POV-Ray : Newsgroups : povray.off-topic : This is the sort of brokenness... Server Time
25 Jun 2026 05:52:29 EDT (-0400)
  This is the sort of brokenness... (Message 105 to 114 of 164)
Subject: Re: This is the sort of brokenness...
Date: 19 Mar 2009 18:34:57
Message: <49c2c891$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>>>> I'm saying that C++ does not enforce that you don't change private instance
>>>> variables from outside the class.
>>>   And this has exactly what to do with whether (compiler-enforced) data
>>> hiding is a good thing or not?
>> Because there's two reasons for data hiding: (1) allow more flexibility in
>> implementation, (2) allow easier debugging.
>> If you can violate my encapsulation, I don't see the data as especially
>> encapsulated, is all.
>   You didn't answer my question.
You said the designs of C# and Java are badly broken because they let you
get to the private variables of an instance using reflection. You then said
C++ doesn't let you get to a private variable of an instance. I was
disputing that claim. That's what compiler-enforced data hiding has to do
with C++.
>   "Is enforced data hiding a good thing or a bad thing?"
>   "In C++ you can bypass the encapsulation, so it's a bad thing."
You skipped a bunch of context in between that I thought still applied.
Maybe you're reading messages in a different order than I am. That's one of
the problems when a conversation really gets going online. :-)
If you're not going to apply that context, see my other messages where I
explain the types of access and seem to be mostly in agreement with you.
>>>   Every single discussion about programming with you turns into C++ bashing,
>>> no matter what the subject.
>> I'm happy to bash any other unsafe OO language you might want to name. :-)
>   It's getting really tiresome and old.
I didn't start out bashing C++ this time. We got pretty far until you
*seemed to* claim C++ was better at modularity than C# or Java or CLOS. I
merely listed C++ amongst a half-dozen languages I was criticizing for
different individual design choices.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 19 Mar 2009 18:55:18
Message: <49c2cd56$1@news.povray.org>
>>>   That's the whole idea in modular thinking: You don't know what's inside
>>> the module, and you *don't care*. You don't need to care.
>> It also prevents code from *inside* the module from doing certain things in
>> an easy way.
>   Everything in the class is public to the class itself. I don't understand
> your point.
I can use reflection to iterate over my own member variables without
breaking modularity. I can use reflection to look at the documentation of
other classes without breaking modularity. I can use reflection to
instantiate an instance of a class whose name is in a string without
My point is that not all uses of reflection are kludgey, and including it in
a language doesn't mean the design of the language is badly broken.
For further examples, peek at the Google API for database interaction on
Google App Engine. For example, looking at
http://code.google.com/appengine/docs/python/gettingstarted/usingdatastore.html
you can see how a "Greeting" class is declared, a "greetings"
list-of-greeting is created by db.GqlQuery(), and later the elements of that
list are accessed via greeting.author syntax. How does db.GqlQuery() create
a greeting instance and fill in the author based on the names of the rows of
the database? Reflection.
>   So your solution to the problem of being able to modify private members
> by accident because of the language being unsafe is to make the language
> safe... and to make everything public (with a naming convention of
> variables).
>   I don't see how the latter follows.
No. Making it safe and not making everything public and not needing naming
conventions is best. That's what CLOS does, modulo reading the source and
invoking interpreter-internal routines with the names of private variables.
That's what C# does, modulo the reflection libraries. That's what C++ does,
modulo using pointers and UB.
It would be better, of course, if languages like Python didn't expose
private variables unless you were intentionally doing meta-programming. But
Python has all kinds of hacks to let you control access to variables. For
example, there's even a case where if you type
    x = y.z
and y.z's *value* has a method called __getvalue__ (or some such name) then
the return value of invoking that method is what actually goes into x. So,
yeah, there's a lot of non-OO stuff going on there.
>> I'm just less worried about intentionally violating modularity than
>> accidentally doing so.
