POV-Ray : Newsgroups : povray.off-topic : Arrrgggh! Server Time
14 Oct 2024 21:22:54 EDT (-0400)
  Arrrgggh! (Message 1 to 10 of 21)
Subject: Arrrgggh!
Date: 18 Mar 2009 23:35:14
Message: <49c1bd72$1@news.povray.org>
Damn. Two hours to figure out you can paste a 680-row table from Excel into
Word and it works as documented, but a 1300-row table from Excel into Word
pastes the table but neither formats it the same way as the table you're
appending nor is responsive to changing the table. Bleh bleh.
The first one worked just right, once I figured out how to do it. I spent 2
hours trying to get the second one, trying to figure out what I did the
first time that I missed the second time. Easy - "do it 700 rows at a time
instead of all at once."
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Subject: Re: Arrrgggh!
Date: 19 Mar 2009 11:15:00
Message: <web.49c26157687c6b3af708085d0@news.povray.org>
Yeah, I always knew there was *something* brain-dead about pasting Excel tables
into Word...
I gave up a while ago, and resorted to pasting the contents into a pre-sized and
pre-formatted table with at least *one* row more than I'm about to insert, and
after the paste operation copy the format from that one untouched row to the
pasted-in ones to fix the formatting again...
What's been annoying me most is that Word *does* seem to adjust the table
formatting according to the Excel table format, there's *nothing* you can do
about it, while the adjusted format *never* seems to bear *any* similarity with
the Excel formatting whatsoever (that would be *something* at least).
Yuck!
Or, as you put it: "Arrrgggh!"
Date: 19 Mar 2009 11:32:29
Message: <49c2658c@news.povray.org>
  Maybe you will admit that MS doesn't *always* make their programs perfect?
Date: 19 Mar 2009 11:34:08
Message: <49c265f0@news.povray.org>
Try this:
Copy your spreadheet to the clipboard. Go to Word. From the Edit menu select
Paste special and select Microsoft Office Excel....
Date: 19 Mar 2009 11:55:00
Message: <web.49c269d9687c6b3af708085d0@news.povray.org>
"Halbert" <hal### [at] gmailcom> wrote:
> Try this:
What version of Word do you have in mind?
With my version (the Office XP one) there's either no such menu item, or it
didn't do what I needed it to do.
I'm perfectly sure that if it is there I have tried it, only to get all the more
frustrated.
Or are you talking about the thing that lets you *embed* Excel tables into Word
documents?
As far as I recall, that did seem to do what it was *intended* to. But it wasn't
what I *needed* either.
Date: 19 Mar 2009 12:04:16
Message: <49c26d00@news.povray.org>
> wasn't
Embedding the table is the best bet for keeping the formatting exactly as
you intended, plus it keeps all formulas active so you can update later if
needed without having to go back to the original Excel file, update, then
copy & paste again.  Don't know how it works with multi-page tables though,
my experience comes from copy&pasting from Excel into PowerPoint, not Word.
Date: 19 Mar 2009 12:04:35
Message: <49c26d13@news.povray.org>
My version is Word 2007. If you have the newer confusing menus like I do
then it should appear like this.
"clipka" <nomail@nomail> wrote in message
news:web.49c269d9687c6b3af708085d0@news.povray.org...
>> Try this:
>> select
> it
> the more
> frustrated.
> Word
> documents?
> wasn't
Download 'word paste.JPG' (42 KB)
Preview of image 'word paste.JPG'
Date: 19 Mar 2009 12:20:00
Message: <web.49c27029687c6b3af708085d0@news.povray.org>
- I don't *want* the formulae in there, I want the plain values.
- Embedding the table opens up another can of worms: How, for instance, to get
rid of those column and row headers?
- Word is much more flexible when it comes to formatting, so I'd prefer to
define a table in Word and just throw in the data from Excel.
One would think that it would be a piece of cake... but no: You can insert the
whole smash as a new table; you can insert the whole smash into the existing
cells using the source format (or what Word makes of it); you can insert the
whole smash using the destination formatting - but then Word pastes it all in a
single cell (duh! That's what I call BS).
Why the Holy Moly doesn't MS seem to consider this a frequent enough use case to
make it possible somehow? You get all the fancy stuff in the dropdown list you
can pop up after inserting, but *this* one is not among them.
Ah well, I stopped bothering about the answer, and just shake my head instead...
Date: 19 Mar 2009 13:04:16
Message: <4nu4s49n5bl5mtvc4kqphhked0blic4oec@4ax.com>
I'm using Word 2002 and it works for me. Although I have to use paste special
from the menu. Edit > Paste Special
Regards
Date: 19 Mar 2009 14:07:42
Message: <49c289ee$1@news.povray.org>
> into Word...
Actually, if it's small enough, it works in a way that seemed quite
intuitive to me. Especially after I peeked at the help pages.
Ah! I hadn't thought of the extra step of pasting just the format from the
untouched row. That probably would have worked too. However, when I did
that, I found it put extra spaces from the excel sheet into the cells,
meaning that they wrapped in a way I wasn't allowed to let them wrap
(because the table columns had to fit the predefined field lengths).
In Word 2003, at least, just putting the cursor right after the table
enables a menu option that says "paste appending to current table" or some
such. It pastes it in, and then there's a lightning-bolt thingie that offers
to format it the same as the destination table or to keep the source
formatting, defaulting to the former.  And then you can get the footer on
there just by "split table" first, paste in, then delete everything between
the foot and the new table and you're golden.  Easy, *when* it works.
(And I spent 20 minutes figuring out how to insert 1200 blank rows, too. :-)
If you paste it into cells, that's true. If you put the cursor right after
(or before) the existing table and paste, it formats it correctly.
