[snip]
> nearly right.
Well, algorithmic ideas for many problems are almost always intuitive and
straightforward enough and only implementations differ.
The real question is:  is it in Haskell? :)
Date: 9 Apr 2009 04:17:11
Message: <49ddaf07$1@news.povray.org>
>> nearly right.
I don't know about that.
You have a tree of nodes. You need to place them so they don't overlap.
How do you do that?
It wasn't at all obvious to me how to do that. In fact, my layout
algorithm takes each subtree and draws an invisible box around it, large
enough to contain the entire subtree. This results in many nodes being
shoved too far left or right - much further than actually necessary.
There's probably a way around that, but I haven't found it yet.
Well *duh*! :-P
Date: 9 Apr 2009 09:26:14
Message: <49ddf776@news.povray.org>
> I came up with myself. What I don't have is a special
> graphs), and a stage for properly routing the edges (which is why they
Mmm, how ingenious. They add extra "invisible" nodes to each row that an
edge passes through, and then jiggle the invisible nodes around as a
means for deciding how to route the edge.
Of course, they then apply a complex algorithm to decide exactly how to
produce the best possible spline path through the general area reserved.
I doubt I'll go to that much trouble. But I could certainly use
invisible nodes to avoid unecessary intersections...
Date: 9 Apr 2009 09:42:20
Message: <49ddfb3c@news.povray.org>
OK, now *that* is interesting... I'm using a newer version of GraphViz
at work, and the same input gives a radically different result:
Download 'fib1.png' (25 KB)
Preview of image 'fib1.png'
Date: 9 Apr 2009 12:00:01
Message: <web.49de1b17c22165a3bbbb20030@news.povray.org>
> Well *duh*! :-P
That's a cool real-world application for it. :)
Date: 11 Apr 2009 20:46:34
Message: <49e139e9@news.povray.org>
>> nearly right.
Which is why software patents shouldn't exist.
Date: 11 Apr 2009 23:20:00
Message: <web.49e15ceac22165a3bbbb20030@news.povray.org>
> >> nearly right.
Indeed.  You know using xor for operations on screen was once patented, don't
you? :P
