![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
1024x768 frame buffer...
Code:
:-D
public partial class Form2 : Form
Bitmap fireBmp;
byte[,] fireData;
Timer t = new Timer();
Random rnd;
int w = 1024;
int h = 768;
int[] clut;
public Form2()
InitializeComponent();
fireData = new byte[w, h];
fireBmp = new Bitmap(w, h,
System.Drawing.Imaging.PixelFormat.Format32bppRgb);
rnd = new Random();
clut = new int[256];
for (int i = 0; i < 256; i++ )
if (i >= 0 && i < 64) clut[i] = Color.FromArgb(i * 2,
0, 0).ToArgb();
if (i >= 64 && i < 128) clut[i] = Color.FromArgb(i * 2,
(i-64) * 4, 0).ToArgb();
if (i >= 128 && i < 256) clut[i] =
Color.FromArgb(255,255, (i-128)*2).ToArgb();
t.Interval = (int)(1000 / 30.0);
t.Tick += new EventHandler(t_Tick);
t.Start();
this.SetStyle(ControlStyles.OptimizedDoubleBuffer |
ControlStyles.ResizeRedraw | ControlStyles.UserPaint |
ControlStyles.AllPaintingInWmPaint, true);
void t_Tick(object sender, EventArgs e)
BitmapData bd = fireBmp.LockBits(new Rectangle(0, 0, w, h),
System.Drawing.Imaging.ImageLockMode.ReadWrite,
for(int y = 0; y < (h-1); y++)
for(int x = 0; x < w; x++)
if(y == 0)
fireData[x, h-1] = (byte)rnd.Next(255);
unsafe
int* pBmp = (int*)bd.Scan0;
pBmp[x + (h-1) * bd.Stride / 4] =
clut[fireData[x, h-1]];
fireData[x, y] = (byte)((fireData[(x - 1 + w) % w,
y + 1] +
fireData[(x + 1) % w, y + 1] +
fireData[x, y + 1] +
fireData[x, (y + 2) % h]) / 4);
int c = clut[fireData[x, y]];
unsafe
pBmp[x + y*bd.Stride/4] = c;
fireBmp.UnlockBits(bd);
Refresh();
protected override void OnPaint(PaintEventArgs e)
base.OnPaintBackground(e);
e.Graphics.DrawImage(fireBmp, this.ClientRectangle);
~Mike
Download 'windowsformsapplication1.exe.dat' (11 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, according to the Great Language Shooting, the Mono implementation
of .NET is slower than several other languages. (*cough* Haskell
*cough*) It depends on what you call "slow", of course.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Orchid XP v8 escreveu:
The Microsoft implementation isn't listed nor would run on their Linux
server, obviously. There's a fair amount of evidence that Microsoft's
F# is faster than OCaml, which is generally faster than GHC. There's
indeed good evidence nowadays that good jit compilers produce code which
is as fast or faster than code produced by ahead-of-time traditional
compilers.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You scare me each time with these posts. I open an innocent news mail
item and then suddenly all alarms go off warning me of a potential
infection.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> infection.
Sorry... My exe's are safe. But, yeah... some AV suites go nuts with exe
attachments.
I should copy them to my website and post a link to it, rather than
attach, anyway.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> implementation of .NET is slower than several other languages.
>> (*cough* Haskell *cough*) It depends on what you call "slow", of course.
> compilers.
Well, you're possibly right. Difficult to see how to verify or refute
those claims.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would think there's relatively little need to be slow in a program like
this, where it's all manipulation of fundamental structures. As in, I would
think the speed of a program like this in .NET wouldn't necessarily be any
slower than a similar program in plain C, unless the JIT is just really bad.
Was there really any reason to use the unsafe pointers?
It is a cool effect, tho.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> like this, where it's all manipulation of fundamental structures. As in,
> I would think the speed of a program like this in .NET wouldn't
> necessarily be any slower than a similar program in plain C, unless the
But, that's sort of my point. :) You don't need to be down to the wire
to get fast performance out of the system.
There was. There are 2 ways to access the bitmap data. One by using the
setpixel and getpixel functions. This is very slow. essentially every
access to the pixel data requires a conversion to and from a color
structure.
The other way is to access the buffer directly, hence the unsafe pointers.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> in, I would think the speed of a program like this in .NET wouldn't
OK. I'm just saying ... what makes you think it's not "down to the wire" in
this case? It doesn't look like you're doing anything in the inner loops of
the tick that you couldn't do equally well in C, so why wouldn't the JIT
generate equivalently efficient code?
> structure.
Cool. I've only done large-scale manipulations, not drawing pixel-by-pixel,
so I guess I never ran into that problem.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I estimate I'm getting 0.5fps.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