>   Problems with programming errors in unsafe languages has nothing to
> do with the subject of modularity.
I disagree, as I've explained. There's two aspects to modularity, only one
of which is addressed by unsafe languages.
>   Accessing something out of boundaries by accident is always a bug
> regardless of what effects that has. This has nothing to do with whether
> modularity is a good thing or not.
Modularity is a good thing. The inability to violate modularity by mistake
is a good thing, don't you think?
>> (I've had server code written in unsafe languages where it would dump core
>> on a segfault, and the providers wanted to blame it on the fact that the Xen
>> kernel was on the machine. We weren't booting Xen, but they wouldn't even
>> look at their code until we uninstalled that kernel. Just as an example of
>> how people can avoid admitting their own bugs might be part of the problem.
>   And this has what to do with the original subject?
That when modularity can be accidentally violated, it can be difficult to
debug, in part because those with the accidental bug can be reluctant to
admit they have a bug when it's actually the violated module that's crashing.
Again, the point is there's two parts of modularity: future upgrade
proofing, and class invariant maintenance. I think they're both important.
You seem to be completely ignoring any discussion of the second part.
>   You always succeed in returning to your favorite subject: Bashing
> "unsafe" languages. And in your world there's only one such language: C++.
Not at all. Lots of unsafe languages are out there - C and assembler both
spring to mind. I don't know of many unsafe OO languages, is all. C++ is the
only OO language I know where the default operation of the language is to be
unsafe, rather than it being used as a well-labeled escape hatch where
necessary for performance. Doing unsafe things when you declare them after a
#pragma UNSAFE
for example doesn't seem to be a "kludge" in the language design to me.
Date: 19 Mar 2009 19:07:06
Message: <49c2d01a$1@news.povray.org>
> it in a language doesn't mean the design of the language is badly broken.
Oh, and a lot of these language use reflection to implement debuggers,
performance monitors, and unit test frameworks. :-) None of which I'd call
kludges or violations of modularity.
Funny enough, every Python class and method has documentation that's
included in the class (in a member called "__doc__"). There are python test
frameworks that go thru all your classes and members, finding the document
strings, looking for something that looks like the result of running tests
interactively in the doc string, then runs the tests and compares the results.
http://docs.python.org/library/doctest.html
The stuff in the blue strings, with >>> marking the calls (which is the
default python interactive interpreter prompt) gets run by this library,
which then tells you what failed after comparing the results to the
documentation.
In this case, the documentation for the class includes its own simple tests,
which I thought was pretty cool.
Sure, you can do all this sort of stuff with preprocessors generating code,
but that's just because compilers have all the information that reflection
is supposed to make available.
As an aside, there's actually a lack in the terminology. I use the term
"reflection" to mean looking at the source code while it runs, and
"introspection" to mean looking at the process while it runs. So the
question of "what member variables does class XYZ have" is reflection, and
"what's the name of the method two stack frames up from here" is
introspection. Unfortunately, I don't think I've convinced anyone else to
make that distinction. :-)
Date: 19 Mar 2009 21:50:00
Message: <web.49c2f58411b2c18810409b140@news.povray.org>
> OK. I was confused by the fact that your post had
> 1) A paragraph about how CLOS allows access to the private variables,
> 2) a comment about languages lacking data hiding aren't really OO,
> 3) a lack of specific support for hiding means the OO is kludgey.
Me too.
Date: 19 Mar 2009 22:12:25
Message: <49c2fb87@news.povray.org>
Warp wrote:
> Nicolas Alvarez <nic### [at] gmailcom> wrote:
>> Instead of using private:, you could just add an underscore to internal
>> variables.
>   But why would I want to do that? There's no benefit. There are only
> potential disadvantages.
Because Python has no real "private", and in practice the underscore seems
to work well enough.
