POV-Ray : Newsgroups : povray.off-topic : Something new every day Server Time
15 Oct 2024 15:14:32 EDT (-0400)
  Something new every day (Message 1 to 10 of 20)
Subject: Something new every day
Date: 7 Nov 2008 09:08:44
Message: <49144bec$1@news.povray.org>
So check this out: Apparently piping works on Windoze.
I knew redirecting the three standard handles works on Windoze, but I
had no idea you could actually pipe data directly from one program to
another. I thought only Unix could do that particular trick.
Subject: Re: Something new every day
Date: 7 Nov 2008 11:08:46
Message: <4914680e@news.povray.org>
Welcome to world of PC's. IIRC piping worked even on MS-DOS (eg. type
autoexec.bat|more).
-Aero
Date: 7 Nov 2008 11:39:44
Message: <49146f50@news.povray.org>
> autoexec.bat|more).
	Yep. Been there since forever.
Inoculatte: To take coffee intravenously when you are running late.
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 7 Nov 2008 12:45:29
Message: <49147eb9$1@news.povray.org>
> autoexec.bat|more).
Under DOS, since only one thing ran at a time, this didn't actually
"pipe" the data. It was just a shortcut for
   type autoexec.bat >tempfile
   more <tempfile
You had to wait for the first program to finish, and you had to have
enough disk space, before the second would start.
Pretty much every MS OS since Win3 at least has had actual pipes, tho. I
think the command.com under Win3 still used the tempfile stuff, but the
OS had a "make a pipe" call in it.
Date: 7 Nov 2008 16:25:10
Message: <4914b236@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> > autoexec.bat|more).
>    more <tempfile
  Yes. The difference is whether a program can programmatically create
pipes or not. For example in unix systems (and probably in Windows as
well) a program can create a named pipe, after which it can write data
to it, and then another program can read the data from it. It works like
a data queue between programs. In fact, more than one program can write
to the pipe (although if two programs do so at the same time, it's not
guaranteed in which order the data will come out).
Date: 7 Nov 2008 16:46:07
Message: <4914b71f@news.povray.org>
However Windows named pipes aren't part of the filesystem. Unix's mkfifo is
*very* useful.
Date: 7 Nov 2008 16:52:48
Message: <4914b8b0@news.povray.org>
Yep. And Windows has different kinds of "pipes" as well, in addition to
the usual stream-of-bytes stuff. I'm talking about message queues and
stuff like that.  Windows uses named pipes for all kinds of things, like
talking to the graphics system, over the network, etc etc.
Date: 7 Nov 2008 16:53:50
Message: <4914b8ee$1@news.povray.org>
Yes they are. You just have to use \\?\.... syntax to get at them. Why
do you think they're *named* pipes?
Date: 7 Nov 2008 17:32:16
Message: <4914c1f0@news.povray.org>
Most programs I have tried don't work with that syntax. I think it only
works if you use the Windows API directly, and not stuff like fopen...
Date: 7 Nov 2008 17:38:42
Message: <4914c372$1@news.povray.org>
Not surprisingly, if you use the UNIX interface libraries to access
Windows juju, no, it might not work.  That whole "lowest common
denominator" type thing doesn't really work anywhere once you get
sophisticated about things.   :-)
But yes, I have used named pipes in Unix before, and they can be
surprisingly handy for some things. Kind of annoying in that (at least
back then) the locking/exclusion semantics made things difficult.
Difficult enough I wound up writing a socket listener instead and
replaced the I/O stuff with libraries to talk to the sockets.
