POV-Ray : Newsgroups : povray.off-topic : Standard libraries Server Time
30 Jun 2026 22:13:21 EDT (-0400)
  Standard libraries (Message 51 to 60 of 108)
Subject: Re: Standard libraries
Date: 7 Mar 2009 06:50:13
Message: <49b25f75$1@news.povray.org>
Mike Raiford wrote:
> Invisible wrote:
>>> Sounds like they drank the OSS flavored kool-aid.
>> I have no idea what the heck kool-aid is, but... yes.
> Read http://en.wikipedia.org/wiki/Drank_the_kool-aid it's interesting,
> and gives the source for the expression.
http://en.wikipedia.org/wiki/Kool-Aid#.22Drinking_the_Kool-Aid.22
Tor Olav
http://subcube.com
Date: 7 Mar 2009 11:54:38
Message: <49b2a6ce$1@news.povray.org>
Warp wrote:
>   Now that you have "proven" that C++ will not have "true" lambda functions,
> you must be exhilarated.
Not really, because I don't wrap my sense of personal worth around the
features of programming languages I use or don't use.  I'm not sure why
discussing C++ puts you so off.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 7 Mar 2009 11:56:13
Message: <49b2a72d$1@news.povray.org>
nemesis wrote:
> It also features much cleaner syntax and semantics.  uplevel?!  frankly... :P
That too. And complex data structures, because they do both GC and pointers.
Python seems much nicer than Tcl. I just can't use a language that doesn't
(for example) support Unicode in preference to one that does, due to the
sorts of things I program. Now that Python has integrated all those things
cleanly, I'll start using it more.
Date: 7 Mar 2009 12:08:19
Message: <49b2aa03$1@news.povray.org>
Warp wrote:
>   Says the person who didn't even know how lambda functions will be
> implemented in the next C++.
Nonsense. The limitations of the undefined behavior tell me they're not
going to be implemented by allocating the stack onto the heap, for example.
>   I like it how you succeed in making *everything* sound negative when
> applied to C++, while at the same time the *exact same thing* is positive
> in other languages.
Huh?
>   For example, generics in Java being "just syntactic sugar" is a positive
> thing, while lambdas in C++ being "just syntactic sugar" is a negative thing.
What makes you think the fact that generics in Java being syntactic sugar is
a good thing? Where'd I say anything to imply that?
>> You can't have closures in a language without runtime type information.
>   Oh, now C++ doesn't even have RTTI. Right.
Cool. So you have a library capable of marshaling any type of data into a
serialized stream? I can pass you a void* and you can inspect what it points
to and tell me what class it is? The traceback in your exceptions can tell
you what the values passed as arguments to the function on each frame... oh,
wait, that's right...
Hell, you can't even tell me how big an array is, or look at a pointer to a
value and tell me whether it's valid. How are you going to tell me what type
it is?
>   Like "lambdas", what is called "RTTI" in C++ is not *really* RTTI, right?
It's limited in exactly the same way as lambda's are - you get just enough
RTTI that people can call it RTTI, without having so much that you have to
do something extreme in the runtime code to make it work.
>   I start seeing your general rule of thumb: Every programming language
> feature, when implemented in C++, either isn't *really* that true feature,
No, there's a bunch of stuff that C++ does decently, and a bunch of stuff
like RTTI and lambdas that, yes truly, aren't really what everyone else in
the world calls that feature.
> or is magically converted into a negative aspect of the language (while
> it's a positive feature in all other languages).
It's usually the combination of that feature with other features or
misfeatures that make what's positive in some languages into what's negative
in C++.
>>>> (2) not wanting to add any syntax for it,
>>>   Have you even looked at how lambda functions will be written in the new
>>> C++ standard? How is it not adding new syntax for it?
>> A complete lack of any sort of keyword, like, oh, "lambda" maybe?
>   Wow. The lack of a keyword is now a negative feature. Right.