Date: 19 Mar 2009 22:15:20
Message: <49c2fc38@news.povray.org>
Warp wrote:
>   I still can't comprehend what's so bad in the compiler doing the check
> that you don't access the private members.
It's not bad to have the compiler do that, it's good.
But some languages don't have that feature, and that doesn't make them bad
either.
Date: 19 Mar 2009 22:19:26
Message: <49c2fd2e@news.povray.org>
> variables. That's what C# does, modulo the reflection libraries. That's
> what C++ does, modulo using pointers and UB.
That's not a good comparison.
C# has a way to access private data through reflection. Python has a way to
access private data by just doing it (but you'll know you're doing it
because there is an underscore).
C++ has no way to access private data. If you say pointers and UB are
a "valid" way to access private data, then I'd say attaching a debugger to
the .NET virtual machine and poking at its memory is a valid way too.
Date: 19 Mar 2009 22:21:34
Message: <49c2fdae@news.povray.org>
Warp wrote:
>   It breaks modularity badly. The whole idea of data hiding is that the
> private part should be completely opaque to the outside. The second it
> isn't, outside code will start making assumptions, and you can't change
> the implementation of the class anymore.
You CAN change the implementation of the class. It's not your problem if you
break code that made assumptions.
Date: 19 Mar 2009 22:57:13
Message: <49c30609@news.povray.org>
memcpy. Check the standard under 3.9. It's therein defined how you can
access and modify the private data of a class in C++ (and in a
standards-conforming way if it's POD). Consider the case of "class alpha
{int abc;}" for a counter-example - I know exactly how that's laid out due
to the standard. It's perfectly standard-conforming to pass a pointer to an
instance of class alpha to both memcpy and memset.
In any case, C++ *DOES* in *practice* have a way to access private data,
even without that, because it's not safe. It's not clean and portable, but
if there wasn't any way to access private data, we'd have far fewer sigsegv's.
I guess there's two ways you could argue it:
1) C++ in theory disallows access to private variables but in practice every
known implementation allows it, because it's actually virtually impossible
to follow the rules of the standard while disallowing said access.
2) LISP in theory allows access to private variables even though it's
impossible to do by accident and you have to read the source for the
implementation of the class (which you might not have) to learn the
variables. (Actually, has anyone checked whether the Common Lisp standard
actually guarantees you'll be able to get to private variables, or is that
just the current implementations?)
Sure, in theory, great.
In practice, nobody uses a C++ compiler that prevents access (intentional or
otherwise) to private variables, and in practice, nobody uses private
variables of a class that haven't been exported except as a last resort.
Since we're talking about practical benefits (like being able to modify
code), I was taking the latter approach.
In any case, even if we took reflection out of C# and Java, it's still
possible to declare unsafe pointers in C# and "native code" in Java that can
change private variables in a more-or-less well-defined way. Except you're
now doing it exactly the same way as C++ would, except for the fact that
again you've flagged your source code as "hey, I'm doing this on purpose".
I'm not sure how that should "count".
Date: 19 Mar 2009 23:56:03
Message: <49c313d3@news.povray.org>
You know something?  It's getting "really tiresome and old" that every time
I list problems with 5 or 6 different languages, you think I'm bashing on
C++. It's getting "really tiresome and old" that every time I point out
something that Windows does well, I'm told I'm bashing on Linux. It's
getting "really tiresome and old" that every time I point out problems with
unsafe languages in general, you think I'm bashing solely on C++. It's
getting "really tiresome and old" that every time I talk about automatic
resource management you think I'm bashing C++. It's getting "really tiresome
and old" that most times you tell me I'm ignorant and I ask you for more
information, you ignore that request, preferring just to insult me rather
than actually provide information that might improve the conversation.
I think I've expressed my point of view, and I think you all understand what
I'm saying but for some reason feel the need defend C++ instead of
discussing the pros and cons rationally and conversationally. I can't add
any further information by pursuing this conversation, altho I've left
several questions open in various posts that could be productively answered.
