POV-Ray : Newsgroups : povray.off-topic : Technical support is... Server Time
16 May 2026 01:01:31 EDT (-0400)
  Technical support is... (Message 1 to 10 of 31)
Subject: Technical support is...
Date: 9 Feb 2009 08:33:06
Message: <49903092$1@news.povray.org>
...showing a member of staff how to operate a piece of software when you
don't actually know how to operate it or what it's supposed to do.
(Most especially fun when the member of staff in question uses this
software every day, and has been trained in its use, and you yourself
have never used it and have not been trained on any aspect of it.)
But hey, I'm sure people probably think that a car mechanic can fix any
imaginable device as long as it's purely mechanical too...
Subject: Re: Technical support is...
Date: 9 Feb 2009 09:19:03
Message: <49903b57$1@news.povray.org>
No, but a mechanical engineer might be able to figure it out ;)
~Mike
Date: 9 Feb 2009 09:22:08
Message: <49903c10$1@news.povray.org>
>> any imaginable device as long as it's purely mechanical too...
Now, see, most people would think a car mechanic *is* a mechanical
engineer! :-D
Date: 9 Feb 2009 09:34:02
Message: <49903eda$1@news.povray.org>
> engineer! :-D
Sadly the case :-(
Date: 9 Feb 2009 09:35:11
Message: <49903f1f$1@news.povray.org>
>> engineer! :-D
> Sadly the case :-(
You *know* it's true! ;-)
Still, I went on an IT course that was labelled "HND/BSc Computer
Science". ;-)
Date: 9 Feb 2009 10:01:38
Message: <49904552$1@news.povray.org>
In other words, it's a wetware issue. ;-)
Date: 9 Feb 2009 10:01:56
Message: <49904564$1@news.povray.org>
>> engineer! :-D
> Sadly the case :-(
Far from it ...
~Mike
Date: 9 Feb 2009 10:05:59
Message: <49904657$1@news.povray.org>
>>> engineer! :-D
>> Sadly the case :-(
> Far from it ...
No, see, most people *do* think that terms sounding vaguely similar in
fact refer to the same thing.
For example, most people would probably agree what "pharmacutical
analyst" and "chemical engineer" amount to the same thing. (Which is, of
course, completely false.) Most people would similarly believe that
"electrical engineer" and "staff electrician" are the same thing. And
the list goes on...
Date: 9 Feb 2009 10:08:38
Message: <umh0p4h7uqegqm4cpovs3ostbeq6gpng4o@4ax.com>
On Mon, 09 Feb 2009 08:16:49 -0600, Mike Raiford <"m[raiford]!at"@gmail.com>
Maybe but it will take a time served mechanic to fix it. ;)
Regards
Date: 9 Feb 2009 10:10:30
Message: <49904766$1@news.povray.org>
>>>> engineer! :-D
>>> Sadly the case :-(
>> Far from it ...
Wow, I think I screwed up there. I meant the mechanic is far from an
engineer.
> the list goes on...
Yeah, The EE knows the theory behind what he is doing. He knows WHY you
want, for instance, equal potential on all ground connections.
The electrician simply knows that he'll get flagged if he wires the hot
wire where the neutral was supposed to go. He may even be vaguely aware
that it might pose an electrocution hazard. :)
~Mike
