POV-Ray : Newsgroups : povray.off-topic : GRUB uglies Server Time
16 May 2026 09:57:56 EDT (-0400)
  GRUB uglies (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: GRUB uglies
Date: 8 Nov 2008 12:15:27
Message: <op.uka8v0qw7bxctx@e6600.bredbandsbolaget.se>
On Sat, 08 Nov 2008 17:45:16 +0100, Darren New <dne### [at] sanrrcom> wrote:
> Fredrik Eriksson wrote:
>> I think you may have to chroot into the Linux installation before
>> setting up GRUB if the installed version is not the same as the one on
>> the CD. GRUB will crap out if stage1 and stage2 are from different
>> versions.
> Hmmm. Fair enough. But I didn't do any updates on at least some of the
> tests, so I'm assuming the two versions were the same.
The version that gets installed from the CD might not be the same as the
one installed *on* the CD.
> I want Vista to chain-load GRUB. (More precisely, I want Vista to chain
> load Linux, but LILO wasn't happy either.)
Personally I use grub4dos for that. That way, I do not need to change
anything on the Windows side when I update GRUB on the Linux side. Not
sure how well it works with Vista though; setting it up on XP is trivial.
Also, should you not be doing "setup (hd0,1)" if you want to chain-load
 from the Vista boot-loader?
FE
Date: 8 Nov 2008 12:22:45
Message: <4915cae5@news.povray.org>
Good point, good point. I never ran into that before, but you could be
right there.
Unless GRUB rewrites the per-sector partition, I don't need to change
anything on the Vista side either. I didn't have trouble changing, for
example, the menus, IIRC.  I'll check it out.
There's also a program called EditBCD or some such that can install a
variety of boot loaders. I was just trying to do it all with native code.
Should I?  What GRUB actually does when it sets up is still kind of
mysterious to my. I'm basing my commands on what I did when I set up a
bunch of 32-bit machines at work - after restoring the dump, the script
ran those grub commands and then it would boot. (Well, not exactly,
because it was a RAID at work, so it had to do it with two different
devices as root.)
I'll try it with setup (hd0,1) next, and with a chroot first. Thanks for
the advice!
Date: 8 Nov 2008 12:35:38
Message: <op.uka9tnk07bxctx@e6600.bredbandsbolaget.se>
Changing the config is not a problem. Updating GRUB to a newer version is.
Anytime you re-setup the GRUB boot-loader you have to update the copy you
keep on the Windows side.
> mysterious to my.
"setup (hd0)" installs GRUB to the MBR of hd0, i.e. it overwrites the
first stage of the Vista boot-loader. If you want to chain-load Linux, you
should install GRUB to the boot sector of the Linux boot partition.
FE
Date: 8 Nov 2008 12:44:51
Message: <4915d013$1@news.povray.org>
> is. Anytime you re-setup the GRUB boot-loader you have to update the
> copy you keep on the Windows side.
Yes, that I'm aware of. Fortunately easy to fix from the SuSE rescue
disk, if it updates and I don't notice.
> you should install GRUB to the boot sector of the Linux boot partition.
Mwa ha!  Very good!  Thanks!  I'll give that a try as soon as I get
stuff reinstalled. :-)
{I guess I should have put off the wipe until I got an answer. ;-)
Date: 8 Nov 2008 14:33:49
Message: <4915e99d$1@news.povray.org>
Using setup (hd0,1) seems to have done the trick. Thanks!
I can't chroot, since /tmp/root/dev doesn't seem to be set up, but that
shouldn't be much of a problem, methinks. I wouldn't think grub gets
updated incompatibly very often. :-)  Given that it's pretty trivial to
back up every file on a partition under Linux and to frob the results
off a live or rescue CD, I don't expect even a disaster where I have to
reinstall would be that much of a problem.
Thanks for the clue!
Date: 8 Nov 2008 15:00:43
Message: <4915efeb$1@news.povray.org>
> versions.
Yeah, I would concur with that - have had that experience myself.
Jim
Date: 9 Nov 2008 13:00:23
Message: <49172537@news.povray.org>
My stumbling block here is that if I use chroot, I no longer have /dev
for GRUB to write things to. If it comes to that much of a disaster,
I'll reinstall stuff and rescue things on a per-file/per-directory
basis. :-)
Date: 9 Nov 2008 15:27:06
Message: <op.ukdcff1k7bxctx@e6600.bredbandsbolaget.se>
You must bind /dev in the new environment before chrooting.
Gentoo users know how to chroot properly, as it is a required step when
installing Gentoo:
http://www.gentoo.org/doc/en/handbook/handbook-amd64.xml?part=1&chap=6
FE
Date: 9 Nov 2008 16:02:34
Message: <49174fea$1@news.povray.org>
> installing Gentoo:
Thanks. I figured it was merely a stumbling block rather than a wall. ;-)
I'll put that into my instructions file under "in case of complete user
screw-up..."
I'm learning way more about system administration than I ever wanted to
know, you know? :-)
Date: 9 Nov 2008 21:52:22
Message: <4917a1e6@news.povray.org>
> basis. :-)
I also mount /dev/ in the chrooted environment.
Jim
