POV-Ray : Newsgroups : povray.off-topic : Luniversity studies Server Time
5 Jul 2026 03:30:50 EDT (-0400)
  Luniversity studies (Message 84 to 93 of 203)
Subject: Re: Luniversity studies
Date: 13 Nov 2008 04:28:34
Message: <491bf342$1@news.povray.org>
>> MOST companies need salesmen. Not all of them, but most of them.
> Every company needs at least one salesman. Sometimes that person is also
> (say) the inventor, president, and CEO, tho. :-)
OK, I rephrase: Some companies need far fewer salesmen that others. It
depends what they do.
>>> Most jobs requiring competence don't advertise. It's mostly
>>> word-of-mouth.
>> ....and since I don't know anybody, it's not going to be me.
> That is definitely a stumbling block.  Another kind of thing you learn
> at school...
The only thing *I* learned at _school_ is that people are terrifying
things to be avoided at any cost.
Fortunately I have now unlearned that one. Unfortunately, I now have no
starting point.
>> SOME people want somebody who can definitely do the job RIGHT NOW.
> Yes. And not infrequently, those are exactly the companies you don't
> want to work for.
Yeah, I gathered. ;-)
>> (E.g., I suspect if you applied to work for Google,
> Not if their interview process is anything to go on.
O RLY?
You know something about this then?
(All I know is that all the "interesting" companies like Google, NI,
etc. seem to be in other countries. Not this one.)
Date: 13 Nov 2008 04:29:22
Message: <491bf372$1@news.povray.org>
>> Yeah, it does - just not particularly often. ;-)
> Tell that to all of those employees here or at RedHat who get paid.
> But there is an added advantage to working on OSS projects - helps build
> a resume and people can see your work.
I'm not disputing that getting paid for OSS is a good idea - I'm just
saying it's highly nontrivial to achieve this.
Date: 13 Nov 2008 04:30:59
Message: <491bf3d3$1@news.povray.org>
Nicolas Alvarez wrote:
> scott wrote:
>>> Well, I had a diagram for a circuit where you connect a lamp to the
>>> battery through a linear potentiometer. The brightness of the lamp
>>> varies roughly linearly. But the brightness of an LED... does not.
>> LED brightness is proportional to current not voltage!
> Also, are *human eyes* linear? Would you notice when brightness is changing
> perfectly linearly? :)
Probably not. But when the light stays off, and then suddenly turns full
on, with nothing in between, I'm fairly sure that's non-linear. ;-)
Date: 13 Nov 2008 04:39:58
Message: <491bf5ee@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:491bf342$1@news.povray.org...
> O RLY?
Google for google interviews. Quite a bit has been written about their
interview process.
> (All I know is that all the "interesting" companies like Google, NI, etc.
Google's EU headquarters are in Ireland (though that is another country)
http://www.google.co.uk/intl/en/jobs/index.html
They seem to have a lot of openings. Won't suit you though, they're in that
horrible, terrible place that no one want to go (London)
Date: 13 Nov 2008 04:47:26
Message: <491bf7ae@news.povray.org>
> interview process.
...the irony...
> that horrible, terrible place that no one want to go (London)
Sadly it seems that 80% of all UK jobs are in London. Regardless of
which industry.
Date: 13 Nov 2008 06:52:54
Message: <491c1516@news.povray.org>
news:491bf7ae@news.povray.org...
> Sadly it seems that 80% of all UK jobs are in London. Regardless of which
> industry.
Well, yes. It's the capital city and (iirc) the largest city in the UK.
Hence most things will be there
Date: 13 Nov 2008 07:02:40
Message: <491c1760$1@news.povray.org>
>> which industry.
This is not surprising.
What *is* surprising (to me at least) is that lots of things happen in
cities near to MK, but very little happens in MK itself. I'm not sure
why that would be...
(I'm thinking more of social events - I'm not really sure what the jobs
markets are like.)
Also... the UK has plenty of other large cities besides London. Yet not
many of these seem to have huge quantities of work available. I'm not
really sure why.
Date: 13 Nov 2008 10:13:41
Message: <491c4425$1@news.povray.org>
Invisible wrote:
>> "normal" ones work at all sorts of voltages, it even varies from piece
>> to piece quite significantly.  But you never drive an LED directly by
>> applying a fixed voltage, you always drive it by regulating the
>> current to a fixed amount (like 20 mA or whatever).  Adding a series
>> resistor to a raw LED is a quick and crude method of fixing the
>> operating current.
> This doesn't make sense to me.
> Presumably the resistence of the LED is finite and fixed. How does
> adding another resistor help? There are several schematics in my
> electronics kit that involve LEDs and no resistors at all.
