POV-Ray : Newsgroups : povray.off-topic : YouTube Server Time
23 Jul 2026 07:21:31 EDT (-0400)
  YouTube (Message 61 to 70 of 73)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: YouTube
Date: 3 Nov 2008 12:39:13
Message: <490f3741@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> > Damn. And here I was thinking an integer-arithmetic FFT would be really
> > fast...
> When your CPU is a 16-bit CPU on an 8-bit bus running at a dozen MHz,
> even integer FFT is slow.
  And FFT is not the only thing an MPEG encoder has to do. Far from it.
Date: 3 Nov 2008 13:17:49
Message: <490f404d$1@news.povray.org>
>>> fast...
Well quantinisation isn't exactly math-intensive, and the arithmetic
encoding stage shouldn't be too hard either. (It's fiddly to code
correctly, but it's all simple integer arithmetic.) I'm not sure what
else is *in* the MPEG encoder transform...
http://blog.orphi.me.uk/
Date: 3 Nov 2008 13:22:02
Message: <490f414a$1@news.povray.org>
Darren New wrote:
> It's pretty easy. There's three kinds of frames:
> I - Independent. Basically JPEG. Used when going FF and Fast Reverse.
> About every half second.
> P - Predictive. Differences based on the previous I frame. About five
> per I frame.
> B - Bidirectional. Based in the previous and following frame.
> Lots of cheaper mpeg encoding software doesn't do B frames, because
> they're a PITA to calculate efficiently. Natch, with faster and faster
> CPUs, this becomes less of a problem. 5 or 10 years ago, you could spend
> weeks looking for an easy-to-use compressor that would do B frames.
> I think the higher numbered MPEGs added more options to the encoding of
> B frames, so that you could look at more than just one frame away, for
> example.
I'm not really comprehending the significance of the distinction between
P frames and B frames...
>> really fast...
True - but the Intel product line has been 32-bit over a 32-bit bus
since, what, the Pentium at least?
Date: 3 Nov 2008 14:22:09
Message: <490f4f61$1@news.povray.org>
P frames are differences from the previous I frame.
B frames are differences from the preceding and following frames,
whether they be I or P or B.
In other words, you can't play a B frame at all without all the data
between one I frame and the next.
Ever try to skip forward and back in a youtube video? Those jumps
*there* are the I frames (or whatever equivalent). P frames need the
previous I frame (and maybe previous P frames? I don't remember) and B
frames need all the data between two I frames.
Yep. How long do you think DSL and MPEG1 has been around? :-)
Date: 3 Nov 2008 20:49:09
Message: <490faa15@news.povray.org>
Invisible wrote:
>> The key concept is how to describe the current frame fairly accurately
>> with the minimum amount of data, given some data from previous (and in
>> some cases future) frames.  Commonly motion is detected, as often blocks
>> of pixels hardly change, but are shifted in space from one frame to the
>> next.
> ...so they added motion prediction then?
Wasn't that in MPEG1 already? (honest ignorant question)
Date: 3 Nov 2008 23:38:00
Message: <490fd1a8@news.povray.org>
I think it was, yes.
Date: 4 Nov 2008 04:19:46
Message: <491013b2$1@news.povray.org>
>> between P frames and B frames...
I get that there are full frames and difference frames. I'm just not
really understanding why there are two different kinds of difference
frames...
Yeah, I figured that out a long time ago. ;-) Presumably otherwise you'd
only have one I frame, right at the very start.
Date: 4 Nov 2008 04:30:45
Message: <49101645$1@news.povray.org>
>> B frames are differences from the preceding and following frames, whether
> frames...
I think it's just because P frames are way simpler (both for encoding and
decoding), so they get their own name.  It's very fixed how the behave (it's
always the difference from the previous I frame), whereas B frames are much
more flexible, having inputs from a number of frames ahead and behind (even
from other B frames, which can make matters very complex).  Some players get
confused if you use too many B frames, or use them in the "wrong" places, or
use them at all!
Date: 4 Nov 2008 09:52:39
Message: <491061b6@news.povray.org>
  The motion detection in mpeg4 is much more complicated than in mpeg1.
Mpeg4 can track the motion of freely-shaped areas.
Date: 4 Nov 2008 10:20:41
Message: <49106849$1@news.povray.org>
Cool. I think MPEG1 was just 8x8 blocks. I knew they had to be doing
*something* more complicated. :-)
Maybe here's something you know: If Xvid and DivX are MPEG4, why do you
need a special codec to decode them? They're either outputting standard
mpeg4 or they aren't, yes?