Yes, because it makes it harder to read and parse. It's not like there isn't
a whole theory behind parsing (for example) that just can't be applied to C++.
>>>   Good thing you are not prejudiced nor biased in the least.
>> "Prejudiced" would imply that I'm not making judgements based on experience,
>> but rather based on lack of knowledge.
>   Are you seriously telling me that you did extensive research on the
> new lambda function feature as specified by the current C++0x standard
> draft before making your remarks?
No. I read what wikipedia has to say about it, and I understand how C++ is
generally implemented in terms of a memory model, and from that I can deduce
that unless you do something *very* extreme, you're not going to get lambdas
out of the C++ mechanisms. The fact that the kinds of extreme things you'd
need to do lead to undefined behavior tells me that people aren't going to
do that, or at least won't be required to.
If I told you I had a great idea for C++, and all it needed was to allocate
each stack frame on the heap as a linked list, and to then add garbage
collection, wouldn't you tell me it's unlikely to be implemented by many C++
compilers?
>> I'm biased against ugly languages that are a pile of hacks to fix flaws in
>> other hacks.
>   At least you dare to admit it.
Sure. I've never hesitated to express my dislike of hacks, even when I
recognise them as necessary hacks.
>>>> No. I just don't like C++.
>>>   And for that reason you have to constantly write prejudiced BS about it.
>> It's neither prejudiced nor BS. What makes you think it's prejudiced?
>   Because you write about a new language feature without even knowing how
> it will be implemented.
I know how it *won't* be implemented. It won't be implemented such that
references to local variables survive the end of the stack frame those local
variables are allocated in. That's enough.
Or do you think C++ is going to hoist those local variables into a separate
object (like every other language implementing actual lambdas)? And if so,
when does C++ deallocate that separate object, given there's no garbage
collection?
>   I hope you have a good time laughing.
I did. I wouldn't be spending all this time typing if it wasn't amusing.
Thanks for asking.
Date: 7 Mar 2009 12:11:19
Message: <49b2aab7$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Warp wrote:
>>>     std::for_each(someList, [&total](int x) { total += x });
>> And, really, what's the advantage of this over a normal for loop?
>   Nothing. Since it's C++ code, it sucks.
You know, if you're not mature enough to have a civil conversation, you
don't really need to participate. I asked an actual useful question, so I
could perhaps learn why people are working to put lambdas into the language
when they have restrictions that make them useless for what most other
people use lambdas for. If your only answer is "there's no advantage of
lambdas over coding a regular for loop", then yeah, C++ sucks.
However, if there's anyone else who might like to answer that question, and
offer a scenario where such a structure is useful for something other than
marketing that "oh yea, we have a functional language too", feel free to
follow up.
Date: 7 Mar 2009 12:33:48
Message: <49b2affc$1@news.povray.org>
> separate object (like every other language implementing actual lambdas)?
> And if so, when does C++ deallocate that separate object, given there's
> no garbage collection?
For example, if you go to
http://download.microsoft.com/download/3/8/8/388e7205-bc10-4226-b2a8-75351c669b09/csharp%20language%20specification.doc
and look at section 7.14.4, you can see what C# supports in *its* lambdas.
Or http://msdn.microsoft.com/en-us/library/bb397687.aspx and go down to
"variable scope in lambdas" if you don't want to download the actual spec.
And when you nest lambdas in several scopes then reference variables from
those scopes, you get an even more complex set of declarations generated, in
order that (for example) the variable outside the loop your lambdas
reference are shared, while the variable inside the loop your lambdas
reference isn't shared.
I looked around to see if I could find the code that C# generates when you
give it a lambda with free variable references to multiple scopes (which,
yes, is just syntactic sugar), but I couldn't find it after 10 minutes or
so. If you really care, rather than just being interested in defending C++,
I'll take the time to hunt it down.  But it's not something you can put in
C++ in the same way.
