POV-Ray : Newsgroups : povray.off-topic : Debian Server Time
16 May 2026 03:59:16 EDT (-0400)
  Debian (Message 31 to 40 of 60)
Subject: Re: Debian
Date: 4 Mar 2009 14:42:30
Message: <49aed9a6$1@news.povray.org>
On Wed, 04 Mar 2009 13:35:54 -0500, Warp wrote:
>   "In Linux when you want to configure anything you have to edit obscure
> files in obscure system directories using a text editor."
> nowadays almost exclusive to Slackware (and a few less known distros
> based on it or on the same principle).
Yes.  It also was common in RedHat when I was using it (5.2 - 9, pre-
Fedora).  The historical context is more important - Andy points this
out, actually, by repeating many statements that used to be correct about
Linux in general 10-15 years ago but are seldom correct today for the
vast majority of distributions.
>   "When you want to install new software, you have to always compile it
> from sources."
I would say that this latter comes from a combination of very early Slack
and LFS rather than Gentoo.  Gentoo is the most popular distro that uses
that as a package management system today, but the history of "build from
source" goes back farther than Gentoo.
Jim
Subject: Re: Debian
Date: 4 Mar 2009 15:14:34
Message: <49aee12a@news.povray.org>
Orchid XP v8 wrote:
> PS. What the hell is it with Linux and "commands" that fill three
> screenfulls of a terminal console?! What's that about?
Run make with -s next time.
Subject: Re: Debian
Date: 4 Mar 2009 15:31:04
Message: <49aee508$1@news.povray.org>
If there's a problem, you can look back and see what the error was and
fix it.
I suppose it's the theory that too much information is better than too
little.
BTW, only three screens full of info?  That's a pretty small program,
relatively speaking.  Compiling Rockbox for my iPod fills more than that
easily.  :-)
Jim
Subject: Re: Debian
Date: 5 Mar 2009 04:22:40
Message: <49af99e0$1@news.povray.org>
>> As I recall, the "minimal text mode" install gave you the barest minimum
>> to have a working system. It seems now there's a "text mode server"
>> option, but it still installs a whole crapload of stuff. I was trying to
>> set up a VM and I wanted the install that would take the least amount of
>> time. It didn't work too well...
> That's what individual package selection is for.  I tend to start with
> the text mode server and remove the stuff I don't need.
My plan was to start with the minimal text install and *add* the stuff I
needed. Except it isn't "minimal" any more - much to my irritation.
There's probably some way to select exactly what packages you want
before you boot the intall disk, but I haven't figured that out yet.
Subject: Re: Debian
Date: 5 Mar 2009 04:23:59
Message: <49af9a2f$1@news.povray.org>
> fix it.
> little.
No, I mean... why would you need commands that freaking long in the
first place??
> easily.  :-)
Well, when you're in text-mode, it's not easy to measure how many
screenfulls are scrolling past faster than the refresh rate of your
monitor. :-P
Subject: Re: Debian
Date: 5 Mar 2009 04:25:18
Message: <49af9a7e$1@news.povray.org>
>> from sources."
Again, this is The Unix Way(tm). That's why every Unix always comes with
a C compiler (not to mention autoconf). It's because every Unix is
slightly different, so while you can usually write a program that works
on every Unix, you're going to have to recompile it for each one...
Subject: Re: Debian
Date: 5 Mar 2009 07:06:25
Message: <49afc041@news.povray.org>
  Actually, as far as I remember, a default OpenSUSE installation does not
install gcc (you have to specify it during installation if you want it, or
install it later). The same is probably true for many other "user-friendly"
distros.
Subject: Re: Debian
Date: 5 Mar 2009 07:43:16
Message: <49afc8e4$1@news.povray.org>
> distros.
Sure. Today most things arrive as binary packages, and there's really
not much need for a compiler unless you happen to be a developer yourself.
Even so, the whole Unix mentallity seems a lot more set-up for this kind
of thing. On Windows, there isn't even a standard place for header files
to live...
Subject: Re: Debian
Date: 5 Mar 2009 11:24:54
Message: <49affcd6$1@news.povray.org>
> to live...
That's because Windows doesn't assume you'll only have one compiler. :-)
It's really quite a recent thing (approximately since Red Hat) that UNIX
software came as executable binaries.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Subject: Re: Debian
Date: 5 Mar 2009 11:26:32
Message: <49affd38@news.povray.org>
>> kind of thing. On Windows, there isn't even a standard place for
>> header files to live...
Then again, how many machine architectures does Unix target?
How many machine architectures does Windows target?
I rest my case.
