POV-Ray : Newsgroups : povray.off-topic : I think this pretty much sums up what I dislike about most Java libraries Server Time
16 May 2026 05:35:52 EDT (-0400)
  I think this pretty much sums up what I dislike about most Java libraries (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: I think this pretty much sums up what I dislike about most Java libraries
Date: 15 Jan 2009 04:17:57
Message: <496eff44@news.povray.org>
Nicolas Alvarez <nic### [at] gmailcom> wrote:
> FactoryFactory??
> http://discuss.joelonsoftware.com/default.asp?joel.3.219431.12
  Overengineering (or in the case of software, overdesigning) really can be
a real problem.
  I have encountered this problem myself in a project I was working.
One guy was really too infatuated with object-oriented design, and went
really overboard with it. Almost *everything* had to be its own separate
class, in a really complex inheritance hierarchy, with several layers of
abstractions, one on top of another. One program he made consisted of over
20 source code files and was rather long and really complicated. The
program source code was rather hard to understand.
  Years later I had to reimplement that same functionality from scratch
(basically it was a simple modification of a similar tool). My version
of the same program consisted of 3 source code files, and the program
was 10 times faster with all inputs I tried. The OOD was, IMO, still
pretty good, but much more understandable because of a way more simplistic
approach.
Date: 15 Jan 2009 04:30:42
Message: <496f0242$1@news.povray.org>
> a real problem.
> approach.
I think if you're actually *trying* to do something that's inherantly
complicated, a complex design may be called for. (And especially if
future requirements aren't completely certain.)
OTOH, unless you're psychic, you will never know what the future holds,
and any flexibility you design in will probably turn out to be not quite
the right thing for what you *really* end up trying to add. There is
definitely a lot to be said for keeping a design as simple as feasible!
Ever heard the phrase "analysis paralysis"? ;-)
Date: 15 Jan 2009 12:46:10
Message: <496f7662$1@news.povray.org>
Same here. The one major program we hired a consultant to do at the last job
needed to simply read a config file, then read from  N streams on a device
driver and stuff them into a database as the data came in. Something like 30
classes to do that, because each bit had its own abstract memory manager
class and then the class that actually did work then yadda yadda. I would
want to change something after he left, and it would take me like an hour to
track down where he parsed the value of a config variable (and this is
simple name=value\nname=value\n... sort of thing). You'd think given the
names, you'd be able to, like, grep for the name in the source code and
track it from there, wouldn't you?
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Subject: Re: I think this pretty much sums up what I dislike about most Javalibraries
Date: 15 Jan 2009 12:48:56
Message: <496f7708$1@news.povray.org>
Yeah. The first time I ran into this was early Java socket libraries, where
they tried to make it possible to talk to different kinds of sockets.
Granted, it was the first time I ran into the factory pattern (since
Smalltalk doesn't need factories, since "new" is a method that returns a
value), so it was a little confusing. I don't remember how you specified
what protocol you wanted, but it wasn't something simple like passing some
enum for the protocol to the factory method and getting back the right
subclass of socket.
There are complexities you can hide, like "here's a URL, give me back an
appropriate object to manipulate a URL with that scheme." There are some you
shouldn't hide, tho.
Date: 16 Jan 2009 04:30:08
Message: <497053a0$1@news.povray.org>
HAHAHA!
Seriously, are there *any* consultants who are good at something other
than job security? Or is that just a myth?
Date: 16 Jan 2009 10:57:21
Message: <4970AEC7.2050604@hotmail.com>
On 16-Jan-09 10:30, Invisible wrote:
> HAHAHA!
Gail?
Date: 16 Jan 2009 10:58:59
Message: <4970aec3$1@news.povray.org>
> Gail?
I wasn't aware Gail was a consultant...
Date: 16 Jan 2009 12:16:31
Message: <4970c0ef$1@news.povray.org>
There are, actually. We just hired poorly in that case. (My interview
process got overruled due to time constraints, basically.)
The code eventually worked. It was just impossible to maintain.
Date: 16 Jan 2009 12:31:43
Message: <4970C4E6.1040009@hotmail.com>
>>> other than job security? Or is that just a myth?
>> Gail?
Last year she left her company to become a consultant in a small firm,
remember?
Date: 19 Jan 2009 05:06:39
Message: <497450af@news.povray.org>
> remember?
Oh, right. I must have missed that...
