POV-Ray : Newsgroups : povray.off-topic : Physics, relativity, quantum, etc. Server Time
23 Mar 2026 20:06:12 EDT (-0400)
  Physics, relativity, quantum, etc. (Message 20 to 29 of 219)
Subject: Re: Physics, relativity, quantum, etc.
Date: 20 Jan 2009 11:24:23
Message: <op.un2c6hs4mn4jds@phils>
And lo On Tue, 20 Jan 2009 01:05:02 -0000, Darren New <dne### [at] sanrrcom>
did spake thusly:
>>   Unless I'm mistaken, the "graviton" is one of those particles invented
>> by quantum mechanics for the simple reason that "because everything
>> seems
>> to consist of particles, then there must exist a particle for every
>> phenomenon we can see, including gravity".
In one sense, if you arrange the known particles you get gaps similiar to
what occured with the first periodic tables...
> I wouldn't be surprised if that's the case. I never heard of anyone even
> proposing properties of a graviton, let alone finding evidence.
... it has been a while but I recall someone running the theory that if
gravity was a particle (as postulated by the Standard Model) then the
properties it would have to have to function in the way we see it would
match certain criteria (as Warp mentioned spin 2 being one of them) that
so happened to match one of the gaps. Working from another direction
string theory 'created' as a necessary outcome a 'particle' then had spin
2 etc.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 20 Jan 2009 13:06:53
Message: <497612bd@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>>>   Not stopped. Asymptotically slowing down.
>> So, the steeper the gravity gradient, the slower he falls? That doesn't make
>> sense? He actually *slows down* as he falls? Nothing ever goes thru the
>> event horizon?
>   No, it looks *from the outside*, from the point of view of an external
> observer, like his time is slowing down.
Right. Understand that my confusion is between these two sentences:
"He is slowing down."
"His time is slowing down."
>   Remember that speed and time is always relative to who is observing.
I would think that from the outside observer, his time is slowing down even
while his velocity is increasing.
I find it hard to believe that in falling into a black hole, your velocity
decreases.
>   Actually there are a few things which can be said of gravitons. In other
> words, "if gravitons existed, they must have these properties". For example,
> they would have spin 2.
Yep. Stuff like that. But I think that's because of where it would fall in
the tables.
>   (And no, I haven't the faintest idea what "spin" means. I just read
> wikipedia. :P )
"Spin" is a fascinating concept related to symmetry. A "spin 1/2" particle
means if you turn it 180 degrees, it looks the same. So a "two of diamonds"
playing card would be "spin 1/2" - it looks the same right side up as upside
down. (Discounting, of course, that it's 3D, so has a back that's different
from the front.)
An "ace of spades" has "spin 1" - if you turn it 180 degrees, the spade in
the middle will be pointing down instead of up, so you have to turn it 360
degrees.
And yes, a "spin 2" particle really is as strange as it sounds. You have to
turn it around 720 degrees before it's symmetric again. Don't ask me how
that works out.
That's about all I know about spin, tho, so ...
>> If hawking radiation doesn't exist, then you have no way of seeing what's
>> inside the event horizon, and hence the information on the spin of the
>> particles in there is lost?
>   Why is it lost? Just because you can't see it doesn't mean it doesn't
> exist.
It's lost because it cannot influence other particles in the local area. Of
course, that's because the particles outside the horizon are a spacelike
distance from the particles inside the horizon, so maybe you're right. Maybe
it's the equivalent of being outside the cosmological horizon.
>   If something moves to the other side of the cosmological horizon (from
> our perspective), is the information "lost"?
Maybe. I don't know. It can't affect us, but it can affect other things in
the local area. Technically, the particles *could* affect things a spacelike
distance away, which is what all the yadda about "quantum teleportation" is
about.
>> I think that's what I was trying to express. With a sufficiently large black
>> hole, you might not know you crossed the event horizon because the rate of
>> change of curvature is so slow. Of course you know you're in trouble.
>> There's just no "bump" as you cross over.  And if you're in free-fall
>> anyway, what might you notice?
>   I think that you would notice everything being warped.
