POV-Ray : Newsgroups : povray.off-topic : new C# stuff Server Time
16 May 2026 05:36:58 EDT (-0400)
  new C# stuff (Message 34 to 43 of 43)
Subject: Re: new C# stuff
Date: 24 Jan 2009 12:16:57
Message: <497b4d09$1@news.povray.org>
Warp wrote:
>   No. What I said was that I don't see usefulness IN THIS CASE. The
> difference is practically nonexistent. It's only in reordering of
> names.
It lets code generation tools (and LINQ) generate code in one pattern
(distinguished caller syntax) for both methods defined on the class and
methods defined outside the class.
It gives you the same benefit that having the name "operator<" available
does. If you want to do a sort in C of integers, you call
   qsort(myArray, myCompare);
   int myCompare(int a, int b) {return a < b;}
In C++ you call
   qsort(myArray, operator< );
or some such syntax, but without the need to have a specifically named
function just to wrap up the < operator.
Plus, of course, it lets the same member-syntax function mean different
things in different places in your code. Here, xyz.Select(...) means one
function, while there xyz.Select(...) means a different function. This is
important when "here" and "there" are two compiled libraries from two
different sources and you're automatically generating the code.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 24 Jan 2009 13:01:18
Message: <497b576d@news.povray.org>
Darren New wrote:
> In C++ you call
std::sort(myArray) is all you need. Guess *how* the operator< is used by
default?
template <typename T> bool less(const T& x, const T& y) {
    return x < y;
std::sort uses std::less as the default sorting function.
Date: 24 Jan 2009 13:36:37
Message: <497b5fb5$1@news.povray.org>
Nicolas Alvarez wrote:
> Darren New wrote:
>> In C++ you call
> default?
>     return x < y;
Yep. And now what do you do if the "less" you want to use is actually a
member function of type T?  What if the "less" you want to use is
class MyDate {
   bool comesBefore(const MyDate& otherDate);
   "Ouch ouch ouch!"
Date: 24 Jan 2009 14:15:31
Message: <497b68d3@news.povray.org>
> class MyDate {
  You create a comparator and give that to std::sort. A comparator can be,
for example, a (regular) function which takes two elements and returns bool.
Date: 24 Jan 2009 14:31:43
Message: <497b6c9f$1@news.povray.org>
>> class MyDate {
And that's precisely what the C# syntax avoids you having to do, in the
other direction.
It's in there most likely because of LINQ, which is a bit of the language
that turns something that looks a bit like SQL into something that looks
like method calls. If there were two syntaxes for each possible call that
LINQ generated, you'd have a mess. So now
   int xyz(this T alpha, U beta)
is a valid overloaded function candidate for
    alpha.xyz(beta)
when alpha is a T and beta is a U.
   "Ouch ouch ouch!"
Date: 24 Jan 2009 14:44:57
Message: <497b6fb9@news.povray.org>
> >> class MyDate {
> other direction.
  So instead of writing a function which takes two objects and returns
a bool, you write a "member function" which which called with one object,
takes another as parameter, and returns bool?
  I'm still not seeing the huge difference.
Date: 24 Jan 2009 14:56:02
Message: <497b7252$1@news.povray.org>
Yes.
That it's the same syntax regardless of whether it's a member function or a
function the user added later, which makes it easier for code generators.
Just like having operator= on classes makes it easier to write templates
than if you had to know whether to use (i = j) for integers and i.equals(j)
for complex numbers.
That you don't have to remember which functions were added after the fact
and which functions were part of the original class.
That you can chain a sequence of calls together that are both members and
non-members without having to skip back and forth around the line to figure
out what order they get evaluated in.
Writing
   myCollection.Select(...).Group(...).Transform(...).Sort(...).Output()
is a lot more clear than
   Sort(Group(myCollection.Select(...)).Transform(...)).Output()
just like writing
   a = b + c * d - e
is more clear than
   a = subtract(add(b, multiply(c, d)), e)
It isn't a "huge" difference, any more than operator overloading makes a
"huge" difference to the language.  But that's why it's there.  If you don't
see why it's a benefit, you either should just let it go, or read the C#
spec that relates it to the other features of C#.
   "Ouch ouch ouch!"
Date: 24 Jan 2009 19:13:56
Message: <153AC00C73C6484BA017DC6E176C3D6D@HomePC>
> -----Original Message-----
> From: Warp [mailto:war### [at] tagpovrayorg]
Maybe that's because you're looking for a huge difference, and there
isn't one.
It's a small difference that can make things a little easier on you.
Are you going to seriously complain that that's a bad thing?
...Ben Chambers
www.pacificwebguy.com
What's the difference between a drug dealer and a whore?
A whore can wash her crack and sell it again.
Date: 25 Jan 2009 07:56:35
Message: <497c6183@news.povray.org>
  The original post made it sound like a really big deal. That's what
I was objecting against. (Or, more precisely, I couldn't understand what
exactly was such a big deal about it that deserved a whole new thread
about the subject.)
Date: 25 Jan 2009 14:55:58
Message: <497cc3ce@news.povray.org>
Really?
"You know, I've wanted something like this since the mid 80's. :-)"
> about the subject.)
It wasn't. Everybody just jumped on that sentence and ignored the second
half of the post.  I was hoping someone with broader experience using Mono
might have mentioned some of the parts that *don't* work ok under Linux, for
example.
   "Ouch ouch ouch!"