Sorry I've been away and missed the fun.
I hook up a LED this way:
A LED will always drop or *consume* a fixed voltage - again, that's
voltage not current.
A LED is NOT a resistor - in the most basic sense it generally will not
prevent current from flowing through it once it starts flowing - it
starts flowing at it's rated voltage drop.
The typical voltage drop for a basic red LED is 1.7 volts.
For most LEDs you can use this number for calculations.
Be aware, that different colors may have a higher voltage drop.
A LED will generally not light up unless your voltage across its leads
goes above it's drop.
A LED likes to have between 10mA and 20mA - to be safe you can use 10mA
in calculations.  The current will affect brightness, but too much
current will cause it to burn out.  You are better off to select a
*bright* LED with a high light output rating than try to get more light
by putting more current through it.
So some easy calculations:
lets say 5v power source
1.7v LED
10mA current
the LED drops 1.7v so the rest of the circuit will drop 3.3v
(5v)-(1.7v)=(3.3v)
If don't put a resistor in then the current through the circuit will be:
I=V/R   from V=IR
I=(5v)/(0 ohm)
not good  too much current - things get hot
	(note:  LEDs should not get hot)
we want the current (I) to be about 10mA
so R=V/I   again from V=IR
R=(3.3v)/(10mA)
R=330 ohm
330 ohm happens to be a common resistor value
so put one in
if your source is 12v then you need a 1,030 ohm resistor - not a common
value.  But 1,000 ohm is - so use it instead.
Typical resistor values are only +-10% anyway - so a 330 ohm resistor
could be as low as 300 or as high as 360 and you don't know it.
So picking something slightly off from the *calculated* value is OK.
After all, you are just trying to make a LED light up - not try to
maximize it's brightness.
Tom
Different LEDs drop different voltages, but you can usually safely bet
on 1.5V and still be safe.
Then there is the current rating of the LED - usually 10mA to 20mA - you
can pick 15mA and be pretty safe.
Date: 13 Nov 2008 10:33:42
Message: <491c48d6$1@news.povray.org>
Orchid XP v8 wrote:
> Darren New wrote:
>> Invisible wrote:
>>> How many resistors can you see? Because I count NONE!
>> I look at an Intel chip stuck to my motherboard, and I don't see any
>> transitors, either.  The gate-level logic is working with bits, not
>> voltages. You're not going to see the analog stuff that makes the bits
>> work there.
> ....which is why I'd rather work at the gate-level. ;-)
The problem is that digital electronics are based on analog circuits.  A
lot of digital circuits can be wired up with out knowing anything about
analog, but when something doesn't work as you expect, you might quickly
get lost.
And as you have found out with LEDs, even when you think you are only
dealing with digital, you are dealing with analog as well.
You don't have to understand breakdown voltages and the like to
successfully work with LEDs, you just have to understand some of their
base characteristics.
Even something as simple as a button or switch can cause problems.
When you close the contact there are literally thousands of connections
made and broken in the very short time before the contact is completely
closed.  If you have a counter, it might count 4 or 5 on each button
press, not just one.  That's what debounce circuits are for, but they
can be analog - go figure.
Electronics can be deceptively simple, but insanely complex.
I think you have the capacity to really work well in electronics - but
you just don't have the background in how it all comes together.  That
comes mostly with experience.
Books will tell you how to calculate you need a 524 ohm resistor -
that's insane.
Experience will tell you that 470 ohm (a typical value) is OK.
Don't get discouraged when things don't work as you think they should.
Pretend that you don't know anything about what is not working and go
research it.  You will learn loads and loads.
If a LED doesn't light, go learn how it works.
The same goes for most anything else.
Don't try to build a rocket ship - build something simple.
Get a book that doesn't just say hook this wire here and there, but that
actually goes through how it all works.
The CMOS Cookbook I pointed out earlier is a good book in that reguard.
Tom
Date: 13 Nov 2008 10:44:14
Message: <491c4b4e$1@news.povray.org>
> get lost.
Yeah, this is the thing. I had assumed that the digital devices you buy
in the shop are carefully designed to behave in a simple, predictable
mannar, even though their internal construction is a tangle on analogue
devices. I thought you could just treat a 7400 as a black box.
Apparently not...
The LEDs actually worked just fine. It's the gate driving them that
didn't do what it was ment to.
I wouldn't find this surprising. Rather, to be expected.
Presumably a debounce circuit is merely a low-pass filter?
Heh. I got stuck just trying to get a truth table out of a logic gate. :-S
...does it matter that I'm using TTL?
