POV-Ray : Newsgroups : povray.off-topic : The most common 3D mesh file format? Server Time
4 Jul 2026 01:57:16 EDT (-0400)
  The most common 3D mesh file format? (Message 11 to 20 of 40)
Subject: Re: The most common 3D mesh file format?
Date: 27 Jan 2009 03:03:27
Message: <497ebfcf$1@news.povray.org>
andrel wrote:
> use blender, wings3d or something like that and export a few basic
> shapes as obj
Thanks, that was a good idea! I exported and imported the Blender monkey
model (in .obj) and here is the result:
http://www.saunalahti.fi/~sevesalm/ssRay/ShowImage.php?img=27
w00t, it works :D It is slow but looks to render quite properly.
However, my system crashed at 7am for some reason (blinking keyboard
leds - kernel panic, maybe?). Still don't know what was the reason.
Date: 27 Jan 2009 03:23:08
Message: <497ec46c@news.povray.org>
>> Another advantage of OBJ is that it support quads. I think 3DS only
>> supports
>> triangles?
>  Rendering a (non-rectangular) textured quad is not an unambiguous
> process.
> How do you do that? Dividing it into two triangles will get you a
> texturing
> artifact.
To be clearer, there is no expected or obvious way how the inside of a quad
should be textured given the four vertex texture coordinates.  Converting to
two triangles does it one way, but there are other possibilities.  In
practise every modeller and renderer will convert it to two triangles, so I
guess that can be thought of the "standard" way.
However, a more fundamental problem with quads is if the vertices are
non-planar.  Now, depending on how you triangulate it, you will actually get
different geometry.  For this reason, when you model using quads you should
try to keep them as close to planar as possible, otherwise you might be
surprised at the output, or when you come to smooth the mesh you will get
some funny results.
Date: 27 Jan 2009 03:26:26
Message: <497ec532$1@news.povray.org>
>> Thanks. OBJ seems fine. Any idea where I could find very simple .obj
>> files which contain (say) less than 100 triangles?
>> ssRay still lacks kd-trees so I don't want to wait millions of years
>> rendering that cool dragon model...
> use blender, wings3d or something like that and export a few basic shapes
> as obj
Just as a warning, I came across something weird with Blender and .obj
files, I can't remember exactly, but it was something like if no vertex
positions had a decimal point it wouldn't like the file.  Putting a ".0" on
the end of just one number in the file made it load ok.  ???
Date: 27 Jan 2009 04:57:19
Message: <497eda7e@news.povray.org>
clipka <nomail@nomail> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 34 lines --]
> Warp <war### [at] tagpovrayorg> wrote:
> >   Rendering a (non-rectangular) textured quad is not an unambiguous process.
> > How do you do that? Dividing it into two triangles will get you a texturing
> > artifact.
> Should be not too difficult: Just triangulate the nasty things.
> As long as we're "only" talking about quads and not generic N-gons that should
> not be a big deal. Find the shortest diagonal and cut it in two.
  But if you do that, you will get a texturing artifact, as I said.
Specifically this:
http://warp.povusers.org/images/uvproblem.gif
  (And if someone mentions the term "perspective" as a reply to this post,
I'll smash his face.)
  I suppose that if you subdivide the quad into four triangles (with one
extra vertex at the center of the quad) the artifact will be greatly
lessened, but it would still not be correct. (Basically the triangles
at the top and bottom edges would have their texture completely vertical,
even though it shouldn't be.)
Date: 27 Jan 2009 04:58:38
Message: <497edacd@news.povray.org>
scott <sco### [at] scottcom> wrote:
> In
  It might be the "standard" way, but it produces an incorrect texturing
(with non-rectangular quads). The texture would require a non-linear
transformation to be rendered correctly on such a quad.
Date: 27 Jan 2009 05:11:18
Message: <497eddc6$1@news.povray.org>
>> In
>> I
More specifically, when trying to map a rectangular section of a texture
onto a non-rectangular quad in model-space.  In practise this rarely happens
because you usually match your texture coordinates to the mesh (so that the
texture does not get distorted) - ie your 2 and 3 in texture space would be
moved to match how they look in model space.
In screen-space, when quads pretty much always become distorted and
non-rectangular due to perspective, the GPU accounts for this by
interpolating the texture coordinates divided by w (the homogenous
coordinate) to ensure the problem you illustrated in the other reply is
avoided.
Date: 27 Jan 2009 05:20:26
Message: <497edfea@news.povray.org>
  That's not always possible. Simple example: A torus composed of quads,
and a rectangular texture image wrapped onto its surface. The texture will
be distorted at the places where the quads are non-rectangular.
  I suppose you could tansform the texture image so that it matches the
shape of the quads at each point. It would make the texture irregular and
larger, but I suppose it might work. OTOH, if you ever decide to change
the resolution of your torus (ie. change the number of quads it's composed
of), you'll have to re-calculate the texture as well, which might not be
practical.
> avoided.
  Perspective has nothing to do with what I'm talking about.
Date: 27 Jan 2009 05:54:16
Message: <497ee7d8$1@news.povray.org>
True, but if you use enough quads that your torus looks like a torus and not
like a jaggedy square wheel the distortion is going to be minimal.  And
anyway, won't you have exactly the same problem using triangles instead of
quads - the renderer can only interpolate linearly and a rectangular texture
on a torus needs a non-linear interpolation to be correct.
> practical.
In most modellers I've seen you apply your texture in certain ways to the
mesh and the modeller automatically calculates the texture coordinates at
each vertex for you, so you don't have to concern yourself with making sure
the textures are distortion free.
I mentioned it because it's the most common situation when you need to map a
rectangular texture onto an often hugely non-rectangular quad, and it's
important it looks right.
Date: 27 Jan 2009 07:03:30
Message: <497ef811@news.povray.org>
  May be feasible for non-realtime rendering, but not real-time games
where you need such shapes.
>  And
  At least with triangles you can lessen the problem by making the
triangles as equilateral as possible (iow. each "row" (in torus
coordinates) of vertices is at the middle of the previous "row" of
vertices). Sure, the texturing will still not be technically perfect,
but at least the error is much less glaring, at least on a torus shape.
With quads the error becomes very visible, especially if the quads are
large.
Date: 27 Jan 2009 11:52:57
Message: <497f3be9@news.povray.org>
Severi Salminen escreveu:
>> shapes as obj
Nice too see a renderer built from scratch specially as I remember its
birth here in past threads... :)
