![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: XBOX fun (or trying not to take a hammer to my router...)
Date: 6 Nov 2008 03:13:03
Message: <4912a70f@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Gah.. All I need, an open network with two other machines already on it,
> for how ever long it takes for me to figure out that the frell the problem
> is..
Nobody is going to hack your xbox, especially if it's not even connected to
the network properly :-) And presumably the other PC will only be connected
for brief periods to change router settings? If you're really paranoid,
then just make sure the firewall on the PC is fully on before you connect to
the router.
> Note, it **can't be** the security though, since I already got "past" that
> part. If it was, then it would have failed, as it was initially doing, at
> step 2, not step 3. Its almost certainly something else, some place. :p
That thing where it "connects" but doesn't get an IP, I had that happen when
the machine was not in the MAC "allow" list. Anyway, I think the 1st step
is definitely to reset the router to its default settings, that will at
least give you some further information about the problem, whether it works
or not.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Nov 2008 12:39:45
Message: <49132be1$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Patrick Elliott wrote:
> OK... Anyone here have an XBOX 360 and a Linksys WRT150N router, and can
> tell me why the hell if fails to connect in the test phase for getting
> an IP?
BTW, since you're going to assign a constant IP address anyway, why not
just set the XBox to have a static IP address? Can you do that with the
wireless frob? It's easy with the wired one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Nov 2008 14:20:17
Message: <49134371$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> it, for how ever long it takes for me to figure out that the frell the
>> problem is..
> to the network properly :-) And presumably the other PC will only be
> connected for brief periods to change router settings? If you're really
> paranoid, then just make sure the firewall on the PC is fully on before
> you connect to the router.
Well, not real worried about it, in point of fact, I just don't like
fracking with something that is working, to fix something that I,
frankly, would find "convenient", but is not at all necessary.
>> that part. If it was, then it would have failed, as it was initially
>> doing, at step 2, not step 3. Its almost certainly something else,
>> some place. :p
> when the machine was not in the MAC "allow" list. Anyway, I think the
> 1st step is definitely to reset the router to its default settings, that
> will at least give you some further information about the problem,
> whether it works or not.
I have given up at this point. Seems that this router, for other people,
either a) doesn't give out the IP at all, due to some cheap ass design
of the damn dongle and what it does support (one person suggested buying
a cheap wireless router that will work as a transmitter, then reflash it
with firmware that turns it into a dongle, instead of a router..), or,
b) it connects, but then, no matter how good the signal is, disconnects
are random intervals, rendering it useless anyway. In all cases, it
works fine with anything ***not*** made to specifically plug into the
XBOX. lol
The only solution seems to be to wait to see if they put out a fireware
version that actually works with the dongle (not sure how you even tell,
without flashing it and trying), or just buy some far cheaper, less
advanced, and shorter range, router, which is in the "somehow these do
work" list.
And, again, its "in" the allow list, so that's not the issue. If its in
the "don't allow" this router won't even allow it to get past the
"connected" stage, it just refuses the connection completely.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Nov 2008 16:02:42
Message: <49135b72@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Yeah. Think I tried that before, but maybe not. The info online seems
> damn useless, and mostly amounts to "reset everything back to defaults,
> and if that doesn't work, either hardline it, or buy one that does
> work", which I suppose is useful for some moron that has more money than
> brains.. lol
Welcome to USA.
*runs like hell*
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Nov 2008 17:25:37
Message: <491b57e1$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
<--twitches..
Wasn't the router at all. Somehow, and I can't imagine how the hell this
happens, given that I never "changed" any settings prior to trying to
set the bloody thing up, the "defaults" for something to do with access
in the XBOX isn't where messed up. Got a new issue of OXM, was fiddling
around and decided.. what they hell, as long as it doesn't wipe
"everything" to restore the factory defaults for the wireless, lets do
that. Then:
Wireless - Connected
Security step - Connected
IP step - Connected
etc.
Sat there just staring at the thing thinking, "How the fuck do you ship
someone a hard drive which has the settings for networking already
fucked up, so it won't work like this the first time?"
Now.. I got all the OXM stuff I have added up, on a non-live profile,
which isn't transferable, and which I therefor have to bloody redo (and
that includes, replaying Halo 3 on Easy and Normal, while trying to
remember how to unlock the stuff I have in it, the replaying up to where
I am in Hard, now..) Apparently, its too damn hard for them to let you
say, "This 'offline' profile is the same as the online profile, please
copy any "existing" data over, and even more idiotic, if you logged in
to try to do anything online via the web, thus making a gamer ID, you
have to "recover" it, since, despite there being a "Yes, I already have
one", option, if its not "on" your HDD already, it can't get it from the
server either, until/unless you "recover my gamer ID" (Gives you an "You
can't do that at this time" error, which is the same as what you,
apparently, get if you enter the wrong password {like that makes sense
at all})..
You can tell this idiotic stuff was written by the same morons that did
the integration of features in Windows... lol
void main () {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