Date: 7 Mar 2009 14:52:34
Message: <49b2d082@news.povray.org>
  You are not discussing. You are bashing based on prejudice.
Date: 7 Mar 2009 15:01:00
Message: <49b2d27c@news.povray.org>
> >> other hacks.
  I said that "at least you admit that you are biased". I didn't say that
"at least you admit you dislike something". But of course you seem quite
fluent at twisting things.
> Thanks for asking.
  You are being an unusually bad jerk in this thread for some reason. Not
your usual self. I'm curious what prompted your sudden holy war now.
Bad day?
Date: 7 Mar 2009 15:17:20
Message: <49b2d650@news.povray.org>
  You really are a master of trolling, you know. I have to admire that.
  First you succeed in trolling me with your unusually heavy and biased
C++ bashing, and then you try to make it look like all you wanted to do
is have a simple civil conversation.
  You know perfectly that there's at least one person reading this
newsgroup who appreciates the C++ language and doesn't appreciate
excessive bashing, yet you deliberately write really inflammatory
comments and mocking about it. Every question you made about new C++
features were aimed solely at trying to find flaws in them. When your
questions were answered, you asked more questions, trying to find flaws.
You continued asking questions until you found some flaw you could point
out. (Eg. first you asked if lambda functions would use such a cumbersome
syntax as boost::lambda, and when you got shown that they won't, you asked
if you can assign lamdbda functions to variables, and when you got shown
that you can, you continued asking and asking until you found something
that you can consider a flaw so that you could mock the whole feature.
The whole purpose of this was clearly to find some flaw you could point
out.)
  You know perfectly that if you start such a heavy bashing, you are going
to piss off at least one C++ fan, yet you deliberately go on, perfectly
knowing what effect it will cause. I think that deep inside you enjoy
doing that.
  Then, when you succeed in your trolling, you act all innocent and civil
and complain that all you wanted to do is have a "civil conversation".
After making me all angry with your condescending attitude you can go
and safely call me "immature" and make yourself look so high and mighty.
  You really are good at trolling. Personally I could not get even near
that level of mastery.
  The std::for_each() function was only a simple example. There are many
other algorithms which cannot be implemented with a simple loop.
  Another example: You could give std::sort() a comparator as a lambda
function which has access to the variables in the local scope, something
which is very laborious to do currently.
Date: 7 Mar 2009 16:05:39
Message: <49b2e1a3$1@news.povray.org>
I think it's fair to say it isn't prejudice that the philosophy of C++ is
that you don't pay for features where you don't use them. I'll admit the
syntax seems much cleaner than I thought it would be, because I assumed
they'd be doing something like Boost. However, C++ still doesn't have lambda
expressions, and I'm rather at a loss why the people working on the
standards called it that, since they aren't lambdas and they *didn't*
include "lambda" as a keyword.
I gave examples of actual code that works in any language that has lambdas,
and you tell me I'm not discussing C++ and that I'm prejudice. It sounds
more like you're prejudice than me, really, defending C++ for some reason
without actually offering any evidence I'm wrong. If I'm prejudiced and
right, what does it matter that I'm prejudiced?
C++ sucks to the extent that you don't pay runtime overhead for features
where you don't use them. This philosophy leads to a great number of warts
on the language (such as delete vs delete[], & references vs && references,
undefined behavior with non-virtual destructors in some cases, that static
initializations aren't done in a reliable order, etc.). I can understand
these warts, because they're focussed on performance and/or make the
compiler writer's job easier (and hence make the language easier to
implement and port).
The syntax also sucks, to a great extent due to the lame attempt to remain
compatible with a different language they're already incompatible with. Had
every C program actually been a valid C++ program with the same semantics,
this might have made sense, but they failed to ensure this too.
I think the fact that I came to different conclusions than you do don't make
it prejudice. I'm willing to learn, but if you can't tell me where I'm
wrong, then telling me I'm bashing based on prejudice doesn't help.
