![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah yes, the wonders of Debian.
Tell me, is there some way of operating the package manager where you
*don't* have to waste hours of your life trying to figure out why it
refuses to install the package you need?
I've tried several different ways, but I can't get any version of the
package I want actually installed.
- If I try from KPackage, it downloads a heap of stuff and attempts to
install it. Half way through, it tries to upgrade "libc6", and bombs out
with an opaque error. (Some subprocess terminated with exitcode 1.)
- If I try through apt-get, I just get a message to the effect of
"foo-123 requires bar-456 which won't be installed anyway". Um... so
install it for me then? What's the problem??
- I can't bring myself to try it with dselect. It's just too painful.
I'm not sure what else to try here... I guess I could invoke dpkg
directly. That'll be fun. :-/
I always hated this about Debian. There doesn't appear to be a simple
way to make it do what you want. :-(
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm. How interesting. If I do
apt-get install darcs
I get all sorts of fun and games. However, if I do
apt-get -t stable install darcs
it works perfectly first time. In fact, *everything* works first time.
So, um, *why* is this not the default?! o_O
/me walks off shaking his head...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At a guess (as I don't use debian systems), you have more than one repo
set up and the package exists in more than one place - so the package
manager doesn't decide for you but requires that you select the repo you
want to install from?
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As another guess, I think KNOPPIX is defaulting to using the "unstable"
branch rather than the "stable" branch, meaning it picks packages that
depend on whole new versions of libc and other critical infrastructure.
Telling it to pick the newest package from "stable" seems to make
everything work beautifully. I wonder why KNOPPIX is set this way?
OTOH... I asked for GHC, and I got version 6.6. That's *years* old
(current version is 6.10.1 - although note they skip odd-numbered
versions). Maybe that's why?
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On a related note, and I'm sure I could track this down with enough
googling, but I only spent about 10 minutes on it and didn't find anything
that looked likely: Can "apt" use "yum" repositories? Specifically, if
there's a repository with software for "open suse", can Ubuntu manage
packages from that easily? How about RPM repositories? Most of the
third-party repositories I see offer those two.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> anything that looked likely: Can "apt" use "yum" repositories?
> Specifically, if there's a repository with software for "open suse", can
> Ubuntu manage packages from that easily? How about RPM repositories?
> Most of the third-party repositories I see offer those two.
APT definitely works with RPM (according to Wikipedia).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think Apt can use RPM repos (which the openSUSE repos would be).
You can convert packages using alien, which I have done with some
success, though library names might be different (they were for a video
converter I was pointed at) so it takes a little work to get the package
working.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> can Ubuntu manage packages from that easily? How about RPM
>> repositories? Most of the third-party repositories I see offer those
>> two.
Seen, this is what happens because I don't use Debian-derived systems. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'll investigate more, but I don't know if the fact that something works
with RPM files means it also works with RPM repositories. I don't know if
they're the same kind of thing. (By "works with repositories", I mean
things like give you the TOC, keep updates updated, etc.)
My sysadmin guru says to use Ubuntu for servers these days, but I've been
using openSuSE, so ... I need to figure out where to get the packages I use
in a way that Ubuntu likes. This is what happens when you start getting
incompatible competition in Linux releases. :-)
"Ouch ouch ouch!"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
out of curiosity, what are his reasons for that recommendation?
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
