POV-Ray : Newsgroups : povray.off-topic : I know I could try this myself, but... Server Time
15 Oct 2024 11:16:54 EDT (-0400)
  I know I could try this myself, but... (Message 1 to 10 of 13)
Subject: I know I could try this myself, but...
Date: 14 Dec 2008 18:27:58
Message: <4945967e$1@news.povray.org>
... I figured someone would have an answer more easily.
If I have a bunch of lights inside a box, one light outside of a box, one
object to illuminate outside the box, and one camera outside the box, the
trace goes much faster if I remove the lights inside the box from the scene.
Apparently, POV isn't clever enough to know that the lights inside the solid
opaque box don't affect the scene outside the box.
If I put the lights inside the box inside a light group that includes only
the other objects inside the box, will it be faster when the camera is
outside the box? Or will I still be better off commenting out the lights
inside the box?  I.e., how fast does using lights in a lightgroups speed up
a scene (where you can't see any of the objects in the lightgroup) compared
to not having the lights at all?
I just don't want to go thru the work of rewriting a bunch of macros if I'm
not going to get a significant speed-up.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Subject: Re: I know I could try this myself, but...
Date: 14 Dec 2008 19:15:46
Message: <4945a1b1@news.povray.org>
Is it just me, or is this off-topic for the off-topic group? :)
Date: 14 Dec 2008 19:19:28
Message: <4945a290@news.povray.org>
Oops.
Date: 14 Dec 2008 19:49:02
Message: <4945a97e@news.povray.org>
  How about simply enclosing those light sources inside #if blocks?
If the camera is outside, don't create the inside light sources at all.
Date: 14 Dec 2008 22:25:34
Message: <4945ce2e$1@news.povray.org>
That's what I essentially wound up doing. I have my own macro preprocessor
(instead of using SDL).  I was hoping to be able to (for example) describe
the shape of the outside walls once and reuse it on every floor, but POV's
bounding boxes aren't magically clever.  Then I realized if I have a
five-story building with 50 light bulbs on each floor, I'll be dead before
it renders, so I essentially put in my own version of "light groups" to
simply not expand the lights in the macro expansions unless the camera was
in "the same room", but it's all manual at the moment. I was hoping I could
have basically one expansion of the macro work for all the different traces.
(I take dozens of traces of each room and make a walk-thru. I had to put
closed doors between the rooms so I could turn off lights in a way that kept
  you from seeing they're off.)
I was just wondering if it was worth modifying my macros to allow lights in
lightgroups, or whether leaving it as "the camera and light are in the same
room so include the light" bit is the best I can do. (Which implies
re-expanding the macros for each room, which takes several minutes because
the macro expander is not written with efficiency in mind.)
Honestly, it was at least as much curiosity as practicality. :-)
Date: 14 Dec 2008 23:05:59
Message: <4945d7a6@news.povray.org>
> could have basically one expansion of the macro work for all the different
> traces. (I take dozens of traces of each room and make a walk-thru. I had
> to put closed doors between the rooms so I could turn off lights in a way
> that kept you from seeing they're off.)
> in lightgroups, or whether leaving it as "the camera and light are in the
> same room so include the light" bit is the best I can do. (Which implies
I don't know if this is at all relevant for what you're doing, but I'll say
it anyway :)
A generic way to see if a light affects a scene:
Render a very small image for each light; each image having only one light
turned on. Take the images that aren't completely black. Those are the
relevant lights :)
I thought about it for re-renders of long animations. Render the whole
animation at a tiny size, compare the tiny images with the ones I did
before the last change, take the differing ones, re-render only those at
full size.
Date: 15 Dec 2008 00:22:35
Message: <4945e99b$1@news.povray.org>
> relevant lights :)
I know which lights affect a scene. The problem is I have hundreds of
lights, and hundreds of frames.
http://darren.s3.amazonaws.com/Castle/SavedOUT/index.html
Take a look at the "floor plan" link near the bottom. That's one floor. The
big room in the middle has (about) 30 light sources and needs probably 200+
images, depending on which way you're facing and where you're standing. That
floorplan image with all the lights for just one of the six floors turning
on rendered in the pixels-per-minute timeframe. Turning off those lights
while rendering (for example) the bedrooms (or the other floors, for that
matter) speeds things up immensely, which is why you see so many curtains
hanging there.
Right now, I run the macro expansion once for each room, then render all the
images for that room. It would certainly be more convenient to run the
expansion once and render the whole building, but that's not going to work
unless lightgroups can very efficiently interact with bounding boxes to
ensure the blocked lights don't take up a lot of time. It took about half as
long to run one expansion as it does to render one frame of the smaller
rooms, so it would have to be very efficient to make it worthwhile.
> full size.
Not a bad idea.
Date: 15 Dec 2008 05:18:42
Message: <49462f02$1@news.povray.org>
> one object to illuminate outside the box, and one camera outside the
> box, the trace goes much faster if I remove the lights inside the box
> from the scene. Apparently, POV isn't clever enough to know that the
> lights inside the solid opaque box don't affect the scene outside the box.
More exactly: POV-Ray figuring out which lights should affect stuff
outside the box is *why* it goes slower. :-P
Date: 15 Dec 2008 06:10:12
Message: <49463b14@news.povray.org>
4945a97e@news.povray.org...
>                                                          - Warp
Don't even answer : he just deserve to get canned for on-topic in off-topic
Marc
Date: 15 Dec 2008 06:11:37
Message: <49463b69$1@news.povray.org>
4945967e$1@news.povray.org...
> scene. Apparently, POV isn't clever enough to know that the lights inside
POV is clever but wondering if the cat is dead or alive !
Marc
