POV-Ray : Newsgroups : povray.off-topic : DFT and FFT Server Time
5 Jul 2026 07:41:25 EDT (-0400)
  DFT and FFT (Message 41 to 50 of 55)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: DFT and FFT
Date: 20 Jan 2009 10:38:24
Message: <4975eff0@news.povray.org>
scott wrote:
>> Personally I'd love to implement something like that myself - but I
>> don't have access to anything that can talk to the sound hardware. :-(
> You could always just output a raw .wav file and then send it somewhere
> to play it (eg mediaplayer or winamp, surely also a smaller command line
> player somewhere out there).
Have you seen the format spec for the .WAV file format??
It's actually RIFF - a multilation of the Amiga IFF format with all the
4-byte values incorrectly written backwards. (Hence "R" for "reverse".)
You can't just say "hey, here's some data". You have to include a header
that describes - in the most retarded way imaginable - exactly what the
layout of the payload is. (E.g., mono or stereo, 8-bit or 16-bit, signed
or unsigned, etc.)
It's no mean feat to set all this up...
What I guess I *could* do is write a small Java application that accepts
raw audio data over TCP and then writes it to the sound hardware.
(Although talking to the sound hardware in Java isn't exactly easy
either - it's a 12-step process of getting a factory factory factory
that possibly yields a factory factory that can then be queried for the
kinds of factories it knows how to produce... you get the picture.)
Date: 20 Jan 2009 10:46:24
Message: <4975f1d0@news.povray.org>
  I think the R stands for Resource.
Date: 20 Jan 2009 10:55:08
Message: <4975f3dc@news.povray.org>
>> somewhere to play it (eg mediaplayer or winamp, surely also a smaller
>> command line player somewhere out there).
> or unsigned, etc.)
IIRC the data in the wav file isn't too, too bad to format correctly,
but the header needs to be right.
I remember a conversation with a friend while I was screwing around with
linux.
I can't remember the exact syntax .. but something like this.
cat mysound.wav | /dev/snd
"You can't cat a wav file!"
"Yeah, I can. Watch"
I hit enter and ... after a short burst of static, it plays the file,
albeit at the wrong sampling rate.
"Huh, I didn't know you could do that ..."
~Mike
Date: 20 Jan 2009 10:59:27
Message: <4975f4df$1@news.povray.org>
You mean this:
http://ccrma.stanford.edu/courses/422/projects/WaveFormat/
Looks very simple to me, about the same level of difficulty as writing a
windows bmp file, ie very easy.
Date: 20 Jan 2009 11:19:40
Message: <4975f99b@news.povray.org>
  The amount of things wrong in everything of the above is mind-boggling. ;)
  (For one, you are trying to run /dev/snd as if it was a program. Of course
that's not the only problem.)
Date: 20 Jan 2009 11:23:05
Message: <4975fa69$1@news.povray.org>
Hmm, does Linux use the same format as DOS for redirection? e.g. it
should be > /dev/snd (or whatever)
I know what I did was truly ugly, but it worked, that's what was funny.
But, I can't remember the syntax (It's been years since I've really used
  linux from a command line.)
~Mike
Date: 20 Jan 2009 12:15:54
Message: <497606ca@news.povray.org>
  | is a pipe: The standard output of the program on the left side is
redirected to the standard input of the program on the right side.
However, /dev/snd is not a program and cannot be run.
  If you want to redirect the standard output of a program to a file
(or, in this case, a device), > is the operator for it.
Date: 20 Jan 2009 12:39:57
Message: <49760c6d$1@news.povray.org>
That's what Microsoft wants you to think. Originally it was "reverse", until
they realized how few people were familiar with the Amiga formats or something.
It's *exactly* IFF, with the endianness reversed. :-)
Altho it does annoy me when I see it mentioned in the press how "RIFF is an
extensible format created by Microsoft...."
I do like how PNG took it a step farther and encoded into the chunk names
whether you need to understand the chunk to parse the file, etc.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 21 Jan 2009 04:17:14
Message: <4976e81a$1@news.povray.org>
Now try doing that with a sound that's been LZW-compressed. ;-)
Doesn't sound very nice...
Date: 21 Jan 2009 08:37:24
Message: <49772514$1@news.povray.org>
I imagine it's about as pleasing as loading an MP3 as a raw PCM audio
file and playing it. For some reason this one audio app I have
recognizes every MP3 correctly, except for a handful of files from one
particular album. Weird.
~Mike
