POV-Ray : Newsgroups : povray.off-topic : My toy Server Time
4 Jul 2026 19:14:24 EDT (-0400)
  My toy (Message 6 to 15 of 85)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: My toy
Date: 2 Mar 2009 12:06:46
Message: <49ac1226$1@news.povray.org>
Invisible wrote:
> Damn, this puppy does even more than I thought! You can put a Windows
> installation CD in your CD drive, remote in to the server, and install
> Windows over the network even though there's nothing in the server's
> CD-ROM drive.
<Invisible> ... which is obviously impossible ... </Invisible>
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Subject: Re: My toy
Date: 3 Mar 2009 01:57:01
Message: <49acd4bd@news.povray.org>
BTW guys have you read/heard news about the 5TB/sqr. inch HP tape
back-up? I hope it could be in production so it arrives to my country in
about 6 months-1 year aprox., but again the price... probably is about
1000 $us... :(
Subject: Re: My toy
Date: 3 Mar 2009 04:56:21
Message: <49acfec5@news.povray.org>
> Some pretty insane technical drawings happening in there! ;-)
> (I wonder how they do that BTW. Must be quite a challenge to draw
> something that complex...)
You don't draw it by hand, the CAD software will draw it based on the 3D CAD
data.  You simply set the view mode to wireframe with hidden edges,
orthographic projection etc and then save as a PNG at whatever resolution
you desire.  Takes about 30 seconds, see attached.
Actually making the 3D CAD data is not really a challenge, the software is
designed with drawing things like this in mind, so there are lots and lots
of features to make your life easy :-)
Download 'image1.png' (19 KB)
Preview of image 'image1.png'
Subject: Re: My toy
Date: 3 Mar 2009 05:12:51
Message: <49ad02a3$1@news.povray.org>
Well, not unless you're *insane* at least... ;-)
> CAD data.  You simply set the view mode to wireframe with hidden edges,
> resolution you desire.  Takes about 30 seconds, see attached.
So... is something like this drawn from the real manufacturing data that
the plant uses? Or do they build specialised models simplified for
display purposes?
> is designed with drawing things like this in mind, so there are lots and
> lots of features to make your life easy :-)
I've often wondered how CAD manages to produce complex, detailed 3D
objects. I have yet to see a modeller that makes it feasible to produce
any moderately complex 3D shape. And yet, the world around me abounds
with intricately machined objects, so there must be somebody who knows
how to do it.
(Just sweeping my head from side to side right now, I see several CD
jewl cases, some external HD bays, an MP3 player which *could* be a
simple cube, but isn't, the casing of my computer... All of them have
pretty intricate shapes.)
Subject: Re: My toy
Date: 3 Mar 2009 05:18:01
Message: <49ad03d9$1@news.povray.org>
scott wrote:
> see attached.
That's pretty mental, by the way. But what the hell *is* it??
Also... how do you make something like that? It looks like you'd either
have to mould it, or take a sheet of metal, bend it around a bit, cut
windows and drill holes in it...
Subject: Re: My toy
Date: 3 Mar 2009 05:32:42
Message: <49ad074a$1@news.povray.org>
A metal case that goes on the back of an LCD display.  Mainly to avoid
electrical interference between the LCD and other parts in the car, but also
for mechanical protection.  The pressed out lump in the centre is where
quite a few high components on the PCB are located, so it needs to provide
space for them, then there's two holes for connectors to go through, a
couple of features to make a good ground connection to the PCB, and various
clips and holes around the edge to securely fasten to the rest of the LCD.
Oh and of course some holes for screws to go through so the thing can be
fitted to the rest of the car!
Yeh it's pressed metal, so you start with a blank sheet and then it goes
through a series of tools that bend and cut certain bits until the final
shape is produced (IIRC there's about 7 or 8 stages usually), no drilling -
the tools have sharp bits that cut the holes and other shapes, just like a
big hole-punch!
Subject: Re: My toy
Date: 3 Mar 2009 05:39:19
Message: <49ad08d7$1@news.povray.org>
> also for mechanical protection.  The pressed out lump in the centre is
> where quite a few high components on the PCB are located, so it needs to
> provide space for them, then there's two holes for connectors to go
> through, a couple of features to make a good ground connection to the
> PCB, and various clips and holes around the edge to securely fasten to
> the rest of the LCD. Oh and of course some holes for screws to go
> through so the thing can be fitted to the rest of the car!
...it's times like this that I realise other people have way more
interesting jobs than I do! ;-)
Damn. That process must take some designing!
> no drilling - the tools have sharp bits that cut the holes and other
> shapes, just like a big hole-punch!
Heh. How thick is the metal??
Subject: Re: My toy
Date: 3 Mar 2009 05:41:53
Message: <49ad0971$1@news.povray.org>
Yes, but have you actually seen anyone using commercial CAD software like
Catia or Pro/Engineer? You know, the software that people who build planes
and cars use?
eg here is a screen shot of a model from Boeing:
http://www.nextcraft.com/media/aviation_technology/military_nasa/B737_catia_big.jpg
It's a bit more suited to doing this sort of stuff than a modeller like 3D
Studio or Blender.  It is more focussed on dimensions and model hierarchy,
and less on the graphical appearance (most of the time you are just using
plane gourard shading or even wireframe if you need to see certain details).
For example, the modelling process in a CAD package for that metal case I
posted would be something like this:
- Draw the outline cuboid shape
- Add on extrusions and cuts for any bumps and dips
- Add rounds to any edges
- Shell the model (this leaves a shell of specified thickness, 2 clicks in
CAD)
- Add in holes where necessary
- Add more rounds
- Add in any clip geometry
The CAD software remembers all that history used to generate the model, so
you can always go back and change the shell thickness and everything else
updates (or move the position of a bump etc).
Subject: Re: My toy
Date: 3 Mar 2009 05:46:37
Message: <49ad0a8d$1@news.povray.org>
>> produce any moderately complex 3D shape.
> like Catia or Pro/Engineer? You know, the software that people who build
> planes and cars use?
No. And that's what I've always wondered about - given the complexity of
the stuff these guys produce, their modelling tools must surely be more
sophisticated in some way.
OK, that's fairly crazy.
> I posted would be something like this:
> in CAD)
> - Add more rounds
> so you can always go back and change the shell thickness and everything
> else updates (or move the position of a bump etc).
I'd almost consider trying to track down some software like this - if it
wasn't for the fact that I keep hearing that it costs a fortune and
crashes routinely...
Subject: Re: My toy
Date: 3 Mar 2009 05:48:59
Message: <49ad0b1b@news.povray.org>
Yes, that's why the tools have ridiculous prices, usually with 6 or even
sometimes 7 figures!  And then you realise why the guy gets annoyed when you
ask for +/-0.1mm tolerance between two specific points :-)
Usually 0.3 - 0.6 mm depending on how big it is.  The tools are quite beefy
though, see attached (that is just stage 4 out of 7), all the intricate
detail in the middle is what actually makes the cuts and folds, the inner
working of each stage can be quite complex with spring loaded plates and
levers etc to do the bending correctly as the two halfs come together.
Download 'image1.jpg' (29 KB)
Preview of image 'image1.jpg'