Sure. But would you notice it significantly more one inch inside a
galaxy-size event horizon more than you'd notice it one inch outside a
galaxy-size event horizon?  I don't know, but I don't think that's how it
works - the event horizon, as I understand it, isn't a discontinuity.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 20 Jan 2009 14:10:01
Message: <web.497620a6c995525def2b9ba40@news.povray.org>
> decreases.
Cheating a little and looking ahead in my textbook, I find the following
sentence regarding the path of a particle falling radially into a black hole:
2/(3*sqrt(2m)) * ( (r_0)^(2/3) - r^(2/3) ) = tau-tau_0
"Looking at this equation, the mysterious surface r=2m makes no appearance.  The
body falls continuously to r=0 in finite proper (inertial) time, in contrast to
the result seen by an outside observer.  In fact, one can say that the entire
evolution of the physical universe has occurred by the time the body passes the
surface r=2m."
In other words, as seen by an outside observer, you reach the event horizon and
sit.  Forever.  As seen by you, on the other hand, you go speeding right on
through like it's not even there.  The surface only has significance for an
observer far away.
 - Ricky
Date: 20 Jan 2009 14:45:16
Message: <497629cc$1@news.povray.org>
Darren New escreveu:
>> wikipedia. :P )
> particle means if you turn it 180 degrees, it looks the same. So a "two
> of diamonds" playing card would be "spin 1/2" - it looks the same right
> side up as upside down. (Discounting, of course, that it's 3D, so has a
> back that's different from the front.)
> in the middle will be pointing down instead of up, so you have to turn
> it 360 degrees.
> to turn it around 720 degrees before it's symmetric again. Don't ask me
> how that works out.
Wonderful explanation.  So far, from my days of chemestry in college,
all I (thought I) knew was that spin 1 was an electron spinning in one
direction and spin -1 in the other direction, whatever it be. :P
> in the local area. Technically, the particles *could* affect things a
> spacelike distance away, which is what all the yadda about "quantum
> teleportation" is about.
quantum entanglement!  Beam me into a blackhole! :D
Including your body! :P
Date: 20 Jan 2009 14:50:16
Message: <49762af8$1@news.povray.org>
> sit.  Forever.
So at what point does the black hole increase in mass? Why would a black
hole ever grow if nothing falls thru the event horizon?
And at what distance do you start slowing down?
If you take the Earth and condense it down to a black hole, then stop a
particle in orbit 100 miles above where the surface used to be, the particle
will accelerate towards the black hole, right? But to avoid crossing the
event horizon, it must logically decelerate, as seen from the POV of someone
in orbit (say).  You wouldn't stop at the original altitude of the surface,
but you would stop before you get to the event horizon, so in this case,
gravity must be causing you to decelerate.  Yes?
   "Ouch ouch ouch!"
Date: 20 Jan 2009 15:20:33
Message: <49763211$1@news.povray.org>
>> horizon and
>> sit.  Forever.
He's talking about what is seen from an external observer, which is the
same explanation Hawking gave in one of his books.  The observer sees a
kind of after image that seems to ever approach the event horizon
without ever touching it, but in reality the crossing of the EH already
took place and nothing of what happens in the inside is seen...
Date: 20 Jan 2009 15:38:19
Message: <4976363a@news.povray.org>
> >> horizon and
> >> sit.  Forever.
  Besides, the mass of a spherical object, as measured from outside the
sphere, is independent of how the mass is distributed. It could be all
in the center or it could be all evenly distributed. From the outside
it would measure the same.
  That's the reason why you can eg. calculate orbits assuming the Earth
is a point, rather than a sphere. (Well, as long as the orbit doesn't
collide with the surface of the Earth, of course.)
Date: 20 Jan 2009 15:40:02
Message: <497636a2@news.povray.org>
  If quantum teleportation exists, I wonder if it would be theoretically
possible to teleport a particle out of a black hole.
Date: 20 Jan 2009 15:50:02
Message: <497638fa@news.povray.org>
Hmmmm.... I'll have to think on it.
   "Ouch ouch ouch!"
Date: 20 Jan 2009 15:50:27
Message: <49763913@news.povray.org>
And therein lies the clash of QED and GR. :-)
   "Ouch ouch ouch!"
